Question about Watches
Marcel hour strike quartz modem # 4ms603 does not chrim
How to remove a link in a q and q quartz watch
My Citizen Skyhawk analog UTC hour hand is always 9 hour back of the UTC digital hour. I've tried to reset and hour/min hand alignment process without success.
Jul 23, 2013 | Lucien Piccard 26024 Wrist Watch
I have had mens talking watch ( silver ) for many years but the talking module has failed,changed the batts but still no success, can a replacement module be obtained or does the watch need to be...
10.0.0.1 IP address is the default gateway of most wireless routers or ADSL modems. There are several IP main addresses a router can take, 10.0.0.1 is the most common one though 192.168.1.1 or 192.168.0.1 are also other options. http://10-0-0-1ip.com/
Dec 07, 2017 | Marcel Drucker Silver Talking 4 Button...
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    I have a bretling colt quartz watch and the hour regester will not reset
    Try pulling out the winding crown,then press the chrono pusher.This will advance the chrono hands.Each pusher will advance a different hand.
    Aug 13, 2010 | Breitling Colt Quartz 820 Wrist Watch
    I have an antique clock that requires two places to wind it up. Since Daylight Savings Time went into effect, the clock has gone crazy, chiming the hour on the half hour and chiming three hours ahead. What...
    With only limited information provided about your type of actual antique clock this symptom has to conclude that your clock is a non self correcting style.
    Step one: Ensure clock is striking the hour. during the time of the hour strike quickly move the minute hand to the hour.
    Step two: Move to the half hour allow to strike, move hand to hour allow to strike then move the hour hand to align with the correct count.
    Step three: Stop the clock until the correct time has been achieved and start clock OR strike ever hour and half hour until clock is set to the correct time.
    Hope this tip guides you to a solution for your clock.
    r/ David
    http://antiqueclock.clockstop.com/
    Apr 06, 2010 | Watches
    How does the swiss eta g10.211 quartz chronograph work
    I am not sure if I understand your question. Are you asking how this particular quartz movement operates?
    All Quartz movements are pretty much the same operational wise. They can vary greatly in materials used for construction and number of jewels.
    At it's basic a quartz watch uses a piece of quartz crystal called a transistor oscillator to vibrate a tuning fork. This vibration is a is brought down by micro processors to a meaningful number then converted into mechanical energy trough the movement and hands.
    In the case of a chronograph it means more internal gears and jewels.
    Although this is a good movement it is the low side of middle of the road.
    The G10.211 is an analog display of hours and measured time. These include hours, minutes and a small jumping second as 6 o'clock. Mechanical date and counters for 1/10 second, 60 seconds and 30 minutes with "ADD" and 'SPLIT" functions. Operated by 2 push buttons.
    It has 6 jewels.
    If you want to know something more specific please just ask.
    Hope this helps.
    Dec 31, 2009 | Bulova Watch
    Marcel Drucker talking watch
    Calling them directly will help you resolve any problems with the older model. Phone 1-800-422-6053 or 1-201-330-5600 if the 800 number gets you nowhere.
    Their website is http://www.marcelwatch.com/
    Regards,
    Worldvet
    May 29, 2008 | Watches
    Watches Logo
    81 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
