Question about Health & Beauty
How do i reassemble my clippers?
Hi, yesterday i adjusted the fine trim setting on my clippers and heard something inside snap / break / come off, and saw the cutting blade had come loose. i took the comb section off to try and fix it but cannot for the life of me figure out how to put it back together properly. theres a spring that i assume somehow attaches to the blade but i have no idea how. tips, advice, suggestions all appreciated.
  •  Brian Main
    Brian Main Nov 14, 2014
    Hi Paulo Rodrigues, I want to help you with your question, but I need more information from you. What is the Make and Model please?
SOURCE: fell please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Posted on Jul 09, 2008
  • 62 Answers
SOURCE: Putting blade back on my Andis dog clipper
It sounds like you may have a bent hinge which is what the blade slides onto. Please call Andis customer service at 1-800-558-9441 to speak with a customer service rep. They can give you instructions on where to purchase a new hinge or send or clippers in for repair.
Thank you,
Posted on Jul 23, 2008
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
Posted on Jul 25, 2008
  • 448 Answers
SOURCE: Noisy wahl hair clippers
If your clippers are the magnetic type (rather than pivot or rotary) they should have a large screw on the side for adjustment (I think the screw you mentioned). The standard adjustment of the screw is to turn it in while the clipper is running until the sound of the clipper increases substantially. Then turn the screw back out, slowly, until the sound decreases again. Turn another 1/4 to 1/2 turn.
Unless something else is wrong, this should take care of the problem, along with proper oiling of the blades.
I hope this helps you.
Posted on Oct 12, 2009
  • 576 Answers
SOURCE: Proffesional Oster clippers model 274-69 seems to be frozen...
First, these are very sensitive to no lubrication. They should be lubricated every use to every few uses. Put a drop or two of light machine oil (sewing machine oil is about right) directly on the cutting blades. That may fix your problem. Also, watch the blades once you getit running and make sure the teeth totally pass each other or it will pull hair -- no fun! The travel of the moving blade is generally adjustable via a large plastic screw on the side of the clipper.
Posted on Dec 06, 2009
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers ยท 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
Blade won't snap back on
make sure the clipper is running when you try to snap the blade on.
Dec 08, 2015 | Wahl 8786451A Arco SE Pet Clipper
Andis trimmers are making loud noise when used outside US
First off all when buying a step down transformer for these clippers or any other electrical equitment make sure u read the label check cycle 50/60 ,and watt transformer need to be the same are close enough,with is hard to get on tha market,get it made custom,I'm a barber and we have a little trick open your andis clipper ,get spong cut it neatly just a bit thicker than the space between movin part and amateur (coil) insert spong between,not centre bit top bit to blade that's where knocking comin from it can cause that movin bit to break,trim spong until u get it quit but able to cut ,note blade will get hot because of wrong transformer and can damage coil
Nov 01, 2009 | Andis Styliner SLII Hair Trimmer
I just bought a wahl detailer trimmer and when I trim my beard,
Your problem is in your blade adjustment,nothing is wrong with the clipper,trust me i've adjusted thousands, set teeth so that hair can easily be feed through when clipper is on,perfect solution,wish i could draw you a picture.
Jan 16, 2009 | Andis Outliner II Hair Trimmer
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Thank you,
Jun 17, 2008 | Andis 29745 Clipper Headliner Hair Trimmer
Health & Beauty Logo
236 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
