Solution one: Press and quickly release the Power button
Follow these steps to turn on the product correctly.
Remove any memory cards or USB drives from the HP product.
Press, and then quickly release the Power button (
) to start a Power On/Off cycle. Do not hold down the button
Figure 1: Press and quickly release the Power button
Illustration of pressing and releasing the power button
If you press and hold the Power button too long, the product might turn
on and then turn off without restarting. The product might also appear
to be turned off in Powersave mode. In either case, press, and then
) to turn on the product.
Solution two: Check the electrical connections and outlet
Follow these steps to make sure that all the power systems work correctly.
Unplug the power cord from the electrical outlet, or the power strip or surge suppressor.
Power module
Power cord
Illustration: Power module
Illustration: Power cord
NOTE:
The power cord detaches from the power module. The term power supply
refers to both the power module and the power cord.
Carefully inspect the power supply for visible damage.
If the power cord or power module shows any damage, contact HP to replace the power supply.
Disconnect the power supply from the back of the product.
Wait at least 30 seconds, and then plug the disconnected power supply
into an electrical outlet. Do not use a power strip or surge suppressor.
If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
Reconnect the power supply to the product.
Press and quickly release the Power button (
If the product still does not turn on, connect the product to an electrical outlet in another room, and then
quickly press and release the Power button (
If the product turns on
, the electrical outlet in the original room caused the issue.
, continue with the next solution.
Solution three: Make sure that other devices are not causing the issue
Follow these steps to make sure that devices plugged into the HP product are not causing the problem
If
the parallel and universal serial bus (USB) ports of the HP product
have other devices plugged into them, unplug those devices.
Press the Power button (
) to turn on the HP product.
Monitor the HP product to see if it turns off again.
If these steps resolved the issue
, there is no need to continue troubleshooting.
If the issue persists
, see the next step.
Solution four: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Please clarify your laptop model, and what exactly the problem you are facing is.
