Question about LG Used Original 47LV3500 RATIO Remote Control
I have a 5 year old lg 47lv3500 how do i scan for pictures with digital antenna
    Top Expert:
  • LG Master
  • 75,289 Answers
Yes. You have to. Refer its user manual for details. Electro help
Posted on Nov 15, 2014
Trying to convert from cable to antenna...I get no signal and it seemingly goes into sleep mode
Consult your TV's owner manual and enter "set up mode" to switch the RF or Antenna input from: CATV / Cable to: Antenna / Off Air. Then, allow the TV to scan VHF & UHF for signals strong enough to "tune in". You may need to upgrade your antenna in order to collect enough signal to display video properly. Make sure that your TV has a digital tuner (ATSC) as the old analog tuners (NTSC) have no signal to tune since broadcasters were forced to digital transmitters by the FCC years ago.
Use the site linked below to help you select an antenna that will allow you to receive all signals possible at your location - without buying more antenna than you need.
Like AntennaWeb org
Apr 08, 2015 | Televison & Video
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
How can I receive digital signal with this TV
go into settings and click on the recieving button and then click on scanning for channels, make sure it says DIGITAL signals. ...this search could take a 5-10 minutes
May 27, 2014 | LG 37LC2RR 37 in. LCD TV
JVC HD-56G886 tuner stopped working
My (unfortunate) guess would be the Tuner received a static discharge when you were changing the antennas... this time of the year is bad for static - if you're in a "Winter" climate.
Receivers have a very sensitive FET or MMIC amplifier right inside from the antenna connection to make it better for picking up distant stations.
However, this same "sensitive" amplifier is also prone to being destroyed by even a small static discharge... especially if the tuner had its power turned ON.
Sad to say, it's likely toasted... :-(
(I hope I'm wrong... but you have already tried all other possible solutions)
Jan 12, 2013 | JVC HD-56G886 56" Rear Projection HDTV
Digital tv tuner not displaying picture
. Try putting you tv set to channel 3 or 4. Try your tv in all modes. Check the back also to see if in the right spots with the wires. Check your channel scan status, try it on anntena and try it on cable, run channel scan on both. good luck. Try vcr wires if cable wires dont work. vcr wires are yellow red and white. Try another cable cord sometimes they get old. Try looking at your remote and setting it to tv.
Sep 02, 2012 | Panasonic PT-50LCX63 50" Rear Projection...
LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Mar 20, 2010 | LG 42LB5D 42 in. LCD Television
LG LCD HDTV 'NO SIGNAL'
To fix the problem, try turning off the TV and unplugging it from the outlet. Once unplugged, push the power button and hold it down for 1 minute. Then turn the TV back on and rescan for channels.
If the problem persists, contact LG customer service immediately as there is a problem with the memory card. The device is unable to retain scanned channels for immediate feedback.
All LG LCD automatically comes with a 1 year manufacturing warranty. You would have to provide proof of purchase to show when it was purchased. Hope this helps. The Guru
LG customer service: http://www.lg.com/us/support/index.jsp
Dec 07, 2007 | LG 42LC2D 42 in. LCD HDTV
LG Used Original 47LV3500 RATIO Remote Control Logo
26 people viewed this question
Computer Repairing
Computer Repairing
