Question about Measuring Tools & Sensors
While mowing the engine was running fine then all the sudden it got real loud like the muffler wasn't right and lost power. Nothing seems to be wrong with the muffler. Any Ideas?
gvince4
  • 31 Answers
SOURCE: loud distortion SA-WMSP75
You blew your sub.
Posted on Jan 20, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Kitchenaid Dishwasher has starting making a real loud noise
Hi Andy and welcome to FixYa. I am Kelly. That loud noise your hearing is the motor bearings. If you were to remove the lower kick panel you will prbably find signs of a slow leak of water has been trickling through the motor and you will see a water spot under the motor pump assembly.
You were correct in your assumption that it was bearings. What happens is the motor shaft ceramic seal starts leaking long before the home owner even notices it. Then the water gets into the motor and corrosion starts to build up. As the motor turns the bearing starts to spal as a result of the corrosion and you hear the loud noises.
The only fix for this sadly to say is a complete motor impeller assembly replacement. If your model number is the one associated with this post / question: KUDI01FLSS then there is one more digit after the last "S" that being one of the following numbers 0, 1, 2, 3, 4, 5 or 6.
The motor and impeller for your dishwasher Item 10 or 18 can be found here and is listed at $138.44:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164895&diagram_id=907556#d907556
The seal that has failed is item 23 of the same link. Changing the seal at this point will not stop the noise.
Thanks for using FixYa.
Kelly
Posted on Apr 23, 2010
pack484hawks
  • 13 Answers
SOURCE: I was driving my 50CC scooter down the road today
Your drive belt snapped. If it is a 50cc, 4 stroke engine, chinese scooter, with a 10 inch rear wheel, then you most likely need a 669-18-30 belt. That is the most popular scooter belt on the planet and is available for about $10-$35, depending on the quality you want. Any scooter shop can change it for you. It only takes about 15 minutes, but expect to pay a chargeable labor rate of .5-1hr since there are unexpected problems occasionally, and there is cleanup time, paperwork time, etc. It should cost about $30-$75 in labor plus parts. Any more than that and you are getting ripped off. You may have other worn parts in your transmission such as roller weights and variator guides. These tend to wear out on chinese bikes around 3000km+. If they are worn, change them while the technician is working on it. It shouldn't cost you any more labor, just the parts, about $12-$20 for the rollers, and $8-$12 for the guides. Cheap belts last about 2000-3000km, good belts last 5000-9000km. Pay the extra few dollars for the better belt, you won't regret it. If your belt broke prior to 2000km, then you may have a defective part in your transmission, such as the rear pulley. That usually comes as a "clutch pack" and generally sells for $40-$90. If you have more than 2000km, it probably snapped just from normal wear and tear. If you can't find a local scooter shop, you can reach us at www.solanocycle.com. We can ship you any parts you need. This repair is not recommended for novices. Although it is easy for those who know how to do it, you can damage your crankshaft and ruin your motor if you do it wrong. Hope this helps.
Posted on Jan 03, 2011
  • 35 Answers
SOURCE: 2005 Victory Vegas, Motor lost
It sounds like computer has put you bike into limp home mode or safety mode to protect the engine. What warning lights do you have if any come on? it sounds like a sensor has either malfunctioned or has done its job properly and picked up something wrong like, temp sensor, oxygen, oil pressure, mass air flow sensor etc. Either way when something is out of the norm form the sensor inputs to the bikes computer it will often limit the revs on the bike putting it into limp home mode to protect the engine.
I personally would be getting a mechanic to put it on a diagnostic machine. If the computer has caused the bike to go into limp mode, your mechanic will more than likely be able read a fault code from your computer to point you in the right direction as to the root cause of this fault.
Posted on Jun 02, 2011
  • 6468 Answers
SOURCE: Gt 245 lawn tractor won't go forward or backward
check the belt
Posted on Apr 08, 2012
Tip
Personal Safety
Be sure to take the right safety precautions before you mow.
