Question about Watches
How do you set up weide WH-2309 actual time(not the LED time)
I have already set-up all the led function and it works perfect however the actual watch is not in sync with the led one so I have not found any detail on how to set up the actual watch in the manual. Please help me.
SOURCE: Bench Watch BC0088 set up manual
Hold down the bottom left button for 5 seconds. It goes to set mode.
Posted on Oct 21, 2008
escapement
  • 2334 Answers
SOURCE: manual for sharp shp6800 atomic watch
Follow this link and submit all details. Then you will receive an e-mail with instructions:
http://www.sharpusa.com/global/ContactUsProdSupp/1,1878,,00.html
Rate me, please.
Posted on Mar 23, 2009
Noggin
  • 944 Answers
SOURCE: Rolex Daytona Wrist Watch
Try these guys for a manual; http://www.timemerchants.com/catalog.htm They have the 2000 daytona manual and several older ones available. Otherwise try your local Rolex dealer; http://www.rolex.com/en/collection/rolex-gallery/cosmograph-daytona/specification.jsp#/en/xml/inside-rolex/sales-service/affiliates/index Hope this helps :)
Posted on May 16, 2007
SOURCE: Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
Posted on Apr 04, 2009
SOURCE: I have a Puma Led
click on the top right button to view time, then click bottom right button and hold it as the time is still appears. then it will start blinking. if you press the bottom right button you will be able to swap the command you want to change (H,Min,Y,D,M) and if you press the top right button you can increase (only) the number you like. Left buttons i dont know what they do :P
Posted on May 21, 2011
Where can I get instruction details for my POD 550 watch?
RCX5 found it surprisingly light and small. It doesn't look like a computer on your wrist like many other GPS watches. Of course that is largely because the bulk of the GPS components and battery are in an arm band.
The armband and separate GPS device seemed like, and became, one extra piece of equipment to worry about.
The watch, heart rate monitor and foot pod all use watch batteries. Battery removal can be difficult, however once the back is removed the batteries are easy to install and replace. The GPS piece is charged with a standard USB cable.
The speed and cadence sensors batteries are not replaceable. These sensors must be purchased again when they wear out
The speed and cadence sensors are attached to a bike with zip ties. I found them easier to install than the Garmin sensor largely because they are separate devices. It was easier to position each of them so that they picked up the magnet from the wheel/pedal separately, rather than trying to align one device to detect both.
Additionally the speed and cadence sensor each have a built in led light that flashes each pass of the magnet.
However, to configure your stride length is tricky at best. The best way to do it is to run a distance using the stride sensor that you know the actual distance of, then change the distance in the history. So let's say you ran 1 mile. The watch believes you ran 1.1 miles. By changing the history to 1 it should adjust the settings so that the next mile you run will record correctly.
Once you have been using the watch for some time you can get into advanced setup. You can add your own sports, or configure the devices, and screens setup with each sport.
You can do this from the watch, but it is easier to do it from the Polar Web Sync software. The software works much like a remote terminal for the watch. You connect to the watch and add or change each sport profile, or change user or device settings.
May 09, 2015 | Watches
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
Look can someone help me set the digital time on my watch please its omega seamaster polaris cheers....
Your watch uses a calibre 1665 movement. You might contact After Sales Service and ask them if they would send you an owners manual. Setting the time and date is fairly straight forward but you also need to sync the analog and digital displays so it is a bit difficult to describe in just a few words.
The basic guideline is
To select function - turn the crown
To change function - pull out the crown and then turn it
To start and stop functions - press the crown
Dec 01, 2012 | Watches
I have a 3054. About 3 days ago it reset to 1-1-2005 and has never changed. it now reads 1-3-2005 at 5:57 PM
This same problem (watch resetting to 1/1/205) has happened to me 2x now, about 2 months or so apart.
I have had this watch for ~10+ years now, and works perfectly.
I have replaced the battery 2x.
Again, the watch works great.
I just realized that in the .pdf manual, there is no indication for a "low-battery" condition.
I am guessing that the "low-battery" is what is causing the watch to reset the date/time to 1/1/2005.
Any others having this same problem if this watch resetting to 1/1/2005 after the watch has run just great (auto time syncing, etc.)?
This watch Keeps great time!
Buster Brown
Jul 25, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Compass is no longer pointing North
I had the same issue. I found that if you re-calibrate the compass the same way you did the first time, then it will act properly. I've had to do this a couple of times and it works.
Jun 12, 2009 | Timex Expedition E Compass Watch Titanium...
Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Apr 03, 2009 | Watches
Athletic Works Watch
With time displayed:
Press lower right, then upper left.
Mar 12, 2009 | Oakley GMT OAK0531 Wrist Watch
Columbia Watch CL-5030
Hold the light button (top left hand) for a few seconds and the adjustment mode becomes available.
Dec 25, 2007 | Columbia All Sport Digital watch
Watches Logo
1,278 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
