Question about Senville 18000 BTU Dual Zone Ductless Air Conditioner and Heat Pump 9k 9k or 9k 12k or 12k 12k
Were dose the green wire go to my senville 18000 heat pump indoor unit
    Master:
  • 602 Answers
The green thermostat wire goes to the G on the terminal strip. If it's not a thermostat wire it is a ground wire Should be grounded to the metal case for safety. It does not affect the operation.
Posted on Nov 17, 2014
How to replace the blower in a Senville SENA-24HF Mini Split Wall unit?
You have to pump down the a/c and remove the indoor unit. If not
The bottom of front side of front panel there are 3 screws. Unscrew and remove the front panel. Then unscrew PCB board. Then Unscrew the coil, and slightly keep upward and replace the blower.
Sep 08, 2015 | Senville 24000 BTU Energy Star Ductless...
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
How can I fix
Hello, try to clean and dry the electronic board, sometimes the humidity make shortcircuits between logic gates.
Oct 24, 2014 | Senville 18000 BTU Ductless Air...
Leto senl/18hd/I or 18hd/o unit keeps turning itself on and switching from heat to a/c mode on it's own.
Is unit still under warranty? If so call manufacturer And request new board and is there a board for outdoor unit? If so, get one of those too. Tell them U will return unused parts. replace outdoor board first and check. replace indoor board and test.
What does error code E6 mean?
E6 usually means that there is a communication problem between the indoor unit and the outdoor unit. This could be due to a wiring problem or maybe you had a momentary drop in the voltage. Find the circuit breaker in the circuit breaker panel for your home/office that is connected to the A/C unit. Turn it off and back on and try using the A/C again. Sometimes the indoor unit is connected to one circuit breaker and the outdoor unit is connected to another one. Make sure you have disconnected and reconnected both before running your unit. If that does not solve the problem you may need to have some cable replaced between both units.
Apr 30, 2014 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Senville mini split displays a "defrost" symbol????
It's a heat pump and that is how they work. But it shouldn't be cycling so much unless you live in Minnesota? The colder it is outside the more chance that the outside coil will freeze so it will go into defrost. It may be low on charge or have leak as well. Call a tech to verify.
Apr 13, 2014 | Senville 18000 BTU Ductless Air...
Gree 18000 Btu Air Conditioner , f2 appears on display
F2 is an indoor pipe sensor fault. You will need an air con tech or electrician to do this as the sensor is wired into the indoor board. Gree parts can be a bit difficult to obtain but a similar sized pipe sensor from an LG or Teco unit will work. You may have to "splice" the new sensor onto the existing pipe sensor wiring as the connection to the indoor board will likely be different. Contact LG or Teco for your colsest parts outlet or buy direct from them.
Sep 07, 2013 | Gree 18000 Btu 20 Seer Ductless Mini Split...
I have two senville mini split 18000 and they both frost up with in 1 Hr. of use both have been pumped out and recharged
Dear Friend! Before recharging gas.did you check leak testing? If not, again you will same problem.
And some more reasons for frost up:
1. Indoor coil & air filter dust blocked-clean it. 2.Less rpm of indoor fan motor- replace capacitor or motor.
Thanks, it's helpful to you.
Jan 10, 2011 | LG LS-K1830CL Cool Mini Split Air...
Senville 18000 BTU Dual Zone Ductless Air Conditioner and Heat Pump 9k 9k or 9k 12k or 12k 12k Logo
134 people viewed this question
Top Senville Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Senville Heating and Cooling Expert? Answer questions, earn points and help others
