Question about Kitchen Ranges
Electric panel not working - Kitchen Ranges
  • 1,923 Answers
Check your fuses first of all not much help after that only make sure all the wiring is connected .Make sure your circuit breakers in your electrical house panel are not flipped off.
Posted on Nov 15, 2014
I need to get to the electric window wiring on the drivers side. Can I just pop up the mechanism on the door?
Yes you can, but you need a flat tool like a "V" end shaped screwdriver because this has locking prongs under the front of mechanism(windshield side).
gently lift up on electric panel on the front side(windshield) use the tool or similar(2 small flatheads will work) between panel and door push in lock clips(front toward back---under electric panel) the panel should come out of the door holder frame to access the wiring connector under it---the electric panel removal and installs from back to front and snaps in place with locking front clips to door panel.
Jan 16, 2010 | 2000 Kia Sportage
Whirlpool Gold electric range control panel not working
I live in a new 500 home subdivision. The contractor ordered all Whirlpool Gold products including Electric and Electric/Gas Ranges. Many of my neighbors' panels have gone out! I'm talking about epedemic trouble. My son has had his oven panel (separate from stovetop) fail within the first year. Thank God it was under warranty...this is not a cheap replacement (he had the sensor touch pad. I just had my oven pad fail. I tried to set the clock for Daylight Savings and found out half my panel is out! The fix is a replacement of the panel. Depending on which model (push or sensor) look to spend at least a couple of hundred bucks. We have the Whirlpool Gold microwave panel and so far so good. My neighbor and my son's both went out! They just tossed the two year old products and replaced them with another brand. Sorry to break you the news...class action anyone?
Mar 04, 2009 | Whirlpool GY396 Electric Kitchen Range
Gas oven does not work. electric upper element does work. codes
I had the same problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Dec 26, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Inglis electric freestanding range model #IRE3230- Oven no longer working
If the oven and the electric panel no longer work, this is an electronic problem. The burners and the oven light will not be effected, nor will the fuses. The electronics card will need to be replaced by an appliance technician.
Oct 24, 2008 | Kitchen Ranges
All of a sudden the driver side window will not roll up.
is it electric windows? if it has electric windows does the passenger window roll up using the switch for it on the passenger door panel? if it works on the passenger door panel and not on the driver's door panel , then your switch on the drivers door panel is bad... replace it.
Oct 13, 2008 | 1999 Oldsmobile Cutlass
1999 Rodeo Electric Windows Switch Panel - Drivers Side
gotta remove the door panels there a panel removing tool looks like a snakes tounge but bigger these pop out your door pannel
they take the panel pins out without damageing the door pannel
disconnect electric switches
the electric assembly in side is rivited in so is your going to remove gears you need to drill out revits then work it out of door panel
May 28, 2008 | 1999 Isuzu Rodeo
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
