Question about Garden
Primer not working wright.want push in right - Garden
  • 2,042 Answers
You may need a new primer. To take the old one out take a small screw driver and work the old one out as well there is a metal ring like out fit that has to be removed as well. This holds the primer in place. Purchase the right primer for the machine and make sure the hole is cleaned out then insert the new primer as well as the metal ring and most go in with a three quarter inch socket and tap it in this a hammer but don't hit hard and it should go in all the way. Then the primer should work.
Posted on Nov 15, 2014
  • kenneth lafon Nov 15, 2014
    It's a homelite chainsaw primer want push gas in carb.It's like carb. is stoped up.
I have a problem with an Echo-SRM 310
wrong primer bulb installed have to get right one this one not letting fuel come in
Nov 10, 2012 | Echo Garden
Ryobi RY60511A tiller wont start
when the primer buld is empty, when pushed it should push bubbles into the gas tank and when let go should draw fuel from the tank. the primer buld now when pressed pushes fuel into the carb and should not push back to the tank. when let go again it will draw more fuel from the tank. the inlet nipple on the carb should be the 3 oclock
Apr 11, 2012 | Ryobi Cultivator
Primer bubble wont expand poulan wt200
you have a clog in the line clear lines out and will work right line to tank and to motor both.
Mar 20, 2012 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My briggs and stratton 158cc 500series push mower primer button melted from sun. how do i replace it?
There is a tab on either side of the carburetor right where the primer bulb sits. You can depress both of these tabs with a screwdriver and pry out the plastic ring that holds the primer bulb in place. You can purchase a new primer bulb (with a new plastic tab) from a local mower shop or from a small engine repair shop. When you install the new primer bulb, put the rubber bulb in first then put the plastic ring on top and press it in until the tabs click on each side. It should work correctly after the tabs are clicked properly. You can take off the air filter and look into the carburetor to see if the unit is priming correctly. I hope this helps you out.
May 09, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
I have a Coleman Powermate Maxa 3000 OTV generator that is powered by the Techumseh Enduro Overhead Valve 5.5HP engine. To start the engine take an act of congress. I can't find any "choke" so its like...
I'm working on one right now. Make sure that all the gas in it is FRESH!!!. Then push the red primer bulb about 6 times. It should start. If it does but dies, push the primer as it dies to keep it going. If it does not start, push the primer 6 more times. You are right-there is no choke.
Oct 03, 2010 | Computers & Internet
Fill with gas and prime won't start repeat 2 or 3 times and it will start
Try giving the primer quick jabs not slow pushes. Also make sure to cover the small pin hole on the primer if it has one. It may just need a new primer. it could not be sealing right or have a small wrip. Hope everything works out for ya.
Apr 05, 2010 | Garden
Lawn mower starts and stops right away
take bowl off bottom of carb....clean and reassemble
Nov 16, 2009 | Garden
Engine starts right up after pushing primer bulb,
There is dirt in the nozzel inside the carb,take it apart and clean it with torch tip cleaners. Remember to replace all the gaskets you disturb.
Nov 01, 2009 | Toro Lawn Mower With Toro Power Tools
Procedure for starting
Thats called the primer Make sure the on/off switch is on the on,Push the primer at least 4 to 5 times,then pull it..once it starts you may have to push the primer a few more times to keep it running once it runs on its own and you dont have to push the primer to keep it running Cut Away,Also one more thing you probably already Know make sure its full of bar oil..Hope this helps you and have a great day...
Apr 06, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