  • Never attempt to lift or repair mower with engine running.
  • When mowing with a walk-behind mower, wear heavy-duty shoes with non-slip soles and long pants to protect your legs.
  • Always wear eye protection when operating a mower.
  • Don't mow a wet lawn or late in the day when the light is dim.
  • Never let the starter robe snap back when starting mower.
  • Always mow up and down an incline with a traditional (i.e. unit with steering wheel) riding mower.
  • Always mow across an incline with a residential walk-behind mower.
  • Never adjust mower height, clean grass chute, or remove grass catcher with engine running.
  • Always stay clear of hot engine. Mufflers can reach up to 1,200 F (648 C
on Apr 02, 2011 | Garden
I just bought a 1994 Toyota Camry le. Only thing wrong was it needed a new battery, my car was running fine then all the sudden it wouldn't start but the battery wasn't dead. So I went and bought...
If I am understanding u, it sounds like u might have the wrong plugs and their hitting the tops of the pistons. Double check that they are the right size. Hope that helps
Jan 05, 2013 | Cars & Trucks
Kohler 27 hp courage engine - oil light and Oil Lag LCD on
do a compression test and see if you blew a head gasket it would be easier to tell if i could hear it could have blew the engine is it loud?
May 30, 2012 | Cub Cadet Garden
Every time i put a new muffler on my 1997 jeep grand cherokee the motor bakfires and blows the muffler compleatly apart it dosent do it right away it runs fine for a few miles then boom then it starts to...
What a funny set of events.Of course the tail pipe is clear(you would have checked that)The only other thing it might be is the cat/converter is blocked.New muffler is allowing a heap of air through and it suddenly clears and the bang.They do block up so it may be worth getting it checked.Hope this helps
Oct 31, 2010 | 1997 Jeep Grand Cherokee
Husqvarna Lawn Tractor LGT 2654 (from Lowes) B&S Intek V-Twin 725cc 26 gross hp 110 hrs. I had a couple of problems with the 2654 in the past but they were electrical. Now the engine seems to...
A common loss of power problem with B&S V twins is a set of crumpled valve push rods. Means you are running on one cylinder which is generally OK unless you also want to mow. Easy to check, pull one plug wire at a time off. If it continues to run on one cylinder but not the other, that is your dead cylinder. As the intake is not opening, there will not be a wet plug. Costs nothing to check and could be your problem.
Sep 21, 2010 | Garden
Loud & smoky smell
could be open at the top of the muffler .......or may be a flange connection between the headers and the intermediate pipe or the connection along the seam or to the muffler
you will need a light and with the vehicle running {{Visually Inspect}} for smoke or louder noise to seclude the area /s of this issue .
Dec 29, 2009 | 1996 Ford Windstar
Lawnmower had loss of power after running into shed door...
two things come to mind here,
1. did the door hit the muffler or carb, if the muffler port is blocked you will loose power.
2 you said the door ht the cover, if it pushed the cover in on the flywheel it may have partially sheared the key. this would cause the timing to not be correct. if it had completley sheared it would not start but if partially then it probally would biut timing would not be right.
Jul 07, 2009 | Troy Garden
My 89 honda civic has been running rough
No it has not been overheating or losing coolant at all it just has been running rough and poorly (loud) it was not smoking till he took out the old spark plug and put in the new one he said it was smoking out all that had been backed up into the cylinder due to non working spark plugs (there was oil on the spark plug)
Nov 12, 2008 | 1989 Honda Civic
1990 gmc k2500 new 5.7engine & turbo 400 ,power lose & noise.
sounds as if you may be looking in the wrong spot. If different gearing is drastically changing the symptoms you may want to check the trans. or torque converter. sudden pop with engine rpm increase and lack of power sounds like possible band breakage in transmission or impellor breakage in torque converter.
Oct 20, 2008 | 1990 GMC K2500
Measuring Tools & Sensors Logo
42 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
