How to Remove the developer unit from Oce TDS 600?
SOURCE: Oce TDS 400 Printer. Erore Prob.
erore
Posted on Aug 25, 2008
SOURCE: oce tds 800 how do you reset the counter for maintenance and part
hi
you have to go into service first
you have to log on in SDS
WITH user :oceservice
pASSWORD:675756
And there on consumbeles you have to reset by
pressing 0 / enter and than egnoladge with the green V on top
good luck
Yaacov
Posted on Mar 08, 2010
  • 149 Answers
SOURCE: OCE TDS 600 error code 22017. Do you Know what it
There is a problem in the power supply section. Call for service, this is not user fixable.
Posted on Oct 05, 2010
  • 212 Answers
SOURCE: MY OCE TDS 400 PRINTER
damage of toflon of printer
Posted on Mar 11, 2011
lukebeeee
SOURCE: oce tds 600 Error code 15504 machine stopped in
There seems to be a feed problem. I googled the error 15504 for the Oce printer and got this page. We did this (see photo) and that seemed to sort the problem out for the meantime (until service guy gets here). I dare say it's a sensor somewhere. So jam a roll of cardboard from a used roll in behind the roller (as in the photo) and that does the trick. Hopefully this works for anyone else with the problem.
Posted on Sep 06, 2012
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8507,i want A Solution
Turn off the printer, and let it cool for an hour. The problem will return, but you may have the ability to get some emergency plots out in the mean time. The error code has to do with a thermistor in the fuser section. These thermistors are made out of a delicate ceramic and are easily broken or cracked if installed incorrectly. I would recommend that you call an authorized Oce/Canon service representative unless you want to spend several hundred dollars on incorrect, or broken thermistors you may get via other official channels. Each Oce model may have a different rating of thermistor, so just putting any thermistor in most likely will not solve your problem and may cause others.
Mar 10, 2017 | OCE Office Equipment & Supplies
Oce tds 600 error code 08005
you can see you'r answer here:
http://www.copytechnet.com/forums/other-copier-brands/90112-oce-tds-600-08005-error-code.html
Sep 01, 2013 | Office Equipment & Supplies
Oce tds 400 random black lines on demo print
Check the developer and clean the charge corona and the transfer /separator corona assy.Clean the PH unit lens.
Jan 29, 2013 | OCE Office Equipment & Supplies
Oce TDS 600 scanner error code 10501
the heater stays cold during run,heater bad or false contac or ssr defect
error 10501
May 22, 2012 | Office Equipment & Supplies
OCE TDS 600 error code 22017. Do you Know what it is >?
Oct 04, 2010 | OCE Office Equipment & Supplies
Oce tds 600 Error code 15504 machine stopped in the middle of a run (like every 5 sheets) could be an overheat problem
Sep 02, 2009 | OCE Office Equipment & Supplies
KONICA 1015 COPIER - P.27 ERROR MESSAGE - - WHAT DOES IT MEAN?
2. Toner was added prior to adding developer and performing the TDS adjustment. Developer must be added FIRST at new machine set-up so that toner does not fall on the uncovered TDS sensor.
Run 47 mode, output code 51 until the code does not reoccur (may take 5 to 10 attempts) OR open the developer unit and clean the excess toner from the area of the TDS sensor. Then tilt the developer unit to allow fresh developer into this area.
3. Poor connection at CN95. The toner density sensor (TDS) is abnormal (0.2 V DC or lower). Reconnect CN95 (located under the front of the developer unit).
4. TDS failure. If version 16.0 is installed, P27 is displayed when the TDS is disconnected or fails. Check for proper connection prior to replacing the TDS.
Jul 10, 2009 | Konica Minolta Office Equipment & Supplies
Error code P27
P27 is a TDS sensor error. You need to check the connectors on you developer unit. Open front cover, push down on copier then lift green handle. remove screw just above toner suppy unit and remove your drum assembly. Next remove your developer unit(two latches hold it in place). your TDS connector is located under your dv unit(you will have to remove the black cover). When finished reinstall drum assembly then turn on copier. If problems persist turn copier on while holding down 47 then press 40 then start.you should hear a motor running (let it run for 1 min.) If you don't try P40 or 01. Turn copier on then back on. If the problems persist I recommend a service tech. your DV or TDS sensor needs to be replaced.
May 28, 2009 | Konica Minolta Office Equipment & Supplies
55 people viewed this question
jasbo
jasbo
