Question about Boating
Bruno 670 lift motor is slow on up lift ? - Boating
bruno 670 lift motor is slow on up lift ?
  • 63 Answers
Possible causes:
Maximum lifting capacity: 200 lb./91 kg.exceeded.
Brushes / commutator bad.
Gear case lubrication inadequate.
Bad bearings.
Battery low or bad.
Posted on Nov 15, 2014
My bruno regal 44 scooter seems to slow down after a few hundered meters, once I stop, its at full speed again, is the a safety feature?
You maybe experiencing a brake hanging up, causing drag on the motor. the brain box senses over current use and will automatically slow down. The motor brushes maybe worn down and have a build up of carbon powder, particularly on the bottom side of the motor, causing this problem, remove brushes and blow out with compressed air, no Sprays please this can cause more harm than good. Note take out all brushes before blow it out with air. Check brushes springs are not discolored. http://www.strege.com/BlueDoc
Jul 29, 2015 | Health & Beauty
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
Need manual for ASL-215 bruno lift
You should contact Bruno directly. Here's the link to their support page Request Information on Any Bruno Product
Feb 09, 2015 | Health & Beauty
Delta table saw, 34-670, keeps shutting down
There could be several problems. First, make sure you have a sharp blade. Then check the arbor for drag just after you have been using it. Unplug it, lift the motor a bit (to loosen the drive belt) and turn the blade with your hand - it should turn very freely. Check the motor shaft for drag too by turning the motor pulley with your hand (with the belt loose). The motor should have just a tiny bit more drag than the arbor shaft. If all of these check out ok, then you might have an insufficient gage of wire between the electric panel and the saw - a thin wire long extension cord is often a problem. If you are using an extension, try to eliminating it and plugging directly into the wall. (It depends on the length, but in general don't use a cord lighter than 14 ga - higher numbers mean skinnier wire). And it could be that the house wire is too light - a long run of 14 gage wire is too light - you want 12 gage wire and a 20 Amp rated outlet. If all of these are not the problem, then you have a bad motor that is partially burned out (that is, the insulation on the coil windings has melted and the coil wires are shorting out resulting in coils with a lot less turns than the motor was designed for. You can replace the motor or get it re-wound. Good luck!
Sep 11, 2012 | Delta Table Saw
Boating Logo
102 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
