Question about Motorcraft 2004 Ford F-250 Super Duty Window Regulator 04 Ford F-250
I'm in Memphis,tn my truck won't start in the cold. it just spins over and sometimes trys to start. f-250 2004 diesel turbo
    Scholar:
  • 103 Answers
Sadly, that is a very common issue with that model. Issue seems to be that the glo-plugs do not heat enough or are too slow to heat. Most owners are adding a block heater to resolve the issue - of course that helps you get it started at home, but might be a problem if you can't plug in at your work place.
Posted on Dec 12, 2014
Having problems starting when cold. I'm in Memphis Tn
Could be battery or connection(how old is battery)
Nov 14, 2014 | Cars & Trucks
Snopes truth or fiction
No it isnt. It was a hub previously, but like many sensible organisations Delta abandoned Memphis to its fate and it goes down the same toilet as Detroit, Baltimore, Chicago.
Sep 01, 2014 | Cars & Trucks
1992 isuzu bighorn 3.1 turbo diesel, rebuilt injection pump, will not cold start
1: compression good.
2: glow plugs hot.
3: test fuel, does test fuel work??????
yes, you did it wrong
no, #1 or #2 caused.
Aug 27, 2014 | Isuzu Cars & Trucks
98 Isuzu rodeo, engine cranks and trys to start but it won't
If this is a diesel engine you probably have an air lock in the fuel system. It will need "bleeding" before it will start. If you have already tried bleeding the fuel system there may be an air lock in the injectors. If it still doesn't start I suggest you carry out a compression check because diesel engines need to be in good condition to start easily, especially in cold weather If it is a petrol engine, there could be problems with engine timing or ignition problems.
Oct 25, 2017 | Isuzu Rodeo Cars & Trucks
2001 Rodeo 2.8 Turbo Diesel running perfectly one day won't run the next. Seems to be after it sits for a couple of days. Any suggestions?
Hi Peter, If the vehicle turns on the starter all the time, and sometimes starts and other times fails, check the fuel filter for leakage. Sometimes air gets into the fuel system. When it gives problems, open the bonnet (hood) and have someone pump the pump on top of the filter housing. If it feels soft when beginning to pump, I would suspect either a leakage on the fuel line or the filter housing. If you need to replace the housing and filter, remember to fill the replacement filter with clean diesel fuel first. the glow plugs can also cause problems if one or more have burned out. Regards John
Oct 31, 2012 | Cars & Trucks
Pletty of fuel it trys to start but won't run
Is this a gasoline or diesel engine?
Oct 12, 2012 | Cars & Trucks
Mitsubishi galant sometimes clicks and won t start but after a few trys it starts
Battery is weak or you have a corroded terminal.
Baking soda and warm water with a tooth brush.
Followed by plenty of cold water
Don't get anything on you , your shoes or your clothes.
Feb 10, 2010 | 2001 Mitsubishi Galant
Turbo diesel, cranks but does not start when it is cold.
Have the cold start valve replaced, it enriches the fuel mix during cold start and check the glow plugs and see if any are bad, to test remove the wires and put test meter to ohms and one by one test each glow plug with one probe to ground and one on the tip of the glow plug see it it goes close to zero if it does not move then that glow plug is bad, replace all that you find bad.
Jun 15, 2009 | 2002 Toyota Land Cruiser
Fixing up a 1989 Toyota Supra 5 speed
I have a hood emblem from an '87 Supra in very good condition that may work for you. Have you looked on ebay?
Feb 02, 2009 | 1989 Toyota Supra
Motorcraft 2004 Ford F-250 Super Duty Window Regulator 04 Ford F-250 Logo
439 people viewed this question
Top Motorcraft Scuba Diving & Snorkeling Experts
jeff5may32
bobalix
Gil Shultz
Are you a Motorcraft Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
