TV turns itself off? - Televison & Video
    Problem Solver:
Prathnath and Zahra: Thank you both for your answers. I can confirm categorically that the sleep timer is off. I work the TV through a Humax PVR and have just checked through that menu that the timer is off. Any other suggestions?
Posted on Dec 18, 2014
    Filmmaker:
    Uploaded 5 video answers.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
I am sharing four cases in which your tv either turns itself off or appears to turn itself off.
TV appears to be off
  • You using your tv as a monitor or your pc is in sleeping mode.
  • Your cable or satellite Box is not outputting a signal.
TV turns iteself off
  • The sleep timer is set.
  • The off timer is set.
Your tv appears to be off:
If you are using the tv as a monitor If you are using tv as a monitor and the stand-by light only
blinks for a few seconds when you press the power button,your pc is in the sleeping mode. To take your pc out of sleep,press a key from your key board or move the mouse.Tv turns on.
If you are using TV with a cable or satellite Box
If you have a cable or satellite Box your Tv may appear be off because the cable or satellite Box is not outputting a signal.Press the guide or info button on the cable or satellite Box remote control.
if the screen displays info or guide data,the problem is caused by the Box,you must call your cable provider.
if screen does not display info data,change the source on your TV.
Posted on Nov 14, 2014
  • zahra Nov 14, 2014
    New Friend:
If TV turns off automatically after a period of usage, first thing you have to check is, if the sleep timer is turned on. You can navigate through the options in TV remote and find if sleep timer is On. If its happening even after that, it can be related circuit board inside (it can be a heating issue).
Suddenly turned off. Why won't it turn on again?
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears to turn itself off. These cases are listed in the following table by category.
HELP! My LG LCD TV suddenly turn off by itself and ... - AVS Forum ...
www.avsforum.com/.../1084538-help-my-lg-lcd-tv-suddenly-turn-off-its...
Nov 13, 2008 - 30 posts - ‎22 authors
This morning, I turned it on, its suddenly turn off and on by itself repeatly. I can't even control the tv using the remote again. Then I try the trick ... Samsung TV turns on and off repeatedly before staying ...
Jul 1, 2014
My HDTV Shuts itself OFF then it Turns On by itself ...
Sep 12, 2008
More results from www.avsforum.com
Samsung Smart TV turning off - Forums - CNET
Dec 29, 2015 | Televison & Video
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Turns off by itself after i've turned it on
I have this same TV and had a similar problem. This may or may not be the same case with yours. The button panel on the front of your TV may be having connection problems. Mine would come on and off by itself. I took the front panel off and cleaned the connection on the button board with a q-tip and a little dab of alcohol. This cleared up the problem of it turning itself on and off.
Mar 20, 2009 | RCA P46924 46" Rear Projection Television
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
RE: Sharp Aquos LCD TV, MODEL LC-37D40U Tried to switch the TV on via remote, and I hear the TV turning on, but then it automatically turns itself off again. Tried it several different ways using...
A component is shorting out, and the TV is auto turning itself off for protection. Usually it is a shorted out horizontal output transistor. Only a tech can fix this.
Nov 13, 2008 | Sharp Televison & Video
Turns off by itself!!!
The flyback transformer are damaged .
May 26, 2008 | RCA TruFlat 27F520T 27" TV
My TV turns itself off and on by itself.
You have a timer that has been accidently set by someone by the remote control.
If you have an instruction amnual for the tv, it will tell you how to turn off the tv's timer.
Feb 13, 2008 | RCA P52930BL 52" Rear Projection...
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
Electro Med Services...
