Question about Nova Development Food Network Recipe Manager
I AM ON A FEEDING TUBE...DO YOU HAVE SPECIFIC RECIPES FOR ME
CAN YOU PLEASE SUPPLY ME WITH NUTRITIOIOUS RECIPES...FOR A FEEDING TUBE...I HAVE BULBAR A.L.S. AND WOULD LIKE TO MAKE MY OWN NUTRITIOUS FORMULA USING ALL HEALTHY INGREDIENTS.
I misplace the recepie booklet for the 5400 Digital Icecream Maker. Would you be so kind to send it to me by mail? Lorenzo Sforza
You are just down the road from me in Mississauga, but I had to do my moderator duty and delete your address. It is too risky on an open forum.
I happen to be a trade chef :>) All ice cream recipes are pretty much alike, so they don't have to be model specific. It is a 1.5 quart, 3 pint machine.
Here are Hamilton Beach Recipes
https://www.hamiltonbeach.com/ice-cream-makers-recipes.html
more here
http://www.myrecipes.com/ice-cream-maker-recipes
and here
http://allrecipes.com/recipes/1556/desserts/frozen-desserts/ice-cream/
Ice Cream Recipes
Apr 23, 2016 | Ice Cream Makers
The tube feeding the ice making machine is iced up? What is the solution?
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jun 04, 2010 | Whirlpool Freezers
Water is freezing in the tube feeding into the ice maker. What could be the cause?
Generally the cause is a defective water valve that feeds the icemaker.
The water valve is allowing a small amount of water to leak past the seat. The water then slowly drips down the icemaker fill tube and freezes in the tube causing a blockage of ice to fill the diameter of the fill tube.
Replace the water valve.
Clean or replace the water supply valve that supplies the house water to the water valve on the ref.
This will ensure trouble free ice maker operation.
Jan 16, 2010 | Refrigerators
Sterling shower faucet
The problem is that the supply lines feeding that faucet are reversed. That is the cold supply line is feeding the hot side of the faucet and the hot supply line is feeding the cold side.
The fix is to reverse the supply lines where ever they can be most easliy accessed.
Apr 14, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
We emptied the ice maker befor we went away ,came home no ice.We checked to make sure it was in right switch on ,red light on.what else can we do?
There should be a silver lever that needs to be completelty against the icemaker (pushed all the way down)- in most cases- Are you sure this is in the right position.
May also want to check the tube that is feeding your icemaker water and make sure it is not frozen.
If this doesnt solve your problem, please let me know the make and model of your refrigerator and i may be able to be more specific.
Apr 13, 2009 | Refrigerators
Seised wire inside feeding tube
You can replace the liner by removing the shroud tip, and pulling the spring (liner) from the machine end of the trifgger cable.
Liners are replaceable.
Dec 23, 2008 | Hobart Handler 140 Mig Welder
Samsung TXJ2567 long wait for picture
That is usually indicative of a weak picture Tube. If the set is over 8 years old, I would consider replacing it. Otherwise, a repair shop may be able to restore the picture for awhile longer.
Dec 19, 2006 | Samsung TXJ2567 TV
Nova Development Food Network Recipe Manager Logo
56 people viewed this question
Top Nova Development Computers & Internet Experts
David Payne
David Payne
Computer Links
John Hong
John Hong
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
