Question about LG Office Equipment & Supplies
LG BS275 projector lamp reset
I need reset the lamp. thank for your instruction
SOURCE: Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Posted on Dec 06, 2007
SOURCE: lg llp xg22 lamp reset
These instructions are taken from page 44 of the User Guide.
Turn the power off but keep pluged in. Press the buttons on the control panel in the sequence as below.
Press "Up Arrow", Press "Down Arrow", Press "Left Arrow", Press "Right Arrow", Press "Menu", Press "Enter".
Lamp time will be initialized
Posted on Mar 01, 2008
SOURCE: Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Posted on Oct 02, 2008
SOURCE: Lamp timer on Sharp XV-Z2000 will not reset
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the  "0000H" on the bottom left of screen...that's how mine worked today.
Posted on Jan 10, 2009
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
How to reset lamp hour on lg bx327 projector
Here is a link to the manual in case yo don't have it:
http://www.projectorcentral.com/pdf/projector_manual_6082.pdf
However it doesn't include counter reset instructions that I could find!
I didn't find specific 327 instructions, but here are 3 different procedures for other units:
  • If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
  • SOURCE:Lamp timer on Sharp XV-Z2000 will not reset
    • I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the "0000H" on the bottom left of screen...that's how mine worked today.
  • If/when you get it to work, please post back via comment to original question.
Jan 08, 2015 | LG BX327 3D Projector
Lamp reset LG RD-JT40
Try to do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
Good Luck.
Jan 26, 2008 | LG RD-JT40 Multimedia Projector
How to reset lg 501b projector lamp life after replacement of new lamp
You'll need to go into your system setup screen on the projector and reset the lamp counter. It doesn't know when a bulb is changed, so it is a manual process.
Jan 19, 2014 | LG Refurbished Electronics BX501B...
How to reset lamp hours & total time toshiba projector TDP-T95
Supposedly the lamp has a chip that keeps track of the used time. The manual says to check in the instructions that came with the lamp. Others say that LG will not reveal how to do it. Perhaps you could ring LG service and give them your machine serial number and request that as the owner you want the correct information.
Apr 11, 2011 | Toshiba TLP S30 Multimedia Projector
Resetting lamp on a lg rd jt40 projector
remove bulb. replace bulb. within ten minutes press exit on projector and hold for three secs. then immediately press menu then press left or right arrow button. you are done. turn off then turn on
Jul 04, 2008 | LG RD-JT40 Multimedia Projector
Sharp xg-h400u projector Lamp timer reset.
plug the projector in. Do not turn it on.
hold the menu, enter, and down keys at the same time....
Press On
The map will turn on and the screen should display Lamp 0000H
Pg 54 of the xr-10x manual -- http://www.sharpusa.com/files/pro_man_PGMB56X_66X_XGMB50XL_XR11XCL_XR10XL_XR10SL.pdf
May 22, 2008 | Office Equipment & Supplies
Help me Please
I have just reset my lamp! Disconnect all cables but the power, switch on it will search for a source, the lamp timer message will display press exit untill it will give you a message to press menu to reset the lamp timer, it will give you a option to press left or right to reset. I used the buttons on the projector not the remote.
Jan 31, 2008 | LG RD-JT40 Multimedia Projector
Reset the bulb
1-press the exit button on the projector for 3 second to display the total used lamp time.2-press menu button on the projector during the lamp hour message- an adjustement message will be appear press right or left arrow to reset timer to zero.if success osd change to(lamp hour reset ok!)
Jan 12, 2008 | LG RD-JT91 Multimedia Projector
Lg llp xg22 lamp reset
Aug 02, 2007 | LG LP XG2 Multimedia Projector
Please show me how to reset the lamp of LG LP XG2 Multimedia Projector
You won´t find a solution in the manual. You may ask LG for technical support. Bj?rn
Nov 29, 2006 | LG LP XG2 Multimedia Projector
154 people viewed this question
Top LG Office Equipment & Supplies Experts
Jaime Hernandez
scj103
Lawrence Oravetz
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
