Question about Drills
How to remove the rotor from the housing in order to replace it with a new one?
Hi, I have a Bosch GSB20-2re 0601194703 (here there is a diagram http://www.ereplacementparts.com/bosch-gsb202re-0601194703-1234-hammer-drill-parts-c-128_1032_15778.html) and I want to remove the rotor from the intermediate flange (housing) because I want to replace it with a new one. I cant figure out know to remove the rotor, I dont see any knob or something... I only see the intermediate flange, rotor ax on it there is a cylinder (probably sleeve type 57 on diagram). Any help is appreciated!
2 Suggested Answers
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
How to pull out Bosch CS20 circular saw's armature?
There are several steps:
Remove the base height adjustment lever assembly(#56,57,71,72,73,74)
Remove the lower blade guard (#37)
Remove the brushes (#810)
Remove the upper guard housing (#827)
The armature will usually slide out with the upper guard - once out wiggle the armature out of the guard housing.
Reverse order to reinstall
http://www.ereplacementparts.com/bosch-cs20-0601674057-circular-saw-parts-c-128_1138_9632.html
Dec 20, 2016 | Bosch Saws
How to remove & install distributor on 1998 Suzuki jlx
answsered here 100s of times now, ok.
does the engine run now< and not fiddle by the wild bunch?
then that is very easy,
first mark all wires. 1,2,3,4 (1,3,4,2 ) is firing order
the rotor turns CCW (do not read GM book lies)
the front cylinder is #1
mark cap tower term.as #1 (the front wire goes there)
  1. now remove cap (distributor)
  2. turn engine by hand until rotor points to #1 location.
  3. This is TDC #1 firing point. (see crank pulley notch at 0?)
  4. I also mark #1 on rim of dissy. (cuz, im careful) and (ask)
  5. remove the clamp bolt and side plug.
  6. pull dizzy out. (distributor slang)
  7. put new dizzy in, allowing for the 13tooth gears to mesh and turn and landing with rotor on #1 mark! . (3 tries, sure)
  8. set clamp bolt, plug in side plug.
  9. Cap back on wires same as before, do not scramble the wires.
  10. new rotor on installed wrong, cheap rotors are just that the install wrong, and never a BOSCH rotor , it fits 1 way only.
  11. The engine now starts.
  12. set static timing using the timing freeze jumper detailed below.
  13. open hood (usa,) look up,see that EPA sticker and timing spec, bingo.
covers all ways (vast) to mess it up, too, not just the simple replace.
http://www.fixkick.com/IGN_timing/16v-procedure.html
good luck.
Feb 24, 2015 | Suzuki Cars & Trucks
How to remove the pick-up coil from the distributor. 1989 GMC 1500 4X4
The distributor does have to be removed and dis-assembled in order to replace the ignition pick-up coil/stator, and if the pick-up coil/stator is faulty then the distributor should be replaced because the distributor will come with a new pick-up coil/stator and the old distributor will have to be removed anyway and in the long run it will actually save money from not having to pay a mechanic to remove and dis-assemble the distributor to replace the pick-up coil/stator, however most of the time it is the ignition module inside of the distributor that is faulty.
When the engine is at TDC (Top Dead Center) is the ignition rotor pointing to the #1 position on the distributor housing as described below?
The engine should be set on TDC (Top Dead Center) with the distributor cap removed, and there is a mark or notch on the distributor housing that the rotor should be pointing to when the engine is on top dead center. (Look under the distributor cap and find where the number one terminal runs under the distributor cap, and where that position on the distributor cap corresponds with the distributor housing, and it should match up to a mark or a notch on the distributor housing)
This static timing is all that matters and the computer will be able to control the timing as long as the ignition rotor is in that position when the engine is at top dead center.
If the engine is at TDC and the ignition rotor does not point to the #1 mark on the distributor housing, then loosen the hold down bolt to the distributor and turn the distributor until the rotor is pointing to the #1 mark on the distributor and then tighten the distributor hold down bolt.
Jun 24, 2012 | GMC K1500 Cars & Trucks
I need a circuit diagram so that i can see how to change the brushes for a bosch Gsb 20-2re drill . Would you please email to me?
I am trying to get you what you need here. The pdf file is about the best your going to get. At least you can enlarge the figure once you download the file.
The parts diagram:
http://www.ereplacementparts.com/images/fein/GSB20-2RE_(0601194703).pdf
The brushes just drop in.. unless the holder is also bad.
Parts list with prices and availability:
Thanks for choosing FixYa,
Kelly
Jul 03, 2011 | Garden
The motor keeps cutting in and out, like the variable speed control is confused. What can I do?
There are a couple problems that could cause this. First is the trigger switch which could be worn out or have a short. The second and more common one is that the motor brushes are worn out. After a long period of use these little blocks that look like black steel blocks on springs are what rub on the rotor and they wear out. These are not steel but special high carbon blocks that are easily replaced and cost effective. Remove the housing and near the rear of the motor assembly you will find the brushes in two square holes on either side of the motor. Remove them (be sure it is unplugged) and replace them with new ones. They can be ordered directly from Bosch or from a host of suppliers on the internet.
Oct 24, 2010 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
1997 nissan quest camshaft sensor where is it & how to replace it
The camshaft sensor is located inside the distributor and is part of it, in order to replace it you must replace the distributor,to replace remove the dist cap. mark the location of the rotor,by marking where its pointing to, then mark the dist housing, so now theres a mark on the rotor and housing to show where rotor points, next mark the location of dist going into housing, mark the shaft and the block,because it spins in block this way you can line back up.next remove hold down bolt and pull out,mark the new dist in exacat same spots as the old so you can install back the same,you may have to put it in and pull it out until your marks are lined up,this way the timing will be dead on, when done you can check timing. good luck
May 09, 2010 | 2004 Nissan Quest
Removing the front brake rotor from the hub housing
You need to take the rotor/hub off the spindle.So you'll need to remove the wheel bearings in order for it to come off. Once off theres bolts in the back of the rotors bolted to the hub.
Apr 23, 2009 | 1995 Nissan Pathfinder
Replacing carbon brushes
The housing cover is removed by removing the one Torx (t-20 or t-25 ) screw from the end of the housing where the power cord goes inside.  Once this screw is removed the brushes can be quickly replaced.  Go to this page for an exploded diagram.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/bosch/1215.034
The screw you want to remove the housing is listed as part 130 in the diagram.  Then the brush (part 801) can be unplugged an removed from brush holder (part 116) by gently pulling back the brush spring (part 126). Then the spring must be held back to install the new brush. Then plug it in, and replace the other brush, test the unit before replacing the housing cover.  The blue sparks generated by running the unit are normal and will decrease as the new brushes are worn to the shape of the armature.  Good Luck!
Oct 06, 2008 | Bosch Die Grinder 1215
Bosch excel check water fault
hi try thisStep 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
Sep 13, 2008 | Bosch Dishwashers
Bosch Dishwasher SGS43E02 Exxcel Control/Display Facia Panel
The panel is replaceable by removing the #20 torx screws inside the door. Once removed the metal outer door cover will slide down and the plastic top housing less switch panel can be unclipped from two locking tabs on either side. You can order via BOSCH service center, check to see if it is warrantied before removing
Feb 06, 2008 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
