Question about BonJour BJ11300 Wine Cooler
I was trying to figure out how to switch between presets and temperature settin on my BonJour wine cooler (looks like the BJ11300). I held the preset button in and the unit powered off and won'
I was trying to figure out how to switch between presets and temperature settin on my BonJour wine cooler (looks like the BJ11300). I held the preset button in and the unit powered off and won't power back on. What do I do?
Where is the thermostat located in Frigidaire Wine Cooler
Is there not a knob in the lower right on the inside? If not it could be a cooler with a preset temperature that is not adjustable. Check your owner's manual. Or go online and find your model number's manual. ~
Dec 06, 2016 | Furniture
Tip
Haier Thermoelectric Wine Cooler
This wine cooler hasn't held temperature for months, even though during the winter my living room gets to 58 F at night. I've had it maybe a year.
I took the back off, and 2 of the 3 heat sinks felt cool, which means the thermoelectric pack was just conducting cold out of the cabinet in 2 of 3 cases. The third one felt slightly warm, as it should. I checked that the cool ones had 12 v to them, they did, so they should have been pumping heat out.
I put bowls of ice inside the unit, and when the temperatures got down to the set points, I heard relays click, so I figured the control unit was OK.
I removed one of the TEC modules that was cold on the outside, and taped up the hole with masking tape.
I unplugged the fan from the circuit board and unscrewed that fan assembly from the heat sink.
I then clipped the leads to the TEC unit, cut away the blobs of hot melt glue, and disassembled the cooling module. I took the TEC device and hooked it back up, making sure it had voltage to it. After awhile, both sides just felt slightly warm so I knew it was bad.
Got on line and ordered 4 (to have spares) TEC1-12703 coolers. I have thermal grease. When the parts come, I will re-assemble and should be good to go.
I don't know what blows the TEC devices, they should be very robust. Maybe Haier got a bad bunch of them, I read almost all bad reviews on these wine coolers.
on Apr 03, 2010 | Haier HVTB40DPABS Wine Cooler
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
I always thought that light was bad for wine. Why is it that almost every wine cooler is look at has bright lights built inside?
The lights in a wine cooler are LED lights. These are safe forms of lighting to use as they will not raise the temperature of your wine.
Jul 31, 2012 | Furniture
I plug in the unit and nothing happens. Is there and on/off switch?
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 05, 2011 | BonJour BJ11300 Wine Cooler
Can't change the cooler's temperature? the temperature reads LL and its very cold.
LL is an error code which means that it is too cold. Surprised that it didn't freeze something. Problem is likely the thermostat ($15 - RF-7350-55) or motor control board ($50 - RF-0668-04).
Nov 21, 2009 | Haier BC112G Wine Cooler
Chamber wc902 wine cooler which wont set temp
I have the same issue especially when there is a power outage. To reset it, press the preset until "1" appears, then adjust the temperature as low as it will go by repeatedly pressing the temperature "-" button. Usually works.
Oct 08, 2009 | Tower Chambrer WC601B 7 Bottle (6+1)...
Not staying cold all of a sudden
THE PROBLEM NEEDS THE ASSISTANCE OF A TECH THER MIGHT BE A PROBLEM WITH THE GAS CHARGE OR THE COMPRESSOR NOT PUMPNG EFFICANTLY.GOODLUCK. MOHAMED
Jun 22, 2008 | Danby DWC283BLS Wine Cooler
Bonjour wine cube #53372
The Bonjour Wine Cube Is NOT a refrigerator it has no freon it circulates air to keep wine stored at proper temperature for cellar. To chill place in fridge or get something with freon.
Nov 10, 2007 | Refrigerators
BonJour BJ11300 Wine Cooler Logo
52 people viewed this question
Top BonJour Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a BonJour Refrigerator Expert? Answer questions, earn points and help others
