Question about Google Gmail
My gmail acct will not load any new mail. It keeps saying "can not connect to server" but only having problems on my pc. Can check it fine on my phone, no problem. please HELP
  • 87 Answers
Hi!
Your Internet Service Provider has either blocked Gmail for you or you are having internet connectivity problems on your computer. Contact your service provider, and they'll fix it.
Posted on Nov 15, 2014
budhoyo
  • 26 Answers
SOURCE: Gmail POP3 Error
Set your gmail profile in your gmail account, by allowed pop3 system software download your mail from gmail
Posted on Sep 26, 2008
freetek
  • 5568 Answers
SOURCE: Gmail.com
- Dialup: The lowest speed of any Internet access and it uses your telephone line to connect meaning you can't use both. - Cable: If you are connected to a cable system for your TV reception, many cable companies offer internet service as an add-on but is characterized by the use of an additional box between your PC and the cable connection. - DSL: 'Digital Line Subscriber' this is a technique that also requires some electronics between your PC and the telephone line which then can serve two purposes; provide a faster connection and still leave your telephone operable. - Satellite: Two types are currently in service; one uses your satellite dish to receive information to pass on to your PC, giving you very fast downloads from the Internet but uses your phone line to send information to your email and also the commands you issue that require that your PC send instructions. The second type, the most costly and fastest of all for home use, requires a transmitter located at your location that provides both downloads and uploads (stuff you are sending somewhere) via a radio signal that is sent to the satellite and then transferred back down to ground stations.
There are other connections available at much higher cost primarily for businesses, the most common of which is the T1 line that exceeds the speeds of the others by many times and uses a dedicated line reserved for the users purposes.
I don't know what version of Windows you are using but on the Control Panel, the 'Network Setup Wizard' is useful for some types of connections, others can be set up via 'Network Connections' or 'Internet Options.'
Your ISP (Internet Service Provider) should have a phone number to help you use the service. Your ISP might be AOL, Netzero, etc. and they may have a semiautomatic setup program to help you to start.
It is apparent that you do have some kind of service but if it is either not set up correctly or simply too slow to avoid 'time outs,' you may have problems not easily solved.
I use a 'real time' conncection speed monitor called 'NetStat Live' to watch the quality of my lousy dialup connection so I can dis- and re-connect if I get a particularly slow connection. You can download it free from:
http://www.analogx.com
It is not completely free of glitches but works well enough and tells me what I need to know.
Don't worry, all this stuff will be 'old hat' after you have dealt with it once or twice :-)
Posted on Oct 14, 2008
SOURCE: wont log in --keeps saying redirecting
This happens when it sometimes refuses to accept the cookies or if disabled, kindly clear your Cache as:
For FF
: Click on Tools, then Options
Select Privacy
In the Cookies panel, click on Show Cookies
To remove a single cookie click on the entry in the list and click on the Remove Cookie button
To remove all cookies click on the Remove All Cookies button(prefer to Remove all cookies)
For IE
: Click on Tools, then Internet Options,
under General tab see Temporary Internet Files block, and then click on Delete cookies (prefer to click on delete files also)
The problem will be solved.
Posted on Feb 10, 2009
SOURCE: couldnot get into gmail acct,, so made another
go to gmail & sign in with your ID & then in the same menu box at the bottom click can't access my account & follow the prompts
Posted on Sep 25, 2011
  • 76 Answers
SOURCE: I forgot my psswrd to gmail acct, and could not
In gmail.com There is Need Help button Below the sign in button click on it and select i dont know my password and follow simple steps to recover your password
Posted on Sep 05, 2014
Problems sending email message username and password incorrect I have reset it several times and have also added an alternate server,
Hi , if your using I device and obviously you've set up an e mail / gmail adress with your password , here's the easiest solution .
Go to your settings menu
scroll down to mail ,contacts , calendar . ( tap on )
you should see your email address (tap on )
you should see your gmail acct. and at the bottom delete acct. (Tap on delete ) not to worry your acct is a fixed or an assigned acct only to you and will always remain .
Now you will be asked to add an account
problems-sending-email-message-username#solution-section-g4hgh2rdbszykgek21atp4ab-2-0.jpg Choose your provider ,Google , yahoo , hotmail ,etc
problems-sending-email-message-username#solution-section-g4hgh2rdbszykgek21atp4ab-2-2.jpg Follow the instructions and TYPE YOUR FIRST AND LAST NAME, ORIGINAL USED PASSWORD (APPLE ) , AND IF YOU WANT A DESCRIPTION FOR THIS ADDRESS ,ie : default adress , recovery adress , email 1 , email 2 . Etc etc .......then
you will see in upper right hand corner continue or done . Should be Done . Tap done.
You do not need to open SMTP or you do not need to add server . It is located through automatically.
Your done ! Should open email app icon and send or receive mail . If you get an error pop up then you've most likely entered wrong password . Use your apple password . Not your Google or other provider password
Sep 20, 2016 | Cell Phones
Tip
Using Gmail as your Universal Inbox
Nowadays most people have more than one email account. If one of yours is a Gmail account, you can use it as your primary inbox to check all your POP3 accounts in your Gmail browser window. But do remember that you can check only other POP3 accounts only. You won’t be able to check Yahoo mail, Windows Live Hotmail, or other such web mail accounts. Also, not all POP3 servers work with Gmail.
