Question about Lasko 5622 1500 Watts Low Profile Heater
How do i turn off the timer on my 5622 lasko heater?
I bought this heater August of 2014, and the red caution light is on but does not heat. What can i do?
don't send anything to Fixya. Please contact your dealer, or the site where you bought this.
Mar 13, 2015 | Lasko 5622 1500 Watts Low Profile Heater
LASKO 5624 will not turn on. The red light underneath the clock button is on. How do I reset? Is this broke after 20 uses?
Disconnect power, (unplug); wait for over 20 minutes, (have a cup of coffee); Depress power button before pluggging in to wall socket . (This will let any voltages that are stored in the unit drain off).
Plug in to AC outlet and press power to turn on.
If this doesn't work, Lasko has a 3 year warantee.
CUSTOMER SERVICE:
Toll-Free (800) 233-0268. Email: producthelp@laskoproducts.com
Feb 02, 2015 | Lasko 5624 1500 Watt Convection Heater w/...
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
Lasko ceremic heater hot cord and melting
Yes it could be the outlet or the more likely wiring to it. If your apt has a maintenance preson have that person take a look if not call an electrician.
Dec 03, 2013 | Lasko 760000 Cyclonic Ceramic Heater, 750...
How to reset Tilt Switch in LASKO Ceramic Heater 5540?
I don't have manual, it's a borrowed one. Several days later, I pushed the botton at the bottom several times, looks it solved my problem.
Feb 08, 2009 | Lasko 5540 Ceramic Compact Heater
Lasko 5350 will not power up. Tempermental.
I had the same problem with mine,, I called the 800# and they told me to either vacuum it out weekly or use a hair dryer to blow out the vents, both solutions seemed to have work for me ~ good luck
Nov 14, 2008 | Heating & Cooling
Lasko 5132
There was a recall on this model and it was deemed a fire hazard as the plug can overheat at the base.
Apr 08, 2008 | Lasko 5132 Ceramic Compact Heater
Lasko 5622 1500 Watts Low Profile Heater Logo
656 people viewed this question
Top Lasko Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you a Lasko Fish Expert? Answer questions, earn points and help others
