Question about Sport & Outdoor - Others
My flush has stuck on, how can this be sorted.?
Toilet flush on constant in motorhome?
    Problem Solver:
  • 8 Answers
Close the Inlet Water valve to the Flush Tank.
Remove the lid on top of the Tank cover.
Check the link/chord connecting the flush knob and the Flush valve.
It might be broken.
Normally the Flush Tank lever, which is outside the Tank lifts the Flush valve at the bottom of the Tank.
Posted on Nov 23, 2014
I had a toilet that was constantly flushing. I read online that is was the solenoid but I wanted to make sure.
are you sure that it is not the rubber washer at the bottom of the cistern that is not the problem
it it continually leaks into the pan then the inlet will keep running
Oct 13, 2015 | Moen Flush Valve. Sensor Operated Closet...
Motorhome toilet won,t flush
Make sure the water supply to the toilet and the pump are working properly, make sure waste tank is not full, if it still won't flush check the flushing mechanism on the toilet.
Mar 01, 2014 | Sport & Outdoor - Others
Toilet liks water to the floor
Check flush fittings. If no leaks, check the flange seal undernesath.
Nov 12, 2013 | Rv Motorhome Dual Co & Lp Gas Alarm...
I have a american standard toilet mode 4112 that keeps running.....any suggestions on how to fix it?
The flapper ball may be contaminated and not sealing or the float level has changed and needs adjustment. You should be able to see if the overflow has water flowing into it continuously.
Mar 07, 2011 | American Standard 4112 Bone Toilet Tank...
Our toilet has a much louder flush than before. Water is not constantly running. What is causing this and how can it be fixed?
Have you tried putting a pressure raducing valve before the toilet? the noise can sometimes be cursed by high pressure.
Mar 23, 2010 | Caroma 270W-RF Reflection Round Front...
Toilet wont flush completely. it may take 4 times or more to flush solids. i at first thought this was related to heavy rains we had been receiving in the area over a period of about 4 months. 2 days...
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Nov 09, 2009 | Eljer 091-2190-43 Platinum Patriot...
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
We just replaced out toilet because we had no flushing power on the old one. After cleaning the vent pipe and using a snake and putting on the new toilet, we still don't have any pressure when flushing...
its got a blocked down pipe lime scale will do this to you, the only way to sort it out is strip it out completly and give it a good clean, if that still failes to flush then its the flushing pump needing looking at,
Oct 25, 2009 | Cadet Manufacturing American Standard...
Sport & Outdoor - Others Logo
105 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