Here is what you need to do. Open your Gmail account and click Settings-Accounts. In the ‘Get mail from other accounts‘ section, click Add another mail account. Enter the email address of the account you want to add, and click Next Step.
Enter your username, password and POP3 server. If you want to continue to access the account through a mail client or through the ISP’s own Web interface, in addition to picking up and sending mail in your Gmail account, check Leave a copy of retrieved message on the server. This allows you to read the mail in Gmail, but the mail will remain on the ISP’s server so that you can download it with your standard mail program or read it through the account’s own Web interface. On the other hand, if you plan on accessing the mail for the address only through your Gmail account, you can leave the box unchecked.
Next, check Always use a secure connection (SSL) when retrieving mail to keep mail snoops at bay. In some instances a POP3 account may not work with an SSL connection: if that is the case, you will have to leave this box unchecked.
If you want all of your incoming messages from the account to carry a label, such as the name of the account, select Label incoming messages. In Gmail, a label works much as a folder does. You can view all mail that carries the same label by clicking the label. Gmail automatically creates a label for the address of the new account. You can select a different label or create a new one by choosing the appropriate entry from the drop-down list. Another option is to have messages bypass your inbox and go straight to your Gmail archive. This would be a good choice if you want to use Gmail primarily for searching through mail. When you’ve made all your selections, click Add Account.
You can compose mail in Gmail and have it appear to the recipient as if it were from the account you just added. When a message appears asking whether you want to create a custom From address, click Yes and follow the instructions.
Gmail will check your account, and any mail sent to either address will appear in your Gmail inbox. To stop Gmail from checking the mail, click Settings-Accounts and choose delete next to the account.
on Mar 20, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
I have just updated my iPad in settings and now don't receive emails. Can see on my iPhone that I have some
This is and ongoing problem with the new OS's. If you delete the email account and redo the email setup this usually helps. Ex. If you have a Optimum (Cablevision) email acct you need to use mail.optimum.net NOT mail.optonline.net cause Apple is not recognizing the old server names. So check with your email provider if the server names to setup have changed. I know that changing your email address can be a pain but if you go to a GMail email acct this will solve a lot of the problems that occur when using cable provider email accounts. Also there is a software that will notify all your contacts that your email has changed that you can implement if you choose.
Jan 30, 2015 | Apple iPad Tablets & eReaders
Google gmail email
you want Gmail as your default mail service? tell your OPERATING SYSTEM, not your gmail settings
Jul 19, 2014 | gmail.com
Login to my Gmail from Window Mail
Contact 1-800-204-4427 Gmail Technical Support phone number is a fast and easy way to resolve all Gmail account related issues,
May 19, 2017 | gmail.com Computers & Internet
Setting up Email Acct with Iphone
well to the first person unfortunatly the bellsouth email system is not yet designed to work with the 3g network so you would have to turn that off to use bellsouth.
Also for all of you need to remember that both Yahoo and AOL email work with the IMAP stands for Internet Message Access Protocol. It is a method of accessing electronic mail or bulletin board messages that are kept on a (possibly shared) mail server. In other words, it permits a "client" email program to access remote message stores as if they were local. For example, email stored on an IMAP server can be manipulated from a desktop computer at home, a workstation at the office, and a notebook computer while traveling, without the need to transfer messages or files back and forth between these computers.
where as the bellsouth system is a POP system. what the means is that when you check your email client on either the computer or the phone it is actually pulling the mail from the bellsouth server to the respective devices and deleting the email unless you have both set to leave a copy on the bellsouth server.
and again the sending and recieving issues with bell south is due to the 3g network
Dec 18, 2008 | Apple iPhone 3G
Connecting to Yahoo
My problem is Incredimail...I can't send e-mail . They say for me to go to
yahoo Properties which i can't find.
I have to put in Server Port Numbers
Outgoing mail (SMTP) 465
check..This server requires a _secure commection(SSL)
Incoming mail (pop3): 995
check..This server requires a _secure connection (SSL)
_Use Defaults
Then it says ..From now on you should be able to send and receive mail using your Yahoo account without any problem
Oct 22, 2008 | Yahoo Mail
Goole Mail configured through Outlook 2003
Go back into your email accounts setup and follow step by step.
under the internet email settings your server info for incoming should be pop.gmail.com and outgoing should be stmp.gmail.com
click on the more settings button
click on the outgoing server tab on the new windown
be sure the my outgoing server requires authentication box is checked and the radio button that says use same settings as incoming is selected.
click the advanced tab
check the box under incoming server that says this server requires an encrypted connection and enter 995 in the value
check the box under out going server that says this server requires an encrypted connection and enter 465 in the value
Your account should work fine with this setting
Mar 04, 2008 | Microsoft Office Outlook 2003 for PC
Email set up
you can, if you have an internet connection to your phone and a pop3 and smtp account on your email.
On jam, go to messaging >Accounts>Outlook E-Mail>Account>New Account...>Enter your e-mail Address: >next>next>Your Name>Username (Put your email login username)> Password (Your E-mail Password)>Account Type (POP3 is OK)>incoming mail (pop3 address, for gmail ,its pop.gmail.com)>Outgoing Mail (smtp server, like smtp.gmail.com)>Domain (if any)>finish.
then to connect, Accounts>connect.
Oct 09, 2007 | i-mate JAM Pocket PC
Google Gmail Logo
51 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
