Ast24 operation light blink constantly and timer light blinks 14 times rests then 14 blinks?
  • Michael Moy
    Michael Moy Nov 15, 2014
    Cheers thanks! Turned power off for 5 minutes all good now
SOURCE: Fujitsu Heat Pump - problems
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Posted on Aug 08, 2008
farfield
  • 462 Answers
SOURCE: friedrich m18cf have timer blinking
If I see a code blinking and all is normal as far as I can tell it means something is in a time out mode and counting down to energize. This may not be the case but let it run and blink for a few hours and see if it comes on.
Mark your watch so you can see how long it takes to change or start.
If it does start then you know about how long it will take to recycle.
Assuming you have changed the batteries in the remote (if you have such), and it does this again do not use the remote again, if possible. Try it with manual only. Remote - remove batteries, this will eliminate the remote as the cause.
Next is find the legend of the codes for your unit. Sometimes they are located by the wire diagram on the unit its self, under the wire terminal panel.
If this helps you please rate me as high as possible. If it gets you on the track and need more help tell me what you did and what you found, post it and I'll post back asap.
Thanks for using fixya. and Good Luck.
Posted on Mar 25, 2009
SOURCE: indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Posted on May 10, 2009
  • 288 Answers
SOURCE: HI, I have a Fujitsu ASTA18lCC. Fan working but
trying to get the compressor to operate. it could be a bad capacitor and the compressore wont start or maybe the compressor is burned up
Posted on Dec 15, 2009
Testimonial: "Thanks for the advice. It turned out that we had a blackout after the AC had started playing up. The blackout seems to have sorted out the problem.Thx"
  • 10 Answers
SOURCE: I have a fujitsu asta18lcc when you turn it on
Below is an extract straight from the fujitsu service manual:
Compressor location error
The compressor speed does not synchronze with the control signal. (Including start up failure of the compressor).
> permanent stop.
[Diagnosis Point]
Check if 2-way valve or 3-way valve is left open.
Check the compressor (Winding resistance value, loose lead wire).
Refrigeration cycle defective (Refer to after mentioned "refrigerant cycle diagnosis")
Posted on Jul 15, 2010
Bravia KDL52z5100. Why is red light blinking 14 times?
Tell the readers of your posting exactly what is the problem with the tv. Audiio? Picture? Backlighting? Etc.
Dec 29, 2015 | Sony Televison & Video
Our holiday decorations are blinking. I want constant light. How do I stop the blinking?
Photo eye is getting exposed to light, so the eye thinks it's day and turns off, but then it's dark so eye turns light back on: lights blink on-off
Read following troubleshoot resources:
http://waterheatertimer.org/pdf/Photo-eye-troubleshoot.pdf
http://waterheatertimer.org/How-to-troubleshoot-timers.html#photocell
Gene
Water Heater Timers Save Money
Dec 08, 2014 | Hardware & Accessories
My wd-65735 the screen is getting harder to see each time you turn it on, and while it is turned off the timer light is blinking
With the set off the timer light should not blink constantly.
If power is disconnected and then put back it should blink for about 70 seconds and go off (this is set booting up like a computer) and then set should be able to be turned on.
If that like blinks constantly something in the microprocessor is causing it.
This set MAY have the soft reset that was used in a lot of these models:
With Mitsubishi remote turn set on and hit menu, 1, 2, 3, enter.
Mar 19, 2012 | Mitsubishi WD-65735 Television
Tv will not turn on. timer light constantly blinks
If you can get into the main menu go to load factory default and reboot, This will reload factory settings and this operation will erase all unwanted settings and load back to factory default. so you can load your own settings and take back control of your tv.
Feb 23, 2010 | Toshiba 42HL196 42 in. LCD HDTV
Blinking on/off light won't turn off
It means it's time to "decalcify" your machine. Not sure how to do that, I assume run vinegar or something like that through it. You can turn the blinking light off by holding down the "set clock" and the "set timer" buttons at the same time.
Oct 23, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
Blinking Green Timer Light
I suspect the lamp area is VERY dirty as is the cabinet's filters and fans. This causes great stress on your tv and lamp. Take the time to clean all of them fully. Is the unit in a dirty area? or in a high temp area? DLP's dont like high temp or contaminated areas as they are NOT air sealed units.
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Timer Light.
according to the book hcm4216w says ti will blink 10 times when turned on then then iluminate when on
Jul 20, 2008 | Samsung HCM4216W 42" Rear Projection...
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Sep 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
