Question about Kenmore Washing Machines
I have a kenmore loading washer that skips the wash cycle, what could it be?
The washer machines fills up with water, clicks clicks and then skips washing cycle, but rinses and spins., what could it be, please help
    New Friend:
    Problem Solver:
  • 15 Answers
Bad Dail, need to be replace
Posted on Nov 19, 2014
  • 90 Answers
SOURCE: washing machine
check pressure switch hose
Posted on Jan 06, 2008
mastatech
  • 478 Answers
SOURCE: We just purchased a top load Kenmore 800 washer
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Posted on Mar 13, 2009
  • 5 Answers
SOURCE: the washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
Posted on May 29, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Posted on Jul 01, 2009
  • 119 Answers
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Posted on Aug 21, 2009
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
    You may have 2 defective parts.
    First,make sure the hot and cold water hoses are connected correctly and both turned on.
    If the water fill problem is the same,the water temp switch is bad.
    The not filling after the wash cycle could be a bad lid switch.
    Set the machine for SPIN and turn it on.
    If it does not spin,replace the lid switch.
    Sep 20, 2010 | Kenmore 24042 Top Load Washer
    Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
    if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
    Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
    Kenmore model # 110.244222300, Won't automatically complete wash
    This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
    First, see the Sears parts site for your washer:
    http://www.searspartsdirect.com/partsdirect/index.action
    Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
    Following is a Whirlpool / Kenmore service manual for top load, direct drive washers.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    Initial thoughts are that the Timer is worn / broken.
    Here is a description of how to gain access to the console on these washers where you may be able to test the timer. (See the Whirlpool service manual for testing)
    http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
    Jan 19, 2010 | Kenmore Washing Machines
    We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
    Mar 13, 2009 | Washing Machines
    Kenmore front-load washer stops at rinse cycle
    When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
    Mar 03, 2009 | Kenmore 43142 Front Load Washer
    Clicking Sound / Kenmore Elite Catalyst
    sounds like ur coupler is bad easy fix 4 dollar part
    Dec 26, 2008 | Kenmore 22422 Top Load Washer
    GE washer model WHDSR209
    On some models, the drive motor is universal meaning the drive turns clockwise in wash mode and turns counter clockwise in spin mode.
    Possibly the motor windings is defective for the wash mode and thus the entire drive motor will require replacing.
    Hope this helps..
    Jul 15, 2008 | GE WDSR2080D Top Load Washer
    Kenmore washer fill problem
    make sure you have it on the right settings, or inspect fill hoses cold for clogg
    Apr 17, 2008 | Kenmore 44042 Front Load Washer
    Washing Machines Logo
    133 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
