Question about Lexmark C546DTN Color Laser Printer
C546dtn printing too much yellow
When printing color pages, the pages have yellow throughout the page. Replaced the yellow cartridge twice and cleaned the roller several times, but the yellow keeps taking over the whole page.
  • Lexmark Master
  • 1,915 Answers
Check the yellow drum unit carefully, could be a full or clogged waste toner collection unit.
Posted on Nov 15, 2014
tom19511
  • 1601 Answers
SOURCE: White lines appearing on print
White Lines on the Printed Page ID:193 null.gif null.gif null.gif
Clean the print nozzles as follows:
  1. Go to Start, Programs, Lexmark, Lexmark Solution Center (or Lexmark Control Program) and select the Cartridges tab.
  2. Select Cartridge Nozzles (or Clean Print Nozzles).
  3. Check the diagonal lines above and below the solid horizontal lines. The diagonal lines should be continuously solid from left to right, with no gaps.
  4. If there are gaps at the top that diminish at the bottom, run the Clean Print Nozzle page a few more times. If the gaps are gone, the Clean Print Nozzle page has probably resolved the problem.
  5. If the gaps still exist, you should unblock ("wick") the cartridges. See How to Unblock/Wick the Cartridge Nozzles.
    For additional help, refer to the following article: How to Clean the Maintenance Station .
Posted on Nov 14, 2007
JackHeath
  • 1049 Answers
SOURCE: printing blank pages
Check that the cartridges are seated correctly. Also clean the contacts in the casing that the copper portion of the cartridge sits against.
Posted on Jul 23, 2008
  • 1564 Answers
SOURCE: Small lines or specks on the right side of every page
Did you try cleaning the lense? You'll have to pull all the toners and open the little door below and wipe with a clean lint free cloth in ONE direction.
Posted on Apr 04, 2009
SOURCE: Printer won't recognize color cartridge
lexmark x3430 says cartridge incorrect but right cartridge.
Posted on May 25, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
    Posted on Apr 09, 2010
    Yelllow color is not printing
    check yellow cartridge to see if toner seal tab has been pulled out
    Aug 31, 2014 | HP LaserJet 2840 All-In-One Printer
    Yellewo does not print
    Must replace the nozzle/ cartridge carriage as the nozzle for yellow is most likely clogged
    HP ink jet 1200..prints only test page after replacing the yellow cartridge.test page only shows black and blue inks are good.need help.
    Important thing: HP inkjet printers having self align technology & its aligns automatically after replacing the ink cartridge/s.In the process of align it will prints align page &it will read it on the model.
    Suppose if you replaced yellow cartridge, as usually it will print align page, but if one or more cartridges not printing properly align will not completes. Results every time it will prints the align page when its switching on. Align will completes only when all cartridges/print heads are in healthy condition.. Check the alignpage find out which colors are not printing properly, replace it to over come from this issue. Now you decide what to do?..
    Dec 11, 2012 | HP Inkjet 1200dn Printer
    Whenever I print color, entire page comes out blue. I have replaced the cyan cartridge (twice) and the Laser Transfer Kit. Sometimes there are thick blue streaks in addition to the overall blue color. What...
    Run the "disable cartridge check"
    It will be in the Diagnostics.
    Once you start the test, you can remove all the cartridges. Put the cyan in the black cartridge slot.
    print a config page. If it is all blue, you have another bad cartridge. If it prints correctly(minus the other colors)...continue
    Now put the magenta in the cyan cartridge slot. Print the config page again. If you have red all over the page, you have a problem with the slot itself.
    Press the STOP button and then select EXIT diagnostics. Put the cartridges back where they all go and run CALIBRATION more than once.
    Select/menus/down arrow/configure devce/select configure device
    Down arrow/print quality/seect print quality
    Down arrow/ calibrate now. Select it and wait.
    Oct 25, 2010 | HP Color Laserjet 3550 Printer
    My copier is printing yellow throughout the page when it shouldnt
    all colour empty in your cartridge. only yellow colour is in. so all printing is yellow. black colour cartridge too empty.
    Feb 25, 2010 | HP Officejet Pro L7650 Printer
    Won't print in color
    All cartridges are new...report shows 0 pages for yellow left yet all others added at the same time show thousands of pages left. Everything printed is in black with no color. BTW: I have 3,000 pages left with black cartridge and the display says I need black.
    What should I do?
    Nov 20, 2008 | HP LaserJet 2840 All-In-One Printer
    C88 / T060 cartridge refilling problem
    sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
    Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
    HP DeskJet 970Cse won't print yellow
    Here is a link to hp's web site. They will troubleshoot your issue. This link is linked to a page talking about HP Inkjet Cartridges and Media - Missing Color, Wrong Color, or Streaks in the Printout. There are several links in this site to go off of and troubleshoot further. Hope this is helpful:) http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00224&lc=en&cc=us&dlc=en&product=60097&rule=34749&lang=en Jason
    Sep 04, 2007 | HP DeskJet 970cse InkJet Printer
    Cartridge alignment
    So if the magenta or yellow are not showing up, it may mean you have installed an empty (or dried up) color cartridge. If you have it, put the "low" volume color cartrige back in and print an alignment page. If you don't have the cartridge, no problem, just print a page from Google. Don't worry about the alignment until you print from Google. See if color is even available. ZT3000 "Beta tester of "0"s and "1's"
    Aug 21, 2007 | Dell 924 All-in-One InkJet Printer
    Lexmark C546DTN Color Laser Printer Logo
    90 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
