Question about General Electric G.E. Arc Fault Breaker
My BSA A65 engine dies when I turn o0n the headlamp switch. Now the bike won't start and I have no lights working?
Battery is charged and I have tried another battery.
  • 5,316 Answers
Sounds as if you have a short circuit in the headlamp circuit. While this could be anywhere, most likely a pinched wire somewhere you have removed and reinstalled some part. The seat? Replaced headlamp bulb? As to no longer starting, you may have blown a fuse due to the short.
Posted on Nov 14, 2014
I started my BSA A65 Thunderbolt last week and it fired up as usual first kick. However, when I put the headlight switch to on, the engine died and I could not restart the bike. Although the ignition
alternator is not working so it is running off the battery but the battery is not strong enough to run it and power the lights. disconnected wire to the alt or bad one
Nov 21, 2014 | Motorcycles
Turns over but indignation button won't fire
possibly you have water in the electrical, let it dry and retry.
Jun 06, 2013 | Triumph Motorcycles
Bike won't start after it died while riding
you CDI unit may have burned out or there's oil at the piston or there oil in the carborator
May 13, 2013 | 1984 Honda VF 500 F
When riding in 5th gear starting losing cylinders. and bike dies? then bike won't start electrical start. can' roll bump start bike if i let sit for an hour. thn bike dies quickly. is my m
More likely to be your ignition coils. They heat up and expand this can cause an open circuit which will close up again when it has cooled down. Although, a bad charging system may cause this problem. Check the battery voltage with engine switched off ( approx 12 volts) and with the engine running (approx 14 volts) If you are getting 14 volts then your battery is dead, if you aren't, then your charging system has a fault.
May 06, 2012 | Honda CB 750 Motorcycles
I have an '08 Lance GS-R. Because I live in CA, it was shipped with the Front Lights Switch present but disconnected. This causes the headlamps to be on constantly when the key is in the ON position [but...
you can always wire in a seperate switch,relay and fuse for the headlamp -- this will allow you to switch on and off the light when you choose. but I will have to say that a brand new battery and a check to see if your DC generator is putting out the correct voltage to charge the battery might be something to look into before installing the switch idea. --- the battery should be good enough when fully charged to start the bike everytime. ( check the battery ).
c...
Dec 31, 2010 | 2005 Honda Silverwing 400
General Electric G.E. Arc Fault Breaker Logo
62 people viewed this question
Top General Electric Electrical Supplies Experts
hpgwva
Rob Bridges
Level 1 Expert
ken skalski
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
