Question about RCA L32HD31 32 in. LCD HDTV
How do i manually add OTA channels after auto scan is done.
Can`t add all channels at once, need to reposition anntenna.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 94 Answers
I don't think this is possible. Have you considered having two antennae connected at once?
Posted on Nov 15, 2014
LEDTV24FHDF
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
displayed.
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
available.
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
remote.
Apr 08, 2014 | Televison & Video
Cannot get audio on one channel
Which make/model TV do you have? Are you watching an OTA signal or cable signal?
On my Viewsonic N1930W, I had a period where certain OTA VHF channels had no audio. The UHF channels were fine. The steps I used to reset the TV: unplug for a while. After reconnecting the power, go to the Tools (Options) menu and then reset the TV to the defaults. Then I did a new channel scan for OTA channels. On my TV, the menu is called Options but the icon is a wrench and a hammer in an X. Thus I call it Tools. The Restore Default option is at the bottom of the list in that menu. The reset command triggers several "Are you sure prompts?" Pressing the Enter key on the remote after highlighting Yes is required. After the reset, I can go to the Channel menu and select Auto Scan after making sure that it is set for Air as the source.
If you post a comment with the details of your TV, I may be able to give the steps to reset your TV.
I hope this helps.
(I spent several days trying different solutions and did e-mail Viewsonic support on the problem.)
Jan 05, 2013 | Televison & Video
I have the box installed and on. Now what do I do to get the local stations on my TV
What box - satellite/cable/digital-to-analog converter? This tv has a digital (ATSC) tuner built in. So if you are looking for OTA channels, use antennaweb.org or tvfool.com to find out what direction to point your antenna and what antenna you need. Then connect the antenna's coax cable to your TV. Antennaweb is very conservative and assumes an outdoor antenna. tvfool.com will list several more channels and the different antennas that are needed for various distances between your location and the station transmitters.
If you are sharing one antenna between several tvs or tv and other devices, you may need an amplifier in addition to the splitter. (Unfortunately, these can get damaged by surges as well. I've lost certain channels after a lightning strike turned the amp into a filter for one part of the RF signal spectrum.)
Once you have the antenna connected and pointing in the direction of the desired station, you will need to scan for channels. If this is the first time the tv is set up, you will be prompted for menu language, the input type and then asked if you want the TV to auto-scan for channels. Otherwise, hit Menu, use the left and right arrows to get to the Channels menu option and press the + button in the center of the arrow keys. Next use the up and down arrows to set the incoming signal (if needed) - the item is labeled Cable and is a Yes/No (again press + to select item and to enter the change). Continue down to the Auto-program and let that run. You can add/remove channels from the resulting listing with the Channel Skip/Add option just below Auto-program.
I hope this helps.
Jun 21, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Manual needed for Sanyo CP29ST3 - I need to tune in TV channels! I lost the manual!
Sanyo has two parts distributors in the U.S. Both are listed below. You'll need to contact the one closest to you and inquire about purchasing a replacement manual. In the meantime, if you're just trying to program the channels into your TV, you need to bring up the TV's menu and select the screen that has the channel or setup options. All TV menus follow the same general format: you should see icons or words going across the top of the screen or down the left side indicating the different menus that are available. On some older TVs you have to press the menu button more than once to cycle through the different menus. Each menu has different options such as picture options (brightness, color, tint, etc) audio options, setup options, and channel options. Use the arrow keys on the TV remote to manipulate what you see once the menu is on the screen. Once you find the channel options, you need to perform what's called a channel scan. On the screen it may say auto scan, auto program, or channel scan. Once you start the scan, you're done. The TV will scan for all available channels and the menu will disappear once it's finshed.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 22, 2009 | Televison & Video
Lost certain channels on Eurovox
run auto scan......please make sure you dont run power scan.....once scan is done you should get all the missing channels back.
Jun 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Turn tv on and get no program or weak signal message.
You should be watching tv in no time. Email me and let me know how it went I would like to know if I was able to help. surfpro@yopmail.com
1-You didn't say what model tv you have. Is it a HDTV?
2-Are you using an over the air (roof) or set top antenna connected to the tv?
3-Are you getting the no program or weak signal message on all channels?
4-Have you tried first cycling through the source or input button to make sure you are on TV and not on an input. Sometimes if you are on an input and for example the device connected to that input is off you wil get a no signal until you turn the device first but you probably already know that.
5-When you were in the process of scanning for channels assuming you had an over the air antenna connected did you make sure and select the ota option and not cable? if you have an ota antenna and not cable you need to select ota before scanning for channels.
Now assuming you have an ota antenna and you chose ota before scanning or doing a re scan and after the scan you still get the no program or weak signal message that means there is no signal and you may be using the wrong antenna or try moving the antenna in the direction of the television tower if you know where that is or turn in another direction but unless you are using the wrong antena you should get something.
Assuming you received some channels or even if you did not, try to and add channels by hand. Heres how: first you need to know the RF frequency channel or digital channel its transmitting on you just cant input the number of the display channel you want like on a tube at least not initially but you can after you first input the rf or digital channel number first and saving it on your tv then you can just input the display channel number you are used to. Heres how to manually force the tv to enter a channel without a scan or re scan and possibly loosing other channels with a rescan.
Go here http://www.rabbitears.info/search.php and go to state search choose your state from drop down list and click search now do you see the list of stations? on the left you have the display channel (thats the number you usually entered on a regular tv) and next to that is the digital channel (thats the number you need to enter on an hdtv or dtv initially to force the tv to accept the channel because if you just enter the number your used to initially the tv wont find it) the tv should now automatically redirect you to the channel you are normally used to and any digital equivalent and any sub channels for that channel. Now save it into memory in your tv menu channel list. do this for every channel for your area if you were unable to pick up any stations during a scan.
Jan 06, 2009 | JVC AV27F476 27" TV
The screen says Air, No signal the channels will not change on tv or remote DTV 265-D with built in DVD
Do you have an anntenna connected to the tv?  if so go to the menu and do Auto Channell Search. If you do not have a anntenna and have a cable or sattilite box you need to change the tuning band from air to cable.
I can assist further if needed.
lone99star
Dec 31, 2008 | Mintek DTV-263 26 in. LCD Television
Setup will not connect to uhf stations using rabbit ears antenna1
Signal is not strong enough. Use outdoor aerial for best results.
Aug 21, 2017 | Sharp 27U-F510 27" TV
RCA L32HD31 32 in. LCD HDTV Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
