Question about LG LA120HYV Art Cool 120HYV Ultra Efficiency SingZone Inverter Mini Split Air Conditioner System with 12 000 BTU Cooling 13 600 BTU Heating and Indoor and Outdoor Unit in White
Does not produce Heat
When I start my LG with my remote it shows that we are set in the heating mode (the sun). After about 15 minutes, without touching the remote, the machine basically turns off and on the machine (not the remote because nothing has changed on the remote, it still shows a "sun" for heat) there is a snowflake with a water drop underneath showing that it is on cooling and dehumidifying? What does this mean and how can I stop it from happening?
  • 29 Answers
Sounds to me like it is defrosting the outdoor unit. Is this possible? The process takes a little bit to complete but it will then start up again.
Posted on Nov 26, 2014
  • 4 Answers
SOURCE: AIR CONDITIONER LG S18AN
The operating LED will be blinking 5 times, means that there is a
comunication error (serial comunication) between the outdoor and the indoor unit.
Posted on Jan 20, 2009
daddyo742001
  • 70 Answers
SOURCE: My LG LAN125 mini split heat pump occasionally
Wash out your outside coil and monitor the outside fan. sounds like a lockout due to dirty condenser or intermittent motor operation. Could mean condencer air problem.
Posted on Jun 28, 2009
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
Myminisplit
  • 11 Answers
SOURCE: 5mint cooling 5minuts heating
The reverse valve and silenoied are bad, you need to change them or replace the condencer.
Posted on May 21, 2010
SOURCE: My LG Lan125HV works fine on air conditioning (
I talked to LG customer support (800) 243-0000. The tech told me that this model had a problem with the indoor thermistor. It doesn't fail with an open-circuit condition, so you don't get an error code. The thermister just goes out of range and believes your indoor temp is much hotter than it is. That's why the heating never comes on. I'll bet that, even though it ran in COOLING mode, once your room reached setpoint, it just kept on cooling & cooling ... because the thermistor was still giving a false, high temp reading.
So, I bought a new thermistor, P/N 6323A20042A. My unit worked fine. Until the next week when I turned heating back on and now I have the same problem ... gives cooling but no heat. Something is failing the indoor thermistor OR the distributor sent me an old-style thermistor, I haven't gotten determination on that yet.
Regardless, call LG and see if they can't direct you to a distributor for an indoor sensor. LG's warranty coverage for parts is a royal pain, unless you can show a receipt by a certified installer, you're not going to have much luck getting payment for the part. However, the thermistor is only $10. Just hope you get one that doesn't fail on you!
Posted on Nov 27, 2010
Lg oven not heating after self cleaning. code f9
F9 stands for oven no heating. It will be displayed if oven temperature readout when oven temperature doesn't exceed 150F/66C in less than 5 minutes from set time. I would say you may have a heating element malfunction..
Oct 23, 2016 | LG Kitchen Ranges
Cant get to heat and it is on the sun mode
Point at unit set on sun icon and scroll temperature up unit should beep and light on unit flash to show its received after a minute or so unit will start
Aug 29, 2015 | Mitsubishi Heating & Cooling
How can I set my remote for cold
Press the 'mode' button on your remote until it says 'cool' or shows a snowflake symbol. Careful that you don't set it to 'heat' mode accidentally if it only has symbols. The 'sun' (heat) mode symbol can look like a snowflake on some of these remotes. Then set the temperature to suit you.
Jul 26, 2015 | Fujitsu Heating & Cooling
Remote start is set for a/c, how do I change it to heat
There are symbols for each mode. Fan leaf for fan mode. cool mode indicates round star. and Sun symbol represents for heat.
Plz note if you change mode heat, it keeps memory and when you switch on again, then the same heat mode will work.
Tnx
Nov 16, 2013 | Heating & Cooling
All three units turn off after 2 minutes
Make sure you have set them correctly IE/ If you want them to heat, make sure the heat symbol is dispalyed and the temperature setting is above the room temperature. Press the "house" symbol on the remote to find the room temperature. LG as with most other brands , if set to cooling but the remote temp is set high ( 20 to 25 degrees,) will run for a few minutes and then turn off as the machine thinks it has reached the temperature you have selected.. Heat symbol on LG is a "sun", cooling is an icicle. Check your filters.... if they are dirty, the units will not operate correctly.
Jun 15, 2011 | LG Heating & Cooling
I have lost my service Manual for my NEC 6847 Air con unit & need to download one so that i can figure out how to get the heat to work
Make sure the remote control 'Mode' setting is on 'Heat', usually an icon that looks like a small sun. Then increase temperature setting until unit switches on. Can take 7 minutes or so to give any warm air flow, but if nothing after about 15 mins, then you have a problem. - Rick
Jun 12, 2011 | Heating & Cooling
I have an AMCOR model AL-10000EH. The A/C side works fine but I cannot select the heat mode with controls on the panel or with the remote. I can select all modes except the heat mode. Hope You can help,...
Remove batteries from remote and reset it. Now keep in "Heat" mode. and setting temp +5 degree than your room temp. Wait for 3 minutes. Heat mode symbol will be like symbol of SUN. Helpful?
Dec 27, 2010 | Amcor Heating & Cooling
The problem using the lg 6711a is that i dont know that how to use its heater. Its an a/c+heating system, the remote just shows some symbols. please tell me that how can i use its heating system/how to...
Press on/off switch and then press mode button still cool symbol * and then set your temp 23 by pressing < or > And for heat press mode still symbol heat (symbol like sun), and set temp 29.
To switch off again press on/off button. Is it helpful?
Dec 17, 2010 | Heating & Cooling
LG PTAC acting strange in heat mode
I believe the problem in lies in the dual stage heat mode setup on the thermostat, but the unit going into defrost does make the unit act kinda strange. Even more so than other types of equipment. I would suggest hiring a licensed HVAC service technician if the problem cannot be resolved by yourself.
Dec 15, 2008 | LG LP120HED Wall/Window Air Conditioner
LG LA120HYV Art Cool 120HYV Ultra Efficiency SingZone Inverter Mini Split Air Conditioner System with 12 000 BTU Cooling 13 600 BTU Heating and Indoor and Outdoor Unit in White Logo
223 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
