Question about Samsung SyncMaster S23A350H
Update the firmware for a samsung syncmaster monitor model sa350
My monitor does not accept signals from the computer. Does the firmware in the monitor have to be corrected? If so, how do I do it.
    Champion:
    New Friend:
  • 210 Answers
You should only have to install the drivers for it to work. Have you tried Samsung's website?
Posted on Nov 19, 2014
bluegreenash
  • 661 Answers
SOURCE: Cannot find VESA holes...Samsung Syncmaster 970p
I have looked at the specification for this, and although it does show as being VESA compatible (This is a display standard) There is no mention of any "wall mounting" capabilities at all, which would lead me to believe that this is not designed to be put on a mount. also the "Magic Rotation" Technology which is part of this device may rely on it using the proprietory stand, it may well be possible to remove the stand however, but it would require some significant dissasembly as the power connector is on the signal box, and this would need to be seperated from the stand itself. The mounting bolts look to be hidden behind the round pivot cover on the back, and it may be possible to see if mounting is possible simply by removing this, however I would seek information from the manufacturer about this as removing any of the covers would most likely invalidate your warranty, it is possible that this was missold to you and you should be able to take it back as not being fit for purpose.
Posted on Sep 15, 2007
vanbiaka
  • 104 Answers
SOURCE: i want defalt settings of samsung syncmaster 793s
The default resulution is 1024 x 768, you can keep the Screen Refresh list at 75 Mhz
If you have been at "Out of Range" then you need to reboot and press F8 before windows load up, then choose VGA Mode. When windows finished loading you can fix the resolution again as you like. Hope this fix your problem
Best Regard!
Posted on Dec 03, 2008
  • 36 Answers
SOURCE: samsung syncmaster 740N 17 inch no display
manual and drivers
http://www.samsung.com/it/function/search/resultList.do?searchWord=913v&ct=0&sort=0
Posted on Apr 14, 2009
SOURCE: Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Posted on Oct 28, 2009
Does my Android Arise have MHL compatibility? Trying to connect to a Samsung SyncMaster SA350 monitor
You can use this converter
http://www.tokosigma.com/?1136,en_mhl-micro-usb-to-vga-f-with-audio-cable-adapter
Mar 18, 2016 | Samsung Computers & Internet
Samsung syncmaster sa350 start computer up then in the top left corner it shows a graphic that says hdmi, then the computer screen goes blank and the power button just blinks red continueously with a blank...
Is your computer connected via the HDMI cable? If not pull up menu and change to another input type. If it is HDMI, check cable ends. You can test by plugging into a Blue ray player and see if video plays on monitor as a test method to verify video coming from computer incase your video card has died for some reason..
Your monitor is going into sleep mode since it can not see an HDMI signal coming across the input. Check your cable though.. sounds like the biggest culprit to me.
Jan 29, 2014 | Smart Modular SV3170A
Samsung t260hd firmware
Go to menu of screen look for defrag or degause press once should sort it self out, if not onboard power supply is faulty of screen take to computer repair shop.
Dec 30, 2013 | Samsung SyncMaster T260HD flat panel TFT...
Samsung Syncmaster SA350
go to the website and download sync master
May 06, 2013 | Computers & Internet
SAMSUNG LED Syncmaster sa300 monitor no response
Oh dear, thats common problem happenned on sa300 series ,
if you luck it can be fixed by update your monitor firmware , other final worst possibility is you must change it bios chip and or eeprom chip.
Aug 16, 2012 | Computers & Internet
Samsung syncmaster sa350 black screen
Download the firmware update
http://www.samsung.com/us/support/owners/product/LS23A350HS/ZA
Screen will turn off when complete. Just turn back on and voila! You're back in business :-).
Jun 15, 2012 | Computers & Internet
NO SOUND ON MY SAMSUNG SA 350
The Samsung SyncMaster SA350 does not have speakers so you will not get sound on hdmi input.
May 23, 2012 | Computers & Internet
Samsung syncmaster 23'' wide led SA550
Update the firmware for the monitor from the Samsung website.
Jan 20, 2012 | Samsung Computers & Internet
Screen is black
if it's new then get it replaced...
else u need to get it fixed from a tech shop....one of the bwlow is @ fault....
1 the LCD screen is gone,
2 the backlite (a small tubelite) is gone
3 the invertor board(a small PCB) behind is gone
May 08, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Smeared image
Try removing signal cable and refitting at both ends.
Signal cable also could be faulty.
Samir
Aug 06, 2008 | Samsung SyncMaster 731B 17" LCD Monitor
Samsung SyncMaster S23A350H Logo
527 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
