Question about Electrical Supplies
Is a triple square socket the same as a star bit
Was watching this video on changing the clutch on my 2001 beetle and it said I needed a #8 triple square socket to remove cv axle can I just use a star bit socket or do I need to order one
    Sergeant:
  • 204 Answers
The star bit or torx bit as it is commonly known is different from the triple square socket.
here is a Wikipedia site that explains torx, if you scroll down about 1/2 way, on the hight there is a chart showing the different types of drivers & what they look like.
http://en.wikipedia.org/wiki/Torx
Posted on Nov 14, 2014
How to change water pump on 2001 olds aurora 3.5
does anyone have experience changing a water pump on a 2001 ...
https://answers.yahoo.com/question/index?qid...
Aug 13, 2008 - aurora.................good luck. if u got the "short star" (3.5 dohc v6) good luck. if u got the 4.0........even better luck. happy trails. TonWon · 8 years ...
Aurora 4.0 Exhaust Leak and Water Pump Whine - YouTube
? 0:46
https://www.youtube.com/watch?v=5mjg_Ps1Ctg
Dec 13, 2012 - Uploaded by Brendan Doyle
Aurora 4.0 Exhaust Leak and Water Pump Whine. Brendan Doyle ... How to Install a Waterpump on a Cadillac Northstar engine. ...How to access spark plugs on a 2001 Oldsmobile Aurora 3.5L Engine - Duration: 3:19. Dennis ...
Oldsmobile Workshop Manuals > Aurora V6-214 3.5L VIN H ...
workshop-manuals.com/oldsmobile/aurora/...3.5l.../water_pump/.../page...
Oldsmobile Workshop Manuals > Engine, Cooling and Exhaust > Cooling System ...Aurora V6-214 3.5L VIN H SFI (2001) ... Install the new water pump gasket.
How to change water pump on 2001 olds aurora 3.5 - Fixya
www.fixya.com/.../t16902718-change_water_pump_2001_olds_aurora_...
Mar 4, 2013 - 4.0? It's not that hard to replace but you need a special socket to changeit ... The starter motor sits in the "valley" between the two bank of cylinders ...
Mar 04, 2013 | 2001 Oldsmobile Aurora
I'am trying to change my front pads on my 92 taurus. but i could not figure out how to get the caliper off to put the new pads on. could you tell me what to do?
You need a socket with an allen/hex bit. Not sure about the size of the hex bit you will have to figure that out yourself. There are 2 scews holding the on calipers.
Heres what they look like:
http://www.autozone.com/autozone/parts/Motormite-Brake-Caliper-Bolt-Guide-Pin/1992-Ford-Taurus/_/N-ix2afZ8knjf?counter=2&itemIdentifier=102943_172605_15907_
They are on the back of the caliper toward the engine, find the proper size hex socket. They sale a set of the sockets at Autozone for around $10, 3/8 inch drive. Thats the best way to go.
Heres what you need:
http://www.autozone.com/autozone/accessories/Duralast-5-pcs-3-8-in-S-2-square-drive-hex-bit-set/_/N-25f3?counter=0&filterByKeyWord=hex+bit&fromString=search&itemIdentifier=947316_0_0_
Sep 18, 2011 | 1992 Ford Taurus
How do i get the rear rotors off a 2006 Jetta (2.5)? I've got the brake assembly off but the other/larger assemble wont budge. It seems to need to have two torx nuts removed but I've tried a T55 and its to...
Rear Brake Pads & Brake Rotor Replacement Volkswagen Jetta 2005 ...
2q==? 8:57 https://www.youtube.com/watch?v=31m24XZj79c
  1. Similar
Nov 11, 2014 - Uploaded by 2CarPros In this video we show how to replace the rear brake pads and rotor on a 2005-2010 Volkswagen Jetta ...
how to change rear brakes and rotors on a 2006 vw jetta value edition ...
2q==? 16:56 https://www.youtube.com/watch?v=KRn3npN6FMw Sep 11, 2017 - Uploaded by Adventures In Living link to pads: http://amzn.to/2jj8vcq link to rotors: http://amzn.to/2wWKpJe.
2006 VW Jetta rear brakes - YouTube
z? 4:10 https://www.youtube.com/watch?v=S0cdLClKA2c May 25, 2016 - Uploaded by Austin Brandt Quick way to get your rear brakes done without buying specialty brake tools. ... Replacing Rear Brakes on ...
MK5 Rear Rotors and Pads Removal and Install - YouTube
2q==? 32:33 https://www.youtube.com/watch?v=AvhufC_ctGo Jun 20, 2016 - Uploaded by scirockalot8v Tools and supplies: M14 Triple Square (12 point) 15mm and 13mm wrench/sockets Flathead Screwdriver Torx ... 2006 Jetta remove rear rotors Google Search
Dec 07, 2017 | 2006 Volkswagen Jetta
What do you use to remove the 6 bolis that secure the front axel to the transmission/
It is a special type bit. It is called a triple square socket. or spline drive socket.
Oct 12, 2010 | Volkswagen Jetta Cars & Trucks
Is there a heater illum bulb in a 2001 VW Beatle
Set the fan speed switch to position #2. Grab the fan speed knob and pull it straight off. It might fight you a bit, but it will come off. Once you have the knob off, lookinside the control unit and you will see the bulb. I have seen these just fall out of the socket on their own.
Dec 31, 2009 | 2001 Volkswagen Beetle
Rpms speed up faster then bike does. Sounds like clutch slip.
You can adjust it by slackening the cable...unless it has hydraulic operation....Otherwise get it replaced before you do more damage..ie clutch dust and debris in the oil, so dont forget the oil and filter change too.
Jul 22, 2009 | 2001 Yamaha V Star 1100 Classic
Interment A/C clutch operation
Thats what it soulds like to me. The low pressure switch is what controls the clutch. Check to ensure you are topped off with refrigerant. If it is, get the low pressure switch replaced.
Jun 02, 2009 | 2001 Volkswagen Beetle
Head bolt socket type
It is a "triple square XZN" spline tool.  Put any of that into ebay or google and you can find it, or else flag down a tool truck (snap-on, Mac) and ask the saleman for one.
Jan 18, 2009 | 2000 Volkswagen Beetle
Electrical Supplies Logo
1,087 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
