Backlight is burned out where do i get a new one
  • 3,506 Answers
Find out what make and model you have and look online
Posted on Nov 15, 2014
Testimonial: "I have a polariod TLA-04641C built in feb of 2008 bought at walmart went to polariod for help & got none any help would be great thanks"
Toshiba quadro not working
Either the Backlight burned out, or the power inverter. If you can connect an external monitor, it's the backlight. If you can't see it, it's either the power inverter or the GPU burned up on the mainboard.
Dec 07, 2011 | Computers & Internet
My Hyundai L90D+ (silver) monitor has worked really well for a couple of years. However, it has recently had the backlight burned out. Which parts do I need to solder to fix the backlight?
it would be esier just to purchase a new monitor. now days 19" monitors are cheap. Visit newegg.com you should be able to get one for $100 you probably could not repair it for that price
Dec 23, 2010 | Hyundai L90D+ 19" LCD Monitor
I have two Tech view 42" ptsw4200u televisions. The screens do not come on and stay black
the backlight might be burned out the Televisions(LCD) use a flourecent tube to light up the screen. I would either have a professional replace the backlight or buy a new TV. I do not know about plasma TVs and how they are lit up if your TV is a plasma screen TV I woulsd consult a professional or the manufacturer of the TV for Help.
Jan 04, 2010 | TechView PTSW4200U Television
Had my tv looked at by a technician and they said it needed a new main power supply,it was to expensive to fix so i bought a power supply and instaled it but it dont work what can i do
Usually there is a warranty period like 30 days.Ask for a replacement if that dont work either there is another problem goin on.Then just ask for your money back,there is sometimes a restocking fee.
Oct 22, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Sidekick 3 backlighting won't work
If the backlight is burned out then you will need to replace the LCD screen. It is fairly easy to do and runs about 30 dollars from ebay.
Here is a guide for it
Sidekick 3 LCD Screen Replacement
and here is a link to buy the LCD screens
New Sidekick 3 LCD Screens for Sale
Sep 10, 2009 | Sharp Sidekick LX Smartphone
Backlight is off
You either have a bad LCD or bad backlight board. The backlight on your screen is no different than a light bulb. If it burn out it stops working, if these is no power to the backlight your screen will have an image but no backlight to see the image.
Jul 03, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
My sidekick 2008 (gekko) backlight doesnt work i can
The problem with your sidekick 2008 screen is the backlight is burned out. this can happen if dropped or if it gets wet.
The only way to fix it is to replace the screen. It is fairly easy to do and new ones run about 65 dollars on ebay.
Below is a guide for the replacement and a link to buy the 2008 LCD screen.
Replace the Sidekcik 2008 LCD screen
Buy Sidekick 2008 LCD Screen
Jun 30, 2009 | T-Mobile Sidekick "Gekko" cellular phone
Navman 5500 gps backlight dim but set to max
Its water ingress causing a short in the high voltage wiring PCB.
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (NA to i models) .
Where water has arced there will be burning black on the green PCB evident, cut the PCB wire and remove the section around the burn.
solder a new wire to bypass the short.
Dry the unit and seal with silicone to prevent re occurrence.
Its a 2 hour repair requiring a high DIY soldering standard but off set it against the time it will take to reload you waypoints in a new plotter , its well worth the trouble.
DAKA
May 27, 2009 | Navman Tracker 5500i GPS Receiver
The screen is black but if you look hard you can see the background very lightly
Hi, your monitor's backlight is burned out or malfunctioning. The LCD monitor consists of two major parts - the LCD panel where images are created, and the backlight which forces light to pass through the LCD panel so you can see things. Your backlight is out. Viewsonic has great warranty support and service. You should contact them, provide them with the serial number, and they'll probably repair it under warranty for you. This is a hardware malfunction, so it needs to be repaired.
May 15, 2009 | ViewSonic VA1912w 19" LCD Monitor
Keyboard light of side kick
If the backlight is burned out, you need to put a new lcd screen in.
It is fairly easy to do yourself and costs about 25 dollars.
Here is a guide:
How to Replace a Sidekick 3 Screen
and here is a link to the Sidekck 3 lcd screens
Replacement Sidekick 3 LCD Screen
Hope that helps you out.
Oct 28, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Televison & Video Logo
Top Televison & Video Experts
