No. You don’t have to use it. But if you want to try prime pantry for free you can skip two day shipping on next shimpment and goose prime pantry credit.
the fuel pump is burnt out. the pump uses the fuel to cool itself. running low fuel the pump heats up and burns the plastic gears inside. thats why the fuse blew. need to take out gas tank to change pump.
I removed the resevoir and pressed the hole where the water enters the machine. There will be a bit of water that should come out and then put the water reservoir back in.
Pumps don't need to be backwashed, some filters do. Sand and DE filters need to be backwashed when the filter pressure has increased to 10 or 11 psi. depending on the manufacturers recommendation. The cartridge filter cannot be backwashed but instead it is removed and a hose sprayer is used to clean out the dirty outside. Your pump does need to be primed so it is not trying to pump mostly air. Each time the pump basket area is low in water then it needs to be primed. You will know how low it can go before it needs to be priming by turning it on when it is low and if it cannot start pumping water at full rate then at that level of water it needs to priming. If it is pumping water at full flow and you turn it off it should not need re-priming because there is enough water in it to force the air through the system. I hope this helps.
