What does three chime signal mean just before shut down
    Sergeant:
    Champion:
  • 226 Answers
Make and model would help please.
Posted on Nov 14, 2014
Testimonial: "Sorry, Samsung AQV09JA"
  • Eugene Tetlow
    Eugene Tetlow Nov 26, 2014
    I'm sorry but I can't find anything to do with 3 chimes in either the user or service manual. The only thing I can think is that sometimes it will go into clean mode before it shuts down.
I want to turn off the alarm chime on 2016 1500 ram
door chime or headlight reminder chime ??? as im not in the knowing that the headlight chime can be shut off as for the door chime they can be tuned down by simply adding a few pieces of thick tape overtop of chime under dash (I know there loud)
Dec 16, 2016 | Dodge Ram 1500 Cars & Trucks
Startup chime on my mac powerbook g4 stopped working. please help !
The parameter ram reset will reset that and other basics back to factory without losing any data. To do this, take a moment and find the command, option, p and r keys and figure out how you are going to hold them ALL down at together. The mac should be off, if not, shut it down (not restart-shutdown). Now, touch the power button and immediately hold down the cmd-option-p-r keys. Hold them for the screen to cycle black to gray THREE times (each taking about 15 seconds), then let go and let the mac complete the boot cycle. On the second cycle, you should have already heard the "chime" appear. That's it! Good Luck.
Dec 12, 2014 | Apple Powerbook G4 15" 1.5GHz SuperDrive...
2007 HHR Radio and chimes not working
Check the radio fuse. As unusual as it seems, GM has started having the radio (even though not turned on) generate the chimes and turn signal sounds. If the radio fails, all the chimes fail too.
This applies to other vehicles besides the HHR. My 2003 Silverado had the door chimes fade down so I could barely hear them. The fix was to replace the radio (under warranty, fortunately...).
Mar 10, 2010 | 2007 Chevrolet Tahoe
NEED TO KNOW HOW TO PROGRAM A REMOTE PAD FOR A MAZDA 626 EX 1995 PLEASE I REPLACED THE BATTERIES AND EVER SINCE THEN THE REMOTE DONT WORK
1. Remove key from ignition.
2. Close all doors.
3. Open driver side door and leave open.
4. Insert key in ignition, Turn key to ON (as far as you can go without starting the engine) and OFF, Remove Key.
5. Repeat step 4 two more times, making sure you remove key each time.
6. Close and then open the driver’s door three times.
7. Buzz sound or chime should be heard at this point signaling that the vehicle is now in programming mode. If not,
wait 40 seconds and return to step 1.
8. All transmitters need to be programmed at this time, including the old ones. Push any button on a transmitter two
times. A buzz sound to chime should be heard at this point signaling that the vehicle has accepted the new
transmitter code. Repeat for next transmitter, up to a total of three remotes (including any old remotes).
9. After all remotes are programmed, wait 15 seconds or until you hear four chimes signaling successful
programming.
Good luck and this should work.
Dec 09, 2009 | 1995 Mazda 626
Startup switch on PB G4 17 not getting apple sound, takes numerous times to boot up. Using Tiger OS, upgraded to latest. Works fine, otherwise.
If a Mac is shut down while the volume is set to zero, the standard Apple startup chime will not sound, so it is impossible to say whether or not this symptom indicates a problem.
For a startup issue such as this, I would recommend zapping the PRAM and resetting Open Firmware.
To zap the PRAM, start with a powered-down machine, press the power button, then immediately hold down the four keys: command, option, P, R. After ten seconds or so, you should hear the optical drive reset, and then the startup chime (because the volume is reset to full by this procedure). Ten more seconds, another reset, another chime. After the second time you hear the chime, release the keys.
Shut the machine down again (if it doesn't start up successfully, hold the power button until the power goes off). Press the power button, then immediately hold down the four keys command, option, O, F. You will see some tech-speak on the screen, then it will wait for input. Enter the following three lines, pressing the "return" key at the end of each:
reset-nvram set-defaults reset-all
After the last line, your Mac will reboot itself. It should now boot much more reliably. If it doesn't, chances increase that you have a hardware problem. You may want to run the Apple Hardware Test from the DVDs that came with the PowerBook to check your memory and logic board. Failing this, you are in for a trip to the shop.
Oct 05, 2009 | Apple PowerBook G4 Mac Notebook
The turn signal click is not loud enough.
Do what I did: go to Radio Shack and get a 12-volt chime (80dB Chime
Model: 273-071), about $10.00. Then do what the person quoted below did. You'll NEVER forget that your signal was left on. ALSO: if the sound is too loud for you, tape a few thicknesses of paper towel around it to reduce the sound level.
[3 of 3 customers found this review helpful]
A GREAT little device By Karlbadge_vr_en_us.gif from Athens, Alabama on 7/19/2007 Pros: A safety device, Consistent Performance, Durable, Easy To Configure, Versatile Best Uses: In The Car Describe Yourself: Tech Savvy Primary use: Personal Bottom Line: Yes, I would recommend this to a friend Comments about RadioShack 80dB Chime:
These are GREAT devices. For years I have used them on my cars, trucks, and motorhome. My turn signals are not equipped with a sounder, so very frequently I forget they are still on when I make shallow turns such as getting onto the Interstate or passing another vehicle. These little chimes remind me to turn off the signals.
They are so easy to install. Just strip about an inch and a half of insulation from each of the three wires. Twist the blue and black wires together. Find your turn signal flasher under your dashboard. (Listen for the clicking when you turn on the signals.) Pull the "flasher" out of its socket. You should see two prongs. Wrap the blue/black wires around one prong and the red wire around the other. Plug the flasher back in and turn on the signal. (Don't forget to turn on the ignition first.) If the chime works, just attach it to anything under the dash. If it doesn't, just reverse the leads on the flasher prongs.
I have NEVER worn out one of these chimes. Of course, I am using them at their prescribed voltage of about 12 VDC.
Jul 04, 2009 | 2008 Toyota Sienna
HOW DO YOU DISABLE THE SEAT BELT CHIME ON A 1997 MERCUTY SABLE WA
Q: Are you wearing your seat belt? Yes? No?
A: No.
Solution: Put on your seat belt!!!!!! Save a life!!!
A: Yes.
Soultion: There has to be a fuse either under the dash or under the hood that controlls the chime.
There is a switch in the seatbelt connecter that controlls the chime. It has either failed or the wireing that carried the signal to shut the chime off has been damaged.
Apr 21, 2009 | 1997 Mercury Sable
G5 has insomnia won't stay in the sleep mode
Usually this is caused by a USB printer unnecessarily clamoring for attention.
Disconnect ALL your USB devices and the problem ought to go away. Then connect them one by one to find out which the culprit is.
To zap PRAM, shut down the Mac, then push the start button and immediately hold down Command-Option-P-R until you hear the chimes pass by three times. But I don't think this will affect your problem.
Apr 15, 2009 | Apple iMac G5 Desktop
Thermador oven timer doesn't repeatedly chime for 5 minutes anymo
I just fixed my timer! Press and hold the OFF button for 10 seconds (until you hear 1 chime). Thanks to David at Bosch/Thermador!
Nov 17, 2008 | Thermador SC302T Electric Double Oven
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
