Question about Dryers
I have a whirlpool duet gew9200lw0,it will not heat. I replaced the thermistor, thermostat,termafuse and multiple other parts and still will not heat. I need help please.
  • 2,210 Answers
You changed all these bits without establishing whether the element was faulty? Find a local appliance engineer.
Posted on Nov 15, 2014
3 Suggested Answers
  • 93 Answers
SOURCE: Whirlpool GEW9200LW0 Not heating
Hi
You need to remove the back panel first then with a multi meter the easiest way is to put the meter on continuaty test (beeps when contact is made then with the dryer switched of and unplugged put one probe on the one side of the element and the other on the other side if it beeps then your element should be ok if not one of two things (1) Your element is blown or (2) there should be a fuse around the area of the back support plate it may be a normal round fuse or a ceramic round fuse or what looks like a brown rectangular piece of plastic with a wire out each side test the fuse in the same way as you tested the element if blown replace if not then put in a element.
Posted on Jan 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: Need part number for thermistor for whirlpool Duet
Number 42 mounts on the blower housing right beside the thermal fuse
1ee95b6.jpgThe price is decent less than $20.
This video shows how to replace it:
Posted on Oct 13, 2010
F25 error code
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323
Read more: http://forum.appliancepartspros.com/dryer-repair/54078-whirpool-duet-dryer-error-code-f25.html#ixzz2n2Rmgm7a
Dec 10, 2013 | Whirlpool WED9400S Electric Dryer
Whirlpool duet dryer goes to sensing..but wont turn on
The control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box. Here is the part to order.
Nov 26, 2012 | Whirlpool Dryers
I ha a whirlpool model #GEW9200LW0 that runs and then stop after abot a minute and flashes E1
Hello there and thank you for choosing fixya
The dreaded E1 error code is telling you that the thermistor on the dryer has failed and needs to be replaced
Dryer thermister - Located on the blower housing next to the thermal fuse.
Part Number: AP3919451 made by WHIRLPOOL
HERE IS WHAT IT LOOKS LIKE
Aug 04, 2011 | Whirlpool GEW9200L Electric Dryer
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
My GEW9200LW0 electric dryer will stop after a few minutes and flash E1 code. Is it most likely a faulty thermistor? How do I know the correct part # to order?
HI, the thermistor is the culprit in this situation. the actual location of the affected part is inside the unit, on the blower housing(mounted on the backside). The part number is (3976615)
E-1:=(Failed Thermistor)
SIDE NOTE:-The manufacturer has replaced part number 3976615 with this item, part number 8577274. 8577274 may differ in appearance, but is a functional equivalent to prior parts including 3976615.
Oct 21, 2009 | Whirlpool Dryers
Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet not heating, replaced thermistor
If it just won't heat, it's a thermostat issue (most likely). You can try a different setting and check if it works. There are different thermostats for different settings. Also there is a contact that is operated by the motor to insure that the drum is turning for heat.
Jul 01, 2009 | Whirlpool GEW9200L Electric Dryer
Hi
Jan 22, 2009 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
77 people viewed this question
Top Dryers Experts
