Question about Jeep 2004 Grand Cherokee Limited 4WD
Getting only cold air when heat is on why?
A/c good but no heat?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 108 Answers
I think your heater core is shot in your jeep,it's a bit of a pain to replace,but before you replace it check the thermostat first,maybe it doesn't have one or it's rusted and no good,for what it's worth I would replace it every year any ways.
Posted on Nov 15, 2014
Getting no heat on a 1998 navigator replaced heater core an still want blow out heat
Is your air locked slacken off top hose and make sure your getting a good flow of water no air
Nov 14, 2015 | 1998 Lincoln Navigator
Heat will not come on now
Check your antifreeze if low it will cause the cars to blow cold air.
Most probable cause is blend doors getting stuck in open position I had that on my 03 Jeep GC dual climate common problem $2000.00 repair.
Good luck.
Dec 20, 2012 | 2006 Dodge Magnum RT
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
Apr 19, 2017 | Heating & Cooling
My central heat won't turn on. It's on automatic and won't turn on. When turned to On and Heat, it just blows cold air.
To get proper heat, keep your temp setting at 30+ degreeand also mode in "heat "position. If still no heat, check your heating sensorfor closed circuit by an OHMs metre.Check heating contactor is energized. If yes, and still no heat, check your heating element.
Jan 14, 2011 | Heating & Cooling
The Amana air conditioner is not getting cold.
when is it the last time you cleaned the unit and changed the filters? it may be working good but you need to maintain the unit...clean all filters and see if you can vacum alll parts especially the condensing unit (you may need air pressure) can you move the unit to outside so you can clean it good? if you can use air or water pressur to clean it after you cover the lectrical parts. Good luck. (save your money this unit need cleaning only)
Sep 07, 2009 | Amana PTH093B35AJ Air Conditioner
Getting heat instead of cold
probably the evaporator is not good,and also there is no gas in the the circuit and when it blow air its only heat is coming out
Aug 22, 2009 | GE Zoneline AZ25E12D3B Air Conditioner
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Ford Windstar SE, 3.8L V6, 1999, front seat heat/defrost is cold
the blendor actuators strip out the gear inside the actuator cases on these all the time. replace the actuator.
Mar 10, 2009 | 1997 Ford Windstar
Getting enough heat from my used 2000 elantra
the light for air should come on with your defroster on, Be sure first your radiator is complete full while it is cold and also the coolant resivoir is at the correct level. Good luck, low coolant will definetely make it blow cold. Hope this helps, Merry Christmas
Dec 22, 2008 | 2000 Hyundai Elantra
Jeep 2004 Grand Cherokee Limited 4WD Logo
57 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
