Question about Garden
What is the wiring sequence for the ignition switch on a John Deere CR125 ride on mower
The ignition switch on the mower keeps on coming loose in the housing. I removed the wires from the ignition switch to unravel them, tightened up the switch but cannot remember which connectors go to which terminals. I photographed the assembly before removing the connectors but regrettably the photograph is too dark to show which wires/connectors go to which terminal Larry Granger Guernsey
  • 2,210 Answers
Go on BING images, put in John Deere Ignition switch diagram and all sorts pop up. See if that helps. Most are the basic switch setup. Keep a copy for the future.
Posted on Nov 15, 2014
lester482529
  • 226 Answers
SOURCE: I need the wiring diagram for a 7 terminal
GO TO PARTSTREE.COM. PUT IN YOUR MAKE AND MODEL# THIS WILL PROBABLY BE WHAT YOUR LOOKING FOR HOPE THIS HELPED
Posted on Jun 11, 2009
SOURCE: need wire schematic for starter switch
I am holding the switch part (INDAK 681064) with the black pushbutton switch to the right.
The two wires on the top are Red then White. The two wires on the bottom are both black.
Posted on Jun 22, 2009
  • 229 Answers
SOURCE: I need a wiring diagram for a 210 John Deere
try johndeere.com you might be able to get them there or call your local dealer.
Posted on Sep 14, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
  • 146 Answers
SOURCE: my john deere rideing mower idles up and down at
The motor has a governor that controls its speed, and if one of the pivoting parts or linkages is sticking this would happen. Look for the throttle linkage on the engine carburetor (move your throttle up and down, watch what moves). The governor will be a second linkage attached to the throttle arm. Squirt some WD-40 on any rotating parts and make sure a foreign object isn't stuck in there. It could also be the part of the governor that's internal to the engine -- harder to get at, but not expensive to fix.
Posted on Jul 04, 2010
Where dose hot wire go to from coils on la145 22hp v twin
the coil wire is only a kill wire. it goes through the wiring harness through safety switches back to the ignition switch.
Nov 10, 2016 | John Deere Garden
Wiring diagram for LX172 John Deere
Type into google john deere riding mower wiring diagram for pto switch clutch circuit then click images
May 12, 2016 | John Deere Garden
Wiring diagram for john Deere model # 125
John Deere Riding Mowers
Richard, Check the attached links,instruction and guides for wiring diagram. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Wiring diagram for john Deere model 125 Google Search
John Deere Lawn Mower Battery Keeps Dying
HOW TO TEST REPLACE SOLENOID ON LA125 JOHN DEERE MOWER
john Deere model 125 Schematic Google Search
Apr 08, 2016 | John Deere Garden
5525 john deere tractor keeps buring ignition switch
First you will have to check for a short , next i would check the ballast resistor. if the points also burn chance this is a problem.
If you have the wiring diagram check to make sure every thing is wired correctly Good Luck
Dec 08, 2015 | John Deere Garden
I have a john Deere 2030 that the engine will continue to run when the ignition is in the off position. What is the cause and is there an easy fix
Hi Nathan:
Have a look at the switch and see if there is a "ground " wire that has pulled off and is hanging loose.
It is also possible that the switch is broken.
Aug 30, 2015 | John Deere Garden
F7 25 John Deere keep shutting off while mowing is it PTO or brake switch
the PTO an brake switch or only in the start circuit, i would look in the ignition circuit for loose connection
Aug 09, 2015 | John Deere Garden
Why will my ignition not shut off on my john deere LT 166 ride on mower
Have you checked to see if all wires are correct .the key ignition
might be bad it works as a switch and probably ain't turning the 12 volts off you can use a multi meter and che
Jul 11, 2014 | John Deere Garden
John Deere 345 won't shut off
I would start with either replacing the key switch, or tracing the wires to make sure they are not touching together somewhere, completing the ignition circuit.
Apr 14, 2013 | Garden
What causes JD 260 riding mower to start dying when you engage the mower deck? It runs fine when you disengage the mower deck.
It's the safety system that causes this. There is a switch under the seat that should activate when you are sitting in the seat. The switch can come loose or fail, the mounting can break, or the wires can come loose - any of these would cause the "engine dies when I engage the mower deck" behavior. Lift the seat, examine the switch. Rmove the switch and keep the plunger in with a piece of tape. Fixed? Then it's just the mounting or adjustment. Not fixed? It's the switch itself or the wires or connectors to it.
Jul 16, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere CR125 hydrostatic mower, engine runs
sounds like you have carb problems
Sep 07, 2009 | Garden
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
