Question about Garden
ENGINES SURGES AT OPEN TROTTLE. RUN O.K. AT 1/2THROTLE
    Problem Solver:
  • 16 Answers
On most carbs, there is a black plastic main jet under the idle speed screw, remove speed screw pop out plastic jet holder, ,it's possible it plugged.
Posted on Nov 15, 2014
Why does my Ryobi 2200 watt generator surge at low RPM's
The engine is not getting enough fuel. Try choking it some and see if this helps. If it does, then check the fuel filters. If you still have problems, then you will need to clean the carburetor or open the main jet if it is adjustable. Modern small engines are se to run as lean as possible to keep pollution down. This is much worse on small engines shipped to California. If the carburetor and filter are clean and you still have the problem, take the carburetor to lawn mower shop and see if they will replace the main jet with one a little larger.
Let me know if this gets you going. Robert
Nov 17, 2014 | Electrical Supplies
98 saturn with trottle wide open engines revs up then down
Sound like you have a bad TPS. Also make sure your throttle body is nice and clean, that will contribute to the problem.
Aug 18, 2014 | Reliance 98-02 Saturn Sc Sl Sw Series 1.9l...
Engine power increasing and decreasing on full trottle
cant work on these rate these for clean solution
Jan 16, 2013 | 2005 MBK Ovetto
My blower run good up to 3/4 trottle when i go full trottle it slow down it feel like it need air.its 2 years old
its not air it needs,,, what it needs is more fule open the screw up a bit more to let more fule through
Nov 16, 2009 | Echo Inc. 25.4 CC Backpack Blower
Engine speed surges
Surging engines in lawn mowers are usually related to a lean fuel/air mixture. With today's environmental concerns, the carburetors on these engines are set with a very lean mixture (to reduce air pollution). Furthermore, they usually put limiter caps on the carburetors where you cannot easily adjust the mix to get the engine to run better.
If there are adjustment screws on the carburetor, try turning the high speed adjustment screw a bit counter-clockwise (if the limiter cap will allow it). This will enrich the fuel/air mix a bit and might help the engine run a bit better.
Oct 11, 2009 | Garden
1995 Oldsmobile Silhouette 3.8 liter engine
Have a fuel pressure test done to determine if proper pressure is there. At very least change fuel filter.
Jul 11, 2009 | 1995 Oldsmobile Silhouette
Silver series 6.5 hp surging
  1. Carburetor is dirty.
  2. Air leak in carburetor or intake manifold (e.g., bad O-ring, gasket, primer).
  3. Carburetor is improperly adjusted
These are some of the more typical reasons that can cause a small engine to surge.
Jul 09, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Engine Surges and Lo trac light comes on then goes
1.Intake air vacuum leak. Check all hoses and bolts for tightness. With the engine running, wiggle all hoses around and listen for a hiss. 2. Change fuel filter, check fuel pressure. 3. Faulty idle control system/sensor.
Jun 19, 2009 | 2004 Chevrolet Cavalier
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
