There's a low speed screw and a high speed screw. There is also a tickover/idle screw. Its possible this is just screwed in too far. The high and low screws may have tamper proof covers on for emissions regs. Remove the top cover and you should see the screws on the side of the carb. H&L are side by side, idle is on the linkage to throttle trigger.
SOURCE: 16'" Wildthing wont Idle after turning the "t" throtle screw
you only screw it in till it moves the throttle plate. Now start it and set idle
SOURCE: huskvarna model 141le wants to run full throtle all time
Hi
Adjust H,L and T from the carb.When the engine is warm check the spark from the sparkplug:It has to be a strong violet spark(not flame).Disassembly the carb and carefully clean it.Check the fuel pump(it should be tighten not bended),Check the fuel filter and air filter.;the gas tank ventil and the fuel hose.
regards savumihai71
SOURCE: Homelite ut 10550 engine runs at 60 to 100% of
Carburretor possibly has a leaking diaphragm. Some workshops will do just a carby repair if you take it in. Enquire at your local service shop.
SOURCE: homelite gas chain saw 3316C How do
Lossen the bar and pull it out to adjust the chain tension
