Question about Symbol LS2208 Handheld
Wher can i found Simple COM Port Emulation USB driver version 1.8.6
I cannot find anywhere thsi driver for windows 7
  • Efstratios Chatzianagnostou
    My scanner has old firmware and i can not update it to be able to work with windows 7 or CDC mode. That is why i ask this driver to see if it works on windows 7 , otherwise i has to through away these scanners. Motorola LS7808
    Hello Hadewaley. Can you give me more instructions about the ID. I must go to "Device ..Hardware ID" and then what to do?
    Thks anyway
    Problem Solver:
  • 9 Answers
Have your tried the driver provided at
www.driverscape.com/download/symbol-usb-com-port-emulation
It says tis 2.33mb. Even if it turned out to be a driverscanner, simply install and wen it find the driver you are looking, use the ID to search for it on google and if it can installed directly.
Good luck
Posted on Jan 01, 2015
Wher i can download USB driver for LG-E900 FOR FREE?
Sep 17, 2011 | Health & Beauty
My problem is i am connecting the intermec pc4 on the laptop windiows 7 and it does not have a pararell cabel in the laptop i am trying to make the mashine recognize the serial and usb port
Read these instructions. You will need to buy a usb printer cable and follow these directions below. Good luck!
We at our laboratory have about 35 Intermec printers and after much trial and error they work well for us. They practically never break. I have also called their tech support and they were very helpful. They advice was FREE. (I promise I do not work for them)
Intermec Install Notes: (from Intermec)
How do I install the USB driver for my EasyCoder PC4 (PC4B or PC4C) printer?
Answer
Tools Required:
1. EasyCoder PC4 (PC4B or PC4C) printer.
2. Microsoft Windows compatible PC. (XP/2000 recommended, Vista NOT supported ( Note from Dole: it works with Windows 7 and probably Vista and Windows 8)
3. USB Cable.
4. Available USB port on your PC.
5. Latest version of the USB drivers (2.0 or better) which can be downloaded from http://home.intermec.com/eprise/main/GSS/Service/Content/Downloads/Show_DownloadSearchResults?Product=PRTRPC4C
Note: There are two parts to installing the USB driver. You will go through the Found New Hardware wizard two times. The first part is installing USB port and the second part is installing the USB to Serial port.
1. Download and unzip the USB drivers to a location on your PC.
2. With the printer turned off plug in one end of the USB cable to USB port on the printer and the other end in to an available USB port on your PC.
3. Turn the printer On.
4. Now you will get prompted with the "Found New Hardware" dialog box. Select "Install from list or specific location" and click Next.
5. Click Browse and select the location where you unzipped the files in step 1 and click OK.
6. Click Next. The USB driver will now install.
7. Now you will get another "Found New Hardware" dialog box for the USB Serial port. Select "Install from list or specific location" and click Next.
8. Click Browse and select the location where you unzipped the files in step #1 and click OK.
9. Click Next. The USB Serial driver will now install.
10. Now reboot your PC. The newly installed port may not show available until you reboot your PC one time.
The USB port is now successfully installed. In Windows the USB port will be assigned to a Com port. To find out what Com port number is assigned to it go to Device Manager and then Select Ports. You will see USB Serial Port (COMx). In addition, when using the Intermec InterDriver Windows print driver. The USB port will be shown as USB00x and the Description will be Virtual printer port for USB.
(You may need to set the printer as the default printer)
Other things to know about these printers: ( not from Intermec )
1) There are 2 types Direct and Thermal transfer. Direct I think heats up the label to get the writing on the ribbon. Thermal transfer uses a one time use ribbon to transfer images to the label.
2) You should use Intermec labels, if you otherwise the labels will probably not print properly
3) How to reset the printer. Turn off the printer, (in the back) then turn on the printer while holding down the Reset button on the top. Release the reset button when the light turns green then wait for the printing to stop. IMPORTANT: Next press the reset button for 1/2 second. If you hold it too long it will not reset the printer properly.
4) Every user will need to set the default label size.
5) If the print is coming out is hard to read do the following. Open the printer then remove the ribbon if there is one and scrape the metal with your fingernail. They give you alcohol and a cotton pad but your fingernail will work fine.
6) Another problem we have sometime is a label falls off and covers a sensor so the labels do not know when to stop. This hardly ever happens but look under the labels and check the sensor.
Feb 18, 2011 | Intermec EasyCoder PC4 Label Printer
I have a suunto pc pod. my suunto t3d watch can connect to the pod but the pod cannot connect to the software installed (training manager lite) since my pc cannot find any drivers to install for the...
I found out that this is because the wrong drivers are installed.
When you install the suunto software the usb drivers are stored under C:\Program Files\Suunto\USBDriver. This contains more than one driverset. See if you can find this.
Then go to Control Panel\Hardware and Sound\Devices and Printers and find your Suunto device. You probably have only one device and will miss Suunto Usb Serial Port.
Now open the deve and change the drivers, via manually select . Select browse and go to C:\Program Files\Suunto\USBDriver. Press Enter. The program will see that there is more than one driver set and offers you a choice.
Previously it has automatically selected the newest one, which unfortunately did not work in my case. Select the oldest set and the program will install the drivers,
Now you will see in Control Panel\Hardware and Sound\Devices that you have 2 devices suunto pc pod and suunto usb serial port. And the program will run and be able to connect to the watch
Good luck
Timco
Oct 02, 2010 | Suunto Pc Pod Wireless Transmitter
OVT Scanner won't run with Windows 7. Vupoint
We suffered this initially on a new laptop with Windows 7. I can't tell if the driver on the Vupoint website has been updated, or is the old XP/Vista driver, but we installed this (1/2011). In Picasa or the Photoimpressions software which comes with the scanner, we were then only able to acquire solid black images. However, when we tried all of the USB ports on the computer, we found that one of them (a USB2 rather than USB1 port) was able to function like normal. We suspect there is a funny issue with the amount of power going to the scanner from different USB ports, and maybe this interacts with the driver in some way.
