Question about Refrigerators
My condinsate pan on my sub sero 642 was overflowing after I returned from 3 weeks away The machine is holding temp , the hot side cois are warm I can't figure out why the water collected in
My condinsate pan on my sub sero 642 was overflowing after I returned from 3 weeks away The machine is holding temp , the hot side cois are warm I can't figure out why the water collected in the pan and did not evaporate ???
  • 739 Answers
Because the refrigerator wasn't opened for those three weeks, the machine did not have to work as hard to maintain temperature, causing shorter cooling cycles, a good thing; but this also means the compressor isn't getting as warm as it normally does either which means less evaporation from the condensate pan. The defrost timer keeps doing its job melting off accumulated ice; but it is time regulated, not usage regulated. Best idea would be to raise the temp setting a couple clicks when you are going to be away for awhile.
Posted on Nov 14, 2014
SOURCE: The drain line from below the defroster unit seems
If the drain opening has frozen over you can thaw it out with a hair dryer. The drain can be cleared by inserting a short piece of hose into the drain and blowing in the other end. Another method is to insert the tip of a turkey baster into the drain hole and apply air pressure by squeezing the bulb.
Flush the line with a small amount of water.
Posted on Apr 28, 2009
Sea Breeze
  • 4655 Answers
SOURCE: drain pan overflowing, evaporator not working ??
The condensor fan and the heat from the compressor help the evaporation of the condensate. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) Find that number and we can go from there, Thanks, Sea Breeze
Posted on Jun 11, 2009
  • 102 Answers
SOURCE: Sub Zero 642 side by side stainless steel leaks water from right
remove the crisper drawers and you will see a drain trough and a drain line . One or both is most likely blocked. If you pull the drain line off the trough usually you can clear it with a turkey baster filled with hot water
Posted on Aug 05, 2009
Testimonial: "Problem solved, thank you!"
woodchuck789
  • 4070 Answers
SOURCE: overflow of condensation water
If you have a water filter the water will leak past the filter to the pan if it's clogged up and needs changing.
The defrost water drains to the pan, so if you are having a lot of frost it could fill it up. Excess frost can be caused by leaky door gaskets and frequent door openings.
The condenser fan near the pan should be running when the compressor runs to help evaporate the water in the pan.
Posted on Sep 09, 2009
  • 4793 Answers
SOURCE: Collected water in evaporator pan does not
you obviously live in a high humidity area.(or you are putting warm/uncovered food inside) but the answer is yes,or you could collect the water to use on you indoor plants.........better than tap water...
Posted on Jul 08, 2010
Refridge temp
Lets go over the way a sealed system works. There is a highj side and a low side. The low side is the side that passes through the evaporator coils inside the machine. Most times on the freezer side only, but sub zero has independent sealed systems for each side. Once it goes throug the evaporator its then condensed into a liquid state, the high side. This is also the hot side. Well, lower pressures in the low side would logically mean lower temperatures. So for the refridgerator not to freeze more freon is used on it to keep the low side pressure higher than normal, giving the cooling effect verses freezing. So, and here is the bad part, if you are seeing ice build up in the refridgerator side you have a freon leak some where allowing the pressure to be less than required to keep it above freezing. Call a service technician and depending on how the model, sub zero warranty is parts and labor covered for the first 6, and only parts from the 6-12 year.
May 27, 2012 | Sub-Zero 642
Does not blow hot air
1st off check your (cold) radiator (not the overflow tank) make sure it's
full, next locate heater hoses at firewall with eng. warmed up hold both
hoses 1hose should be hot going into the the other just a little cooler
coming out when it's working right but if 1 hose is hot and the return
is just warm you may have a restriction possibly plugged heater core
now if both hoses are warm not hot it could be thermostat is not closing
properly there is also the heater ctrl. valve but i don't know if you have
a mechanical- electric or vacum operated valve.
ps do these tests with eng at operating temp. fan on med. temp set on
hot. any other ? gimme a shout good luck
Jan 13, 2010 | 2000 Jeep Cherokee
Although my sub zero 642 is holding the temperature, there is water leaking from underneath the refrigerator every day onto the floor. Sometimes it is heavier than others.
it's condensate from the evaporator coils. when the humidity collects on the coils, it should drain into a pan under the fridge that gets evaporated from the hot-side line. check to see if the condensate tube from the coils is still in the pan.
Jul 29, 2009 | Sub-Zero 642
Sub Zero 642 side by side stainless steel leaks water from right door. evaporator pan is dry, water/ice dispenser door catch basin is dry. Several times per day water collects right under the stainless...
Jul 01, 2009 | Sub-Zero 642
I have a 642/0 side by side sub zero. Although
Has the ambient temp around the unit been going up? Depending on what refrigerant you have here the pressure temp relationship will change in the system, also when you add foodstuff, and again when you open the door.
Jun 29, 2009 | Refrigerators
AC is running but can't keep the temp down. Everything is brand new. AC unit is on shady side. New filter, no cloggs. No clog in drip pipe. Condinsation building up on pipes outside. Please help.
If the big pipe out side is cold and sweating and the little one is warm to touch if it is hot to touch under charged. I would suspect insulation, or under sized unit
is their a 20f difference from supply air to return air the i would lean towards insulation. Tom
Jun 25, 2009 | Ruud Matching Split Air Conditioner
Main door handle top section pulls out from bolt on sub zero 642
There is a tiny set screw that holds that in place. It is on the bottom of the stand off and just needs to be tightened.
Nov 26, 2008 | Sub-Zero 642
New WTW5700SW clothes washer. 1 week old. Worked great for 1 week. Temperature control problem. The cold setting provides hot water. The warm and hot setting provide cold water. The warm setting...
the temp thermister in the control panel is bad, lowes has a 30 day return policy if they delivered it have them bring you a new one, if you picked it up take it back, get a new one no need in starting out with an new almost out of the box washe with problems
Apr 13, 2008 | Washing Machines
Kenmore 5022 please help
Do you have a heavy frost on the rear panel of the freezer section? If so, you have a defrost system problem. If you will post the complete model number I can help you diagnose which part you need to fix it. In the meantime, you can manually defrost it and it will work for about a week or so until the frost builds back up.
Oct 19, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
