My Fedders heat and air unit has stopped heating does it have heat strips what to do to fix it
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Either give more information such as type of unit model # or call a tech .
Posted on Nov 30, 2014
5 Suggested Answers
  • 10 Answers
SOURCE: electric heat strip installation and wiring
Need to make sure your wire size to the inside unit is large enough to handle the amperage, that you have a two stage heat thermostat.
Posted on Jan 04, 2008
SOURCE: heat strip installation
It was quite simple, just installing the heat strip and my model only required removing the grill cover and mounting the element. The other optional installations didn't apply to my model.
thanks,
Don
Posted on May 27, 2008
hemantraj
  • 638 Answers
SOURCE: Fedders Air conditioner
e5 is comp overload code . if you have infared remote for indoor units point at anyone while pushing all 3 buttons at the same time- 'mode' 'temp up' temp down' this will bring up OO where temp set point is normally displayed. scroll up or down with temp up or down buttons (1st digit only) untill you here the beeping sound change tone, this is the 1st part of the fault code. press mode once to change to 2nd digit, scroll again with up and down listening for change of beep- 2nd part of code ie "E5". press mode again will bring up afunny looking T-test mode. press mode again to exit. THATS VERY ACCURATE SOLUTION.SAVE IT FOR FUTURE.WISH U SUCCESS .REPLY FOR FURTHER ASSISTANCE IF REQUIRED.BYE
Posted on Jun 07, 2008
BIKER T
  • 909 Answers
SOURCE: Mitsubishi MSH 18NV no heating or cooling
The fact that nothing is coming on indicates that there is possibly a problem with your incomming power supply or wiring to and from the inside evaporator to the outside condenser. If all in good order, suggest you find someone you know who can operate a multimeter and check if there is voltage going to the control board inside the evaporator unit. If there is then almost certainly the control board would need replacement.
Posted on Aug 01, 2012
The Fedders window unit A/C is making chirpy bird noises when it is first turned on for about 20 min. or so. What is the cause?
Usually a dry bearing somewhere. You need to fix it. If it is in the compressor rather than the fan, it is probably uneconomical to repair. It is better if the chirping STOPS after 20 minutes rather than STARTING after 20 minutes. Heat and use is fixing the problem for you.
May 18, 2015 | Fedders Heating & Cooling
I have a fedders window unit 220v 18000btu. The ac side works great but when swapped to heat it just blows cool no heat. The filter light starts flashing as well in heat mode
Those window units usually have a strip heat kit that supplies the heat. You might want to have a technician open up and check heating circuit.
Oct 31, 2014 | Heating & Cooling
How do I fix heat on unit Frigidare Model LRA12HZT2?
There are no heating strips within this unit. This unit has a heater part 5304476390 that you would need to replaced upon a diagnosis.
Dec 24, 2012 | Frigidaire FAH106N1 Wall/Window Air...
I have a FEDDERS PTAC/HP -07B/09B/12B/15B. It blows cold air only. NO HEAT!
First of all check your unit model has heater system. And then
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 04, 2011 | Fedders Heating & Cooling
I have a Goodman phk 024-1 unit that will not heat.
Basically, set unit to call for the heat strips to be energized. There should be a control that sends power to the heat strips. Usually a contactor or relay. Verify that power passes thru this device to the heat strips. Make sure that the correct voltage is being delivered to the heat strips. If correct voltage is present at the terminals of the heat strip, check the amps. If no amps, heat strip is probably broken. Don't forget that some of these units have sequencers that "Stage" the energizing of the strips. And all of them should have some safety device such as a fuse or thermal overload or some other device that stops voltage should there be a malfunction.
Hope this helps.
Feb 05, 2010 | Goodman PHKJ048-1 Air Conditioner
Fedder split unit
Your heat strip is burnt out . You will need a tech to come out and replace this heater strip due to the complexity of installation
Dave
Jan 06, 2010 | Fedders C48ACD1VF Split System Air...
Our Fedders AirHandler Model#A24C1X keep 1 strip of heat when blower or nothing is on. have to unplug the red wire from NC on blower delay relay to stop it. blower relay Bd is new
Most of the time on Fedders unit one speed for heat comes off sequencer. This a low speed for heat. You may have bad sequencer. If your knowledge is limited about furnaces you may ahve to call service tech. But if you have some knowledge Replace the sequencer and follow woring diagram and you will be ok. Should solve problem. This time of year I replace dozens of sequencers due to this same problem. Rus
Nov 11, 2009 | Heating & Cooling
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
I have a thru the wall fedders ac unit. The heat stopped working when you turn it on it just hums.
no blower !!! or heating element is bad or switch try putting the fan on only if it works than it is probaly the switch not letting the blower on only heat
Apr 01, 2009 | Fedders Y Chassis AEY12F7E Air Conditioner
Heat doesn't work on ac unit
u have to be more specific. is it gas or electric. If electric check breaker first. Gas check thermocouple
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