Jul 07, 2010 | Office Equipment & Supplies
We have recently purchased an Intel I7 processor and installed it into the ASUS P6T motherboard. We have also installed Windows 7 OEM builders operating system (not an upgrade version over windows XT). The...
Run "Windows Update", to see if it will find updated device-drivers for the specific USB hardware on the motherboard.
Access the ASUS web-site, and search for 'P6T', and search for USB device-drivers for Windows 7 -- if none are found, try the device-drivers for Windows Vista.
Jan 22, 2010 | ASUS P6T7 WS Supercomputer Core i7 / Intel...
While trying to print from a microsoft works spreadsheet...it always says "out of memory" and prints a distorted page.
Hi
here are some ways to override the problem
When you try to print
it says
Microsoft Works Out of Memory
This problem may occur if there is a problem with the printer driver that is installed on your computer.
  • Method 1: Install a different printer driver
    Contact the manufacturer of your printer to inquire about how to obtain and install the most recent version of the printer driver for your printer.
  • Method 2: Configure the printer as the default printer
    Configure the printer driver that you have installed as the default printer. To do this, follow these steps:
    1. Click Start, and then click Printer and Faxes.
    2. Right-click the printer that you want to set as the default printer, and then click Set as Default Printer.
    3. Click File, and then click Close.
    4. Start Works, and then print the spreadsheet or the database file.
  • Method 3: Install an emulation printer driver
    If the problem persists after you install the most recent version of the printer driver for your printer, install an emulation printer driver. An emulation printer driver is a driver that imitates the functionality of a different printer driver. For example, you may be able to resolve this issue if you install the driver for the Hewlett-Packard DeskJet 550C printer or for the Hewlett-Packard LaserJet II printer. To do this, follow these steps if the printer is connected directly to the computer:
    1. Click Start, and then click Printers and Faxes.
    2. Double-click Add Printer.
    3. Click Next, and then click Local printer attached to this computer.
    4. In the Use the following port box, select the port that you want to use.
    If the printer is connected directly to the computer, the port is typically LPT1 (Recommended Printer Port).
    5. Under Manufacturer, click the manufacturer of the printer driver that you want to use as the emulation driver. For example, if you are installing Hewlett Packard 550c, click HP DeskJet 550c.
    6. Under Printers, click the model of the printer that you want to use as the emulation driver, and then click Next. Select HP. In Drivers, select HP DeskJet 550c.
    7. In the Printer name box, type a name for the printer, click Yes to set the printer as the default printer, and then click Next.
    8. Click the appropriate option for sharing the printer, and then click Next.
    9. Click No, and then click Next.
    10. Click Finish.
    Note If you are using a USB printer, go to step 12.
    11. Start Works, and then try to print the spreadsheet or the database file.
    12. Open Control Panel.
    13. Open Printers and Faxes.
    14. Right-click HP 550c, and then click Properties.
    15. Click Ports.
    16. Click USB001 Virtual Printer port for USB.
    17. Click Apply, and then click OK.
    18. Start Works, and then try to print the spreadsheet or the database file.
Hope this will solve your problem
Jan 02, 2010 | HP Photosmart C5180 All-In-One InkJet...
Scanner symbol ls3070-i100US
These are the only drivers i could find that fit your description. Hope it helps.
Simple COM Port Emulation USB driver version 1.8.5
1.8.5 DRIVER Simple COM Port Emulation is one of the USB (Universal Serial Bus) interface modes supported by Symbol scanner devices. In this mode, a Symbol scanner...
123Scan Scanner Configuration Utility v2.7
2.7 UTILITY SOFTWARE 123Scan is an easy-to-use PC based application that will help you program your Symbol Technologies bar code scanning products. Allows easy scanner...
OPOS Driver for Symbol Scanners v3.24
3.24 DRIVER The OPOS Driver for Symbol Scanners v3.24 provides the tools necessary for scanning bar codes. OPOS (OLE for Retail Point-Of-Sale) is a standard programming...
JavaPOS Driver for Symbol Scanners v1.9.1
1.9.1 DRIVER  This driver provides the Java objects necessary to connect a Symbol barcode scanner to a host system based on the Java POS specification (a part of the NRF...
Oct 06, 2008 | Computers & Internet
Foxconn Utility CD for motherboard Intel 915 series p/n: 91-185-915-MB-OM W A N T E D
Hi Witalorant,
I have searched the driver for your motherboard chipset and found one similar for the one you were looking at, i copy and paste the link here for you to download it and install it to your unit.
Click the link below and see what driver you need to download when the page loaded..
INTEL 915
Hope it helps.
Enjoy
Pls. rate & hope to hear more from you soon..
tnx
-micro
Feb 10, 2008 | Foxconn 915P7AC-8KS Motherboard
USB Driver for Starcom : Model- UT300R2U ADSL2+ Modem
Hi,This modem has only two ports - 1 Ethernet and 1 USB. I want to connect the USB Port to my PC. I am unable to get a suitable driver. Please help me in finding from which site the driver could be downloade.
Nov 27, 2007 | Computers & Internet
Symbol LS2208 Handheld Logo
683 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
