Question about Chrysler 2000 Town & Country LXi
The heat doesn't get hot while, i'm warming the van but when i started driving the get hot what's warm.
    Top Expert:
  • Chrysler Master
  • 5,332 Answers
First checkup the coolant level in the radiator before you start the engine cold. Top off as necessary. If it's rally low you may need to "burp" the air from the cooling system.
When the radiator is full start the vehicle and watch the temp gauge. Once the gauge reaches the midpoint you should have plenty of heat. If there is still less than adequate heat raise the rpm slightly. If a lot of heat starts to come from the vents with the added RPMs than one of two things has happened.
1. The coolant level is still to low. The added rpm is enough to push coolant up to the heater core but low RPMs cause a loss of coolant flow and thus less heat.
2. The heater core is starting to plug up due to dirty old neglected coolant. The extra RPMs cause more flow which leads to more heat.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Posted on Nov 15, 2014
Heater is not pushing out warm air. Sometimes if I speed up it will make the air turn warm. The coolent is at a great level. AC works great. Heat is not working in the front or the back of the van
Check the heater core to see if hot water is passing through it. There should be 2 hoses going to it. One into the core and one out. Check to see if both are hot.
Nov 11, 2014 | Dodge 2005 Grand Caravan SXT
Engine temperature gauge low
I would suspect the thermostat first.
Aug 17, 2017 | 2002 Dodge Grand Caravan
Drive to work is 35 miles one way on Los Angeles Freeways engine is warm/hot when this happens usually after idling in gridlock after 15 or 20 minutes it will start again and run well
When it starts ti get to warm on the gauge, open the windows and crank the heat up that will alleviate some of the engine heat. That will help a little.
Now since your saying the car doesn't get to hot when moving im going to guess that there is an airflow problem with you radiator.
1. check to see if there is a blockage of the fins (looking in from the grille).
2. Does the fan come on either when hot or the A/C is on.
If not check fan circuit (fan, relay, and other sensors that activate it).
Coolant may be old and need of a flush to get nasties out of engine and rad.
Just some things to look at. Dont hesitate to ask questions to your mechanic too.
Nov 11, 2012 | 2003 Chevrolet Tracker
2000 malibu runs hot if not warmed up
How do you know it gets hot? Are you going by the temperature gauge on the dash? Or have you checked under the hood and found out the engine really is running hot? ...Reason I ask is, something just doesn't sound right in your description. After just 5 minutes from starting and driving away, the engine would not yet be at normal operating temperature. That would explain the heater not yet warm. But the temp. gauge says hot?
If so, I would replace the temperature sending unit on the engine. the one for the dash gauge, and see if that was the problem-not reading the temp. accurately.
Couple of other things: Are you sure you got all the air out of the coolant system? Start the car with the radiator cap off and let it run until the engine is warmed up fully, then shut it off and install the cap. Does your reservoir tank stay about half full where it should be, between the full-hot and full-cold marks?
If your problem persists. I would have the coolant system pressure tested, and see if you could get a true temperature reading of the coolant when it seems to be running hot.
Good luck.
Mar 05, 2012 | Cars & Trucks
When I start in the morning my lumina'99 starts and runs well but when I park somewhere and try to start while engine is warm, it won't start. I serviced Self Starter and replaced battery but no...
Two possibilities. first when the starter is warm/hot they get hot spots in them and drag, not letting the engine turn over fast enough or at all. second would be the ignition module and these also are affected by heat, they work fine when they are cold , then short out with the heat. I gave you both possibilities as I don't know if your van is not turn over the engine or just not starting up.
Jul 25, 2011 | Chevrolet Lumina Cars & Trucks
A/c blow warm to hot air. put a can of refridgerant in gauge said it was charged and still blowing warm air
I had the same problem with my Lincoln. If the heater valve fails open, it tries to heat the car. This is not the fault of the A/C. To test, when the van engine is cold, start the van and the A/C immediately. If the A/C air is cold, then your temperature control valve is stuck in the open position.
Replace it.
Gary
Jul 21, 2011 | 2006 Dodge Caravan
94 dodge intrepid blows kinda warm but not very warm what do I do? We changed the thermostat
Since your blower is working and it is a heat issue,thats where we'll start,First thing is have you checked the coolant level in the radiator when engine is cold,make sure it is filled to top,next verify you have coolant in reserve ,Start your van and get it up to normal operation temperature,If your heat gauge on the dash works correctly it should be 190 degrees,Now lift the hood and locate the two heater hoses going into the heater assembly at the fire wall,Both hoses should be hot to hold on to,if both are hot and no heat inside your problem will be the blend air door in heater assembly.
if neither hose is that hot you need to replace the thermostat in the engine to get it up to 195 degrees.
if one hose is hot and one is luke warm then the heater core is blocked and to blame. hope this helps you.
Jan 08, 2010 | 1998 Dodge Intrepid
Heat
If this car is remote start GM has a service bulletin out to do a computer flash to correct this problem, it will probably blow hot air in the summer if it remote started if you don't have the computer flash done. Hope this helps
Dec 05, 2008 | 2007 Chevrolet Impala LS Sedan New Cars
Chrysler 2000 Town & Country LXi Logo
51 people viewed this question
Top Chrysler Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
ray gallant
Lawrence Oravetz
Are you a Chrysler Heating and Cooling Expert? Answer questions, earn points and help others
