Question about Emerson LC501EM3 50" 1080p 60Hz Class LCD HDTV
I have a Emerson LC501EM3. It keeps blowing the fuse when I plug the power up. I can unplug the main board (green Board) and it does not blow but will as soon as I plug it to the power supply board? If I replace a board, which one?
    Top Expert:
  • Emerson Master
  • 74,383 Answers
It will be best to contact any service technician; before a replacement. There might have other faults too with it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 15, 2014
  • 458 Answers
SOURCE: ba71f0f01042 power board blows fuse
I'm not too familar with this model, but to give you some pointers, you will find when you have this problem the fuse will go straight away as there will be some of the semi-conductors short circuited. Check your bridge rectifier diodes & also the chopper transistor in the power supply. As a general check, test most of the diodes & power transistors & replace any that read short circuit on your meter. Hope this may help you as a guide line.
Posted on Aug 01, 2009
budmrtn
  • 11361 Answers
SOURCE: blows control fuse, have isolated power board, any
It can be shorted bridge rectifier, shorted MOSFET driving the switch mode transformer. Check those two parts first.
Posted on Nov 07, 2009
MNfisherman
  • 11896 Answers
SOURCE: have a emerson blc320em9 a,
You will need to replace your high voltage transformer or flyback. You can get a replacement at http://tigerdirect.partsearch.com
Posted on Dec 12, 2009
  • 8457 Answers
SOURCE: power inverter board didnot solve the problem.
This problems is the causes of the power supply board.The power supply board have problems,it is not giving the tv the wright voltages anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 15, 2010
Slinteriors
  • 8617 Answers
SOURCE: emerson tv keeps blowing fuse
Shorted power supply is the most likely cause. You can get the replacement power supply board from www.tvrepairworld.com
Posted on Oct 28, 2012
How do I find the fuse panel on LG model LSC269055b refrigerator
I think your model number is actually LSC26905SB
There isn't a fuse panel, per se. If I remember your model correctly, the main board is on the back, so pull your refrigerator out, unplug it, and take off the access cover located about halfway up your refrigerator's back. Look at the fuses on the main board. There is a 20 amp fuse that blows easily (the newer boards have a slower blowing fuse in them, now). Temporarily jumper the 20 amp fuse and then plug your refrigerator back in. If you hear relays clicking and such, that's good. The compressor should start up shortly afterwards and all the lights should be on in your refrigerator.
After you have verified operation, go to Radio Shack, or somewhere similar and get yourself a 20 amp slo-blo (slow blowing) fuse and solder it on top of the old fuse on your main board.
Remember to always unplug your refrigerator when dealing with the main board and power circuits.
Good luck and let me know if you need any more help.
Nov 17, 2014 | LG Refrigerators
I have an emerson LC407EM1 and when I plug it in it blows the fuse. What could cause this?
Shorted component/s at its main power supply regulator board. Contact any service technician. Gopakumar Gopalan Google
Feb 28, 2014 | Emerson LD195EM8 19 in. LCD TV
Peavey tnt 115 blowing fuses
your either overloading something cause that's what pops fuses. My guess is that what your plugging in or into has a ground issue. I'm wondering if it does it with nothing plugged in at all. I would say if you have nothing in and it does it, you need to find where the ground issue is. that's my best guess
Feb 20, 2014 | Peavey Electronics Peavey Tour Tnt 115...
I have a Emerson LC32OEM2F, won't turn on. After replacing the fuse, it blows.
If the fuse blows up, it indicates a short circuit. There should be short circuited component/s at the main power supply regulator board [SMPS]. Check and replace the damaged component/s; or; replace this board as card basis. The second option will be the best. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 12, 2014 | Emerson Lc32oem2
Emerson LC320EM2 no power, no sound, blows the 4 amp fuse on the inverter board
this is a combo power inverter board there are several parts to replace , one is the main transistor and check the rectifier diodes along with your brain for buying an emerson
Sep 04, 2013 | Emerson 32in Class LED-LCD 720p 60Hz LED...
My 39 inch tv fuse blown constantly
Either a short or incorrect fuse being used--fuses have become specialized beyond amperage and voltage ratings--a lot are special fuses and or either a slow blow or even a thermal type fuse.
If not a fuse issue, look for a short in the power supply or wherever that fuse is located.
Dec 19, 2012 | Emerson LC391EM3 39 in. LCD HDTV
My emerson model lc320em2f keeps blowing the fuse on the circuit board what can cause this
Check the main power supply regulator board. It will have shorted component/s. That is why, the fuse blows up. In most cases, the components to these type of TVs are vary difficult to get from open electronic spare part market. So it will be best to replace the power supply board as card basis, rather than trying to get it repaired.
Jun 13, 2012 | Televison & Video
Hi i changed colour cartridge tried trial run printer died; changed fuse in plug; still no power any suggestions please
in the printer there is a power supply board.there is a same type of 3amp fuse on the power supply board.if there is any kind of overheating in the power then the fuse in the plug and fuse on the power supply board blows out.in some cases only fuse on power supply board blows out.this fuse is placed on the board for safety reasons.because in the older model printers when this short circuit problem was happening at that time whole board used to blow out.so in the new model of printer a fuse is placed on the board ,so if any overheating or any power outage or any short circuit occurs.the fuse blows out instead of whole power supply board. You just need to replace the fuse on the power supply board by disassembling the printer.the power supply board is the green color square shaped board.its the board to which your power wire of printer is connected. the fuse is available at any local electric hardware shop.its not any special kind of fuse. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
Blowing fuses p50830bl
the board mounted overtop the of the chasis is the convergence power supply board
replace that board will bring your tv back to life
then go into menu readjust convergence red and blue DO NOT MOVE GREEN
Sep 01, 2009 | RCA P50830BL 50" Rear Projection...
NO POWER
if there is no indication of flashing or green light when you plug and try to turn it in this indicates no power to processor. the main fuse is more than likely blown. now this fuse is on a small board that is in front of the green board. just follow the plug in... NOW this board that the fuse is on is known as mains input board. WARNING THIS BOARD CAN AND DOES GENERATE 340 VOLTS DC. AND THIS VOLTAGE CAN BE THERE AFTER U UNPLUG IT. i repair alot of these and parts on this board short causeing fuse to blow. problems can range from plug up to standby my recomendation is if you put qa 6.2 amp fuse in and it blows again ...seek a technician
Sep 30, 2008 | RCA HD61W66 61" Projection HDTV
Emerson LC501EM3 50" 1080p 60Hz Class LCD HDTV Logo
119 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
