Question about Canon MP11DX Printing Calculator
My calculator is frozen what do i do
The entire machine is frozen, can not make it do anything, there is nothing spilled etc.
Spilled icetea on to laptop keyboard, will power up but nothing else screen is black. hp nc4200
Ugh, sorry you had the accident, but many a laptop has survived such a spill (or in my case spills) and booted to tell the tale.
I'm assuming you now have the machine powered off, if not shut ot down immediately and do not try to restart it until you have done the following. There is kind of a standard procedure for laptop spills that I will provide you.
The suggestions below assume that your nc4200 is no longer under warranty.
Remove anything attached to the machine, battery, cables, external drives, anything. Using a soft, slightly damp (yes damp - got to remove as much of that sugar as possible) cloth blot any liquid on the machine gently, do not rub.
Tilt the laptop gently from side to side to allow any possible liquid to drain out. Do not shake the laptop. The Place the laptop upside down so that any potential remaining liquid will drain out. Hopefully you did not spill this amount of tea 8^).
Secure a regular hair blow dryer. Set it to low and slowly move it back and forth over the keyboard from about six inches and do the same for the rest of the machine, focusing attention to the openings that it has for ventilation. Do this for about five minutes or so.
Now the hard part: Set aside the machine in a warm (not hot place) and wait (at least four hours and if you can wait overnight, even better).
Try booting it with nothing attached. If it still doesn't boot the problem has gone beyond the keyboard and you'll have to consider having it professionally serviced.
Good Luck and thanks for using Fix Ya
Mikeyaf
Mar 17, 2011 | Computers & Internet
Frozen
Unplug the device, wait for 30 seconds, and plug it back in to see if it resets the device. Make sure you wait the full 30 seconds.
Oct 11, 2009 | GE (WMM317440) Answering Machine
My TI-89 Titanium is frozen on a table setup window, and i can't do anything to get out of the screen. when i push any button, the cursor will blink once, but nothing happens or changes... Is this fixable?
This might be fixable - first try 2nd + On or Diamond + On. If those don't fix it, you'll need to reset your calculator. The quickest way is to pop a battery out of the back and put it back in. It also works to press Left + Right + 2nd + On all at once. There's a good chance you will lose anything unarchived with the latter method, so do the battery first.
Sep 24, 2009 | Texas Instruments TI-89 Calculator
Coffee spilled on adding machine
The sugar is the problem, To solve it you must disassemble the keyboard wast it out with hot water let everything dry then reassemble. an awful lot of work for a inexpensive calc.
DickyO
Sep 21, 2009 | Sharp EL-1801P Calculator
Frozen, 'snowy' screen...HELP!!!
The only solution that I can think of that might work would be connecting the Ti to another Ti of similarly close models and use the "sendOS" function on the working one, this should reset the crapped one to a functioning setup.
This does require the special wire they have for connection 2 calculators together... probably can get it on ebay or something if you don't have it already and just borrow a friend calc in class or something...
If you need more help you can reach me at saik0[dot]com or Saik0Shinigami{at}gmail[dot]com
Oct 21, 2007 | Texas Instruments TI-83 Plus Calculator
Non functional keys
HP 48SX and HP 48GX calculators have a membrane which connects between the internal circuit boards. This is a common failure point. The "ON" button is often the first button to go out. The calculator can be opened up can cleaned, but it is a little involved. Forutnately someone has posted pictures and information on what to do.
http://www.hpcalc.org/hp48/docs/opening/hprepair.zip
There is a text file with information. The file is big because of the pictures. Summary: Open the case, bend metal clips holding the circuit boards together. Clean up any dust and the contacts. Reassemble.
Sep 21, 2007 | HP 48gx Calculator
Blank lines
It sounds like the lcd is either defective or damaged by liquid spill or dropped. Not feasible to repair. John
Jun 10, 2007 | Texas Instruments TI-89 Calculator
Coffee spill in calculator
I've wetted a wide variety of gadgets, and I've found that generally- not always mind you- leave it to dry for a few days, it could come right on. DO NOT plug in the machine until you're certain there's no remaining liquid inside, and when you plug it in do so at your own risk; be aware that some conductive mineral in your coffee might have been deposited inside, across a circuit and short the whole thing. A short may result in fire. You can make the process alot safer by plugging into a GFCI outlet (one of the ones with the breaker built in, like in a kitchen). I've had calculators and phones, cellphones, a playstation and even a network card survive a drop into water (and other liquids >
May 21, 2007 | Sharp EL-1801P Calculator
Canon MP11DX Printing Calculator Logo
95 people viewed this question
old marine
old marine
