Question about Garden
My Yardworks riding lawn mower won't start. There is fuel getting into the cylinder and the spark plug is new. What do I check now? It cranks well, just won't start.
This unit was working fine when it was shut off about three weeks prior, but it won't even kick now, just cranks. Someone suggested a "toggle switch", but I don't know what they are talking about.
  • 4 Answers
Sounds like the needle valve in the carbuetor is stuck and allowing gas in your oil.. You need to fix that and change oil before you start it up.
Posted on Nov 16, 2014
  • 33 Answers
SOURCE: I have a Crafstman Riding mower model #917.273643.
sounds like your coil went bad
Posted on May 02, 2009
RonInFla
  • 86 Answers
SOURCE: have crafstman riding lawn mower: replaced
double check the ground wire going from the battery terminal to the engine...it is usually on a mount bolt at the engine...if the mount bolt is loose, it's a poor connection...
Posted on Apr 26, 2010
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
  • 2239 Answers
SOURCE: I want to change the spark plug in my 1988 yardman riding lawn mower but don't know what size socket needed to remove it?
Most common size is 19mm
Posted on Mar 13, 2012
  • 6468 Answers
SOURCE: I have a Snapper LT160H42FBV2 riding mower. Won't start , new solenoid switch, new battery, starter checked, its good. still won't start just clicking sound. any suggestions?de
bypass the safety switches to test them while looking for the bad one the clutch/brake is the most common one
Posted on Jul 11, 2012
Engine doesn't start and run...just turns over.
take the spark plug out and crank the engine over for 30 seconds to blow out any gas that may be in there. get another or a new spark plug and put it in and try to start it. maybe check compression to see if the valves are working properly. if you have spark and fuel and compression it should.
Sep 20, 2016 | John Deere Riding Lawn Mower. EZtrak Z225...
Will not crank DEAD but lights come on
Riding Lawn Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf666549.tip.html
Question: Lawn Tractor Won't Start. I have a John Deere LA125. I bought it new in 2009. After sitting unused in the garage for the winter (5 months) I couldn't get ...
Craftsman Riding Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf68077908.tip.html
Why will my Craftsman lawn tractor not start with a new battery, new spark plugs, new gas, gas filter, .... Question: 18.5 hp Craftsman Lawn Tractor Won't Start.
Riding lawn mower will not start - Household Repair Series ...
? 3:41
https://www.youtube.com/watch?v=DFDSvWtXwBk
Jun 21, 2013 - Uploaded by Robert DIY
This video will explain how I got a riding lawn mower started. Always check the basics. ... Lawn Tractor Won't Start--Any Ideas? - Duration: 2:04.
Jan 21, 2016 | Garden
Why won't my riding lawn mower crank over?
Hi if you have got it cranking remove the plug and check for a spark the plug must be earthed to do this if you have a spark it must be fuel pore a small amount in top of carb make sure ign is switch on hope this helps.Ron.
Jun 20, 2014 | Craftsman 420cc 30 6-Speed Rear Engine...
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
190cc 675 sears push LM. Irene put it under water. Drained carb and crank. removed and cleaned filter. New gas. Won't start. Got a little pop with starter spray. No pop at all?
Did you drain fuel tank before refilling with fresh fuel? Drained carburator bowl good, drained crankcase and refilled with fresh oil good,removed air cleaner and dried out good. One question for you , did you remove spark plug and drain any water that may have gotten into your cylinder through an open valve? There could be water sloshing around in the cylinder, gas and water will not fire, and water on spark plug wont allow plug to spark. If you need any more help please get back to me , I believe this is the first under water problem I've encountered. GOOD LUCK.
Sep 07, 2011 | Briggs & Stratton 190cc 875 Series OHV...
Bought this lawn mower.It was sitting for two years and now it won't start.
first things first:
1) make sure that the kill for the magneto/coil is breaking contact( it is on the side of the mower,follow the cable down from the red bar)
2) gas to carburetor
3) spark to plug/s
4) gas to cylinder/s
pull plug and try starting mower, observe spark plug for spark and fuel coming out of cylinder/s. if spark no gas, then check to see if it getting to the carburetor, if it is then it is the float and seat in the carburetor and will need to be cleaned/replaced/rebuilt. Or just simple pour gas into the carburetor and try starting if it starts then it is the fuel line, carburetor. Hope this helped Tim
May 22, 2011 | Garden
Lawn tractor will not crank, new battery installed. only get a sqealing noise.
try turning the fly wheel by hand can you turn it . if not remove the spark plug then try again . if fuel comes out of the spark plug hole in the head the carb is leaking fuel in to the cylinder . if on fuel comes out remove the rocker cover and check the valve clearance .005 intake .003 exhaust . some time the valve stud comes lose and the rocker comes off the valve. also check the intake push rod to see if its bent .
Apr 11, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Riding Mower will not start
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
Jul 05, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
