Question about Troy-Bilt Squall 2100 208 cc 21-in Single-Stage Gas Snow Blower 31AS2T
I HAVE A TROY BUIT SNOW BLOWER WITH A HUAYI CARB . IT WILL RUN ONLY AT HALF CHOKE .I HAVE CARB APART . CAN NOT GET FUEL METTERING JET OUT IAM SURE IT SCREWS OUT. HOW DO I GET IT OUT?
.ENGINES SURGES WITH OPEN CHOKE RUNS O.K. AT 1/2 CHOKE
Why do you need to remove the jet
You can & should be blowing brakleen
& air thru all the holes
The fact you need the choke partially closed-- tells you something
Your creating higher air velocity,so check for a vacuum leak
(failed gasket) on intake side
May have a failed head gasket also
Posted on Nov 15, 2014
Troy Bilt 3090 snowblower surges off choke, doesnt surge on choke, cleaned the carb, jets, float, drained tank, cleaned fuel filter, fresh gas, still surges. Could it be the governor or idle jet?l
you could try opening up the idle/mixture screw another turn to make the transmission from idle to throttle better
governors just open the throttle butterfly according to the spring tension setting from the throttle lever
Dec 16, 2016 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
How do I find the carburetor adjustment. in fact how do I get at the carb??
take it in to a mower shop for the repair as you exhibit very limited mechanical knowledge
the problem is that there is a blocked main jet or fuel flow restriction in the carby
Sep 08, 2016 | Troy-Bilt 123cc 21-in Single-Stage Gas...
Put a new Huayi Carb on snow blower.It wont run right with out having the choke part way. What can I do to fix it? on
Could be two things.
Most likely thing is that the fuel mixture screw is in too tight and this is causing fuel starvation. Opening the choke fixed this by adding more fuel and less air. Screw the mixture screw all the way in and then back it out one and a half turns.
Or
The level of fuel in the float chamber is not high enough. After you have tried to start it turn the fuel off, remove the fuel supply pipe and then remove the float bowel from the bottom of the carb. The reservoir should be about 3/4 full. A workshop manual is the only way to find the exact level of fuel which is measured from the top edge.
Dec 04, 2015 | Garden
Back pack leaf blower wont run past half chick
Either your carb is still dirty as in has clogged jets or passages, bad diaphragm in the carb or you have the air/fuel needles way out of adjustment. Google what type of motor you have and how to set carb. Or even get a manual, that would be my advice. Also make sure you don't have to much 2 stoke oil in your fuel mix.
Nov 03, 2014 | Hand Tools
Brand new snow blower
A brand new snow blower ?? Who made it, single or two stage, 2 cycle or 4 cycle, Tecumseh or Briggs or China engine ??
Without knowing it's pretty hard to tell you if it's adjustable. Have you tried reading the manual ?? Did you try asking a dealer ??
Most newer machines do not have any adjustability as to fuel mixture. It's strictly an emissions issue. Many are so lean they won't run properly without being full warmed up before taking the choke off and some will still need a little choke to keep from surging. If you look on youtube you can see many cases of it. If you bought it new you can take it back and have them replace the carb and hope it's better. If you have some skills and are willing to buy miniature drill bits (I did) you can take the carb apart and gently drill out the brass main jet to get some more fuel in there. This is also a procedure you can find on youtube.
Feb 04, 2014 | Garden
I have a homelite model uto8550 26cc mighty blower/vac. On initial startup it runs at half choke then stalls when i turn it to run. Any suggestions?
1. check fuel filter in gas tank (for clogged condition).
2. Check carb jet for dirt (squirt carb cleaner in jet and fuel inlet
Summary: your carb is not getting enough fuel to mix properly with constant air flow. Therefore, fuel supply needs to be cleaned... then you will run happy!!
-Jim
Oct 23, 2009 | Homelite Consumer Products MightyLite...
Troy-Bilt Squall 2100 208 cc 21-in Single-Stage Gas Snow Blower 31AS2T Logo
377 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
