Question about Maytag Washing Machines
My water was not in when I ran a cycle thru my front load maytag washer. Now it there are no lights on and it won't unlock
Bang the door when its switched on
sounds like something to do with the door lock
turn it on and bang the front of the door lock
then seek a new door lock interlock,,,
Posted on Dec 10, 2014
5 Suggested Answers
SOURCE: Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Posted on Oct 02, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
wpcustomer
  • 362 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My Maytag Neptune front load washer continues to fill with water.
    For troubleshooting assistance please click on the following link
    http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
    Posted on Jul 17, 2010
    ZJLimited
    • 17970 Answers
    SOURCE: Electrolux front load washer door won't
    First try to reset the lock unplugged the power machine for a few (10) minutes (maybe release the interlock door switch). If this work, them its possible that you need door latch replacement.
    To do it, turn off power, unplug at the mains. Drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
    Keep us updated.
    Posted on Aug 18, 2011
    Lights keep flashing and door locks without finishing cycle
    Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
    www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
    flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
    Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
    ? 5:51
    https://www.youtube.com/watch?v=oBihToN6dxs
    Sep 6, 2013 - Uploaded by ApplianceVideo.com
    Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
    Washing machines - Ariston
    Jan 05, 2016 | Washing Machines
    Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
    My washer door is locked and how do i get it unlocked. the light is on and will not go off even after i ran thru a cycle.
    unplug your washer for 5 minutes cut it on and see if you can unlock door, buy you a new door lock switch
    Sep 24, 2009 | Maytag MAH6500 Neptune Front Loading...
    Maytag neptune MLG2000AWW does not turn off at end of spin cycle
    d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
    Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Front loading Maytag Neptune doesnt drain all water
    the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
    Mar 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Washing Machines Logo
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
