Where can I get troubleshooting guide for Jensen RCS 70 back up monitor and system? Or some ones T/S tips. Has power and sound works, only has vertical white line, no picture, no apparent cable or ter
Has power and sound works, only has vertical white line, no picture, no apparent cable or terminal / connection damage
techman
  • 3130 Answers
SOURCE: white screen covers desktop
Ah A simple one. simply unplug the power adaptor and take itno a repair place or radio shack and ask them to measure the output to see if theres 12 volts DC on the plug?? Good Luck
Posted on Jun 14, 2006
noone
  • 105 Answers
SOURCE: two vertical lines across screen
This is a common problem when LCDs are subjected to strong shock. Your internal circuits are damaged The panel itself may not be cracked but there is internal damage. I know of no cure or repair possible other than to replace the panel assembly.
Posted on Sep 24, 2006
Benimur
  • 6966 Answers
SOURCE: boka monitor problem
Below are images of the vertical IC of a Boka MO-15NF. The first shows its general location which is almost at the center of the board.  The second is a close-up.  Hope this be of help. Good luck and kind regards.
Posted on Oct 26, 2007
SOURCE: White screen. Faint vertical lines
Check capacitors that filter the signal from de character generator ic. Unsolder it or them if there are more than one (usually are of 220 micro and test it with an analog tester. If ok, look for the datasheet fo the IC and check if the vcc pin keeps energized when the monitor is on save mode.
Posted on Dec 16, 2007
  • 38 Answers
SOURCE: no sound coming from speakers.
Did you run the audio cable from the computer to the monitor. If not you must have that for the speakers to work. If yes can you verify computer output with another pair of speakers to narrow it down to computer or monitor. If it is the monitor built in speakers that are the problem reply and we can go through a procedure to get them working.
Posted on Jan 18, 2008
I don't have the sound disk anymore and the monitor is not producing any sound. When I try to download the driver my computer says it doesn't recognize my model VA1930wm
The monitor driver is for your computer to recognize all the resolutions your monitor can handle, there is no sound driver for the monitor to work since the monitor built-in powered speakers are jsut that, powered speakers, same as the one you buy if the monitor does not have built-in powered speaker.
You can test the monitor speaker system by feeding it with the MP3 player or any sound sources.
It may have bad power amplifiers IC. You will be better off spending money on a good set of PC powered speaker system that will provide a lot better sound quality than the quarter-size speakers in the monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 21, 2011 | ViewSonic VA1930WM LCD Monitor
My microwave started to make a loud "rotating"
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Apr 16, 2011 | Amana RCS 10D 1000 Watts Microwave Oven
MY Samsung LN40A650A LCD TV MAKES A CLICKING NOISE AND WON T COME ON. There is NO PICTURE AND NO audio.
hello,
Clicking sound but wont power up because capacitors bulm on pcb smps. read my tips here.
Good luck.
Apr 08, 2011 | Samsung Televison & Video
No sound on my Samsung SyncMaster 930MP All drivers are updated
Lets find out first if it is the monitor amplifiers problem or PC sound card problem.
Try feeding the monitor with sound source such as MP3 player to see if you can get the sound or not, the sound system in the monitor is nothing more than Powered PC speakers mounted inside the monitor, no driver required to make the sound to work.
If it is the amp problem inside, you will be better off spending money on a good set of Powered speakers system that will have 100 times better sound quality than the monitor built-in speakers.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Dec 31, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
The computer doesn't recognize the audio system from the monitor. Which is a Nokia 449za.
The powered speakers inside the monitor operates the same way as the Powered speaker system that you can buy in the stores, it just sitting inside the monitor instead of sitting on your desk.
Try feeding the MP3 player into the audio line in of the monitor to see if you can get sound, if you do, then it is not the speakers problem in the monitor but sound card problems in the PC. Post back what you find.
Dec 23, 2010 | Nokia 449Za Monitor
Have a new Hanns G HZ201 20" LCD. Audio cable is
You should feed the MP3 into the monitor audio line in to see if you can get sound, you do not have to install any sound driver for the monitor, it works the same as a set of powered PC speaker system, no driver to install.
do you get sound from the PC using powered speakers?
Dec 23, 2010 | Hannspree HannsG HH281HPB Monitor
The built-in speakers no longer work. The icons register volume changes, but there is absolutely no sound at all.
You need to feed it with another sound source such as a MP3 player to see if it works, if it does, then you PC sound card/drivers/software/setup may be the problem. If it is the monitor, then it can be the power amplifier IC which is not worth repairing, you will be better off spending money on a good set of powered PC speakers instead that will give you much better sound than the monitor's speakers.
Basic LCD monitor troubleshooting guide:
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 04, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
One of the 2ch speakers is not working. so how i could fix? email: tsigablemma@yahoo.com
First, try feeding it with an audio source such as MP3 player, if it still does not work, then you will have to troubleshoot it down to component level which I do not believe it is worth it since you will be bettter of buying a good set powered speaker PC sytem that will give you better sound anyway.
Here is the service manual for the ACER X193W.
http://elektrotanya.com/?q=showresult&megnev=Acer%20&megnev2=X193W&kategoria=monitor&kat2=schematics
It can be the power amplifirers are not getting the DC feeding it or the power amp IC is bad.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 22, 2010 | Acer X193W LCD Monitor
No power to screen
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L1919&kategoria=&kat2=all
May 19, 2010 | LG Flatron L1919S LCD Monitor
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
