Question about Lands Phones
Is it possible to use a splitter, we have maxed out the system.
  • 2,321 Answers
I use splitters on our phone lines as I have only a main line in the house but my computer and three phone systems are all on the one line. Have no trouble up to now. I added a splitter under my house as well to service an answering machine.
Posted on Nov 15, 2014
How do I cable this connection please?
It depends what input connection the second TV has available. You cannot directly daisy chain HDMI cable from Apple TV to the two TVs assuming both have HDMI input. But you can purchase an HDMI 1x2 splitter and connect the 3 up provided the 2nd TV also has HDMI. The challenge maybe the distance you can have between the two TVs. Max is 15 meter but you could cascade 2 units to create longer distances.
http://www.ebay.com/itm/HDMI-Splitter-Box-High-Speed-Full-HD-1X4-4-Port-Hub-Audio-Video-1080p-Amplifier-/191120909726#ht_2675wt_1337
Apr 28, 2014 | Televison & Video
Want to connect more speakers
Use splitter cables to double your outputs. The signal strength will be half to each speaker per channel. i.e. if each channel has an output of 100w then splitter cables will give you 4 x 50w to connect up. Aim to use speakers rated below the max output rating of your amp, so in this example 4 x 40w speakers would be safer (won't blow your amp) than 4 x 60w speakers
Feb 08, 2014 | Behringer EuroPower EP4000 2Channel...
XP won't boot with Startech Video Splitter
try to reinstall your Win xp and if it is the same check other system that work for there model and make they may not be compatible
Apr 18, 2012 | StarTech.com Ltd. 2-Port VGA Video...
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
The last two Aviom personal monitor mixers in our chain started acting up yesterday. A few of the channels (example: bass) are no longer controllable. Volume and panning won't work, and for those problem...
Haven't run across this installing Avioms but wondered if you had a storms with lightning lately, or some power surge possibly in your AV system.
Try unplugging the rest of the stations and only plug in the problem stations one at a time. See if you are still having problems. If so, the issue is in the individual stations. If you have a signal splitter unit ( Cat5 splitter to 8 outs on the stage side) try running out of different outputs. If that handles the problem, it may be in the splitter. The problem sounds like it is an issue with either the mixers or the splitter. By isolating the mixers and testing them one at a time you can confirm this. If that is the case contact Aviom directly for the nearest service center or send back to them. As I mentioned bad weather or a power surge could have damaged a couple of units and left others fine. This happens often.Make sure your valuable gear all have a surge suppressor on them. Good Luck
Feb 21, 2011 | Aviom Audio Players & Recorders
Why does my internet keep disconnecting when i use my house phone?
possible you need to get a new splitter, your old splitter may be damaged already, you have DSL from your phone company right? get a new splitter it should do the job for you...
Feb 21, 2011 | Gateway Computers & Internet
How can I split a 3gp movie ?
You need to use software to split the 3gp movie. It is not possible directly into the nokia phone. You can try boilsoft 3gp splitter at: http://www.boilsoft.com/videosplitter/download.html .
Jun 19, 2010 | Nokia Computers & Internet
Mac slow downloads
If you have slow downloads, you have an internet problem. Call your internet service and talk to tech. support and get them to run a diagnostics check to ensure you are receiving the fastest speed. You might find that you are running at max mps and therefore would need to up your service connectivity package.
also, if this just happened without explanation (meaning, it was working fine before), then check to make sure you don't have a splitter that hooks up your cable tv and your internet with the same cord. If you do, your splitter is probably gone bad and you need a new one.
Mar 25, 2010 | Apple iMac OS 9.1
Hooking up 3 sets of speakers to a PC
It is possible for this to work, but you are likely to damage your sound card in the process.
Mar 08, 2009 | Belkin Phone splitter (F8V109)
VGA Splitter frying video cards?
We have Extron Crosspoint switcher 300Series 128 when we switch ON the switcher it will not Powering ON can you helpme out how to solving this problem
Nov 01, 2007 | Extron Electronics Extron P/2 DA2 MT...
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
