Question about Mitel Superset 4025 Corded Phone (mitsup4025)
Fprgotten passcode last person in office is gone. no way to get previous passcode. can't retrieve new messages
  • Richard Maisel
    Richard Maisel Nov 19, 2014
    The problem is that I don't have the passcode. The previous inhabitant of the office is gone and there is no way for me to get her code so calls keep coming. I'm the school social worker - and I can't retrieve them unless I put my info, name and message into the phone but I can't do that without the darn passcode!
  • Richard Maisel
Checking phone messages
When trying to retrieve your messages from a different phone, you will call the number and when the message starts playing you will press either # or * (depends on your phone service as to which one you push). The message will stop and you will be asked for your pin/passcode. Enter it and you will be taken to a menu where you can pick the option to retrieve your message.
Jul 20, 2012 | Panasonic KXTG7432B 1-Line Cordless Phone
Tip
Reset i phone password
It is never a joy when one loses or forgets a password. This is true within any situation.
But what makes it far less joyous, is when losing that password and not being able to retrieve it, can mean the difference between simply resetting a password, or not being able to retrieve or reset the password, and running risk of losing all the data secured by that password, completely.
Welcome to the lost or forgotten iPhone passcode.
The passcode for an iPhone is the similar to a standard password with the exception that an iPhone passcode is only 4 numerical digits long, like that of a PIN or Personal Identification Number, more commonly implemented with bank ATMs.
A password on the other hand, can be as few as 6 digits up to 128 alpha-numeric characters or longer, depending on the encryption protocols which may be used with a password string at any given time.
A Pass code, is not as sophisticated by any measure, in regards to the password, especially with the numerous cryptic and encryption protocols that are employed in the process of creating effective passwords.
But don't be fooled by the passcode... try losing or forgetting a passcode and sometimes it can be a real pain just to restore it or reset it. The iPhone passcode has its challenges in that same fashion.
When an iPhone passcode is lost or forgotten by the user, like any access authentication string, it blocks the user from accessing his or her data on the now locked iPhone. Also, the passcode for the iPhone is not included with the iPhone's backup, so it makes retrieving the passcode nearly impossible to retrieve, especially if you have forgotten it.
So why would Apple make it so difficult to recover the lost passcode?
Why not? What happens if you lose your iPhone or it is unfortunately stolen? Do you want the individual who finds it, or in the perpetrator who stole it, to have access to your personal data on that device? Of course not! So chalk this up as a safety feature from Apple, to protect your private data and information, even in such an unfortunate situation.
Now what to do if you have forgotten your iPhone pass code?
You will have to unfortunately restore your iPhone with iTunes, which will unfortunately wipe the iPhone clean, but, it will gain you access to your device once again.
Now before crying in defeat, remember last time you synced your iPhone with iTunes (hopefully you did that recently)? You see, each time you sync your iPhone with iTunes, iTunes creates a back up of your iPhone's data.
The reason, results from if you do have to perform a recovery of your iPhone due to forgetting your iPhone passcode. Its that recent backup performed by your most recent sync with iTunes, which can be restored the first time you sync your iPhone, after a restore is completed.
Consequently, a restore is necessary, as a passcode is NOT included in any previous iPhone backup file. That is also a safety feature as well, because in the wrong hands with the right tech saavy, but ne'er do well individual, your precious data on the iPhone surely can be compromised.
Yes, you may have lost some files, applications or settings due to not syncing that information more recently. But think about it. It is better to have lost some data, than to have to start all over again, because you lost all your data.
With your previous iPhone back up through iTunes on your computer or notebook, you will will still be able to recover your music, video, calendar, and contacts, thanks to iTunes, but you may lose text messages and past mail for example.
To restore your iPhone is simple:
* Be sure you restore your iPhone on the same computer or notebook that your previous iPhone backup files or stored.
* Now, make sure you are using the latest version of iTunes
• Be sure your iPhone is correctly connected to your computer or portable.
• Finally, in the left column under Devices, click on your iPhone, then click on Restore in the Summary tab.
* Allow the process to complete and your iPhone will be restore to its original factory default settings.
* Now simply sync your iPhone with iTunes and this is where your last sync now comes into play. When you sync after the recovery, iTunes will look for your iPhone's previous backup and per your OK, will restore your most recent backup to your iPhone.
This time, when you set your passcode... Please make sure to write it down somewhere or on something, that is easily accessible and one you won't soon forget.
Yes, an iPhone passcode may only be 4 digits long, but from the explanation above, you can see, it makes a whole lot of sense to keep your passcode closer and another iPhone restore, as far away as possible!
For more information about making sure you are correctly backing up your iPhone with iTunes, here is a good support page from Apple on the subject:
on Jun 07, 2010 | Cell Phones
Tip
It is never a joy when one loses or forgets a password. This is true within any...
Apple Support Link:
Backing up and updating an iPhone (or iPod Touch)
Bonus Link: Password Protect your iPhone
Thanks for reading!
Regards,
-Mactechtrainer
on Feb 10, 2010 | Computers & Internet
Can't retrieve voice-mail?
Most voice mail services require you to dial your own # to retrieve VM. Mine does not require me to use my area code. Yours may or may not (depending on your service provider). You may need a passcode to get into it the first time (maybe not). Your passcode will either be - the last four digits of your SS# or a four digit passcode that will be listed on your monthly bill. However, once you are in you can change your preferences. You can even set it so that you don't need a passcode at all when calling from that #. Only problem with setting it that way is you can't check your messages when calling from any other #.
Hope this info was helpful. Good Luck!
Jan 29, 2010 | Vtech CS5111-2 Twin Phone
I have a Partner-18 and need to reset the password for a user
Delete the mailbox for this extension then re-create entire mailbox.
May 04, 2009 | Avaya Lucent Partner 616 Phone
Tip
Forgetting your iPhone Pass code... What to do?
Apple Support Link:
Thanks for reading!
Regards,
-Mactechtrainer
on Feb 09, 2010 | Cell Phones
Passcode
wats the passcode for a 9xx plantronics bluethoot
Feb 02, 2009 | Plantronics - Bluetooth Headset Plus Base...
Txt n on the iphone
it's a workaround, but it works if you're going to leave your phone unattended...
First, go to Settings > General > Passcode Lock Turn the passcode on and create a password to protect your phone--set this to the time you prefer for your phone to go into locked mode.
Next, under the same Passcode Lock screen, set the "Show SMS Preview" to off.
Lastly, when you're going to be away from your phone, set the phone to Airplane Mode under general settings.  By setting to airplane mode, you won't get any new information pushed to you.
If you're not in airplane mode, it will still show on your home screen that you received a text message from a specific number but it won't preview the message. In order to retrieve the message you will have to go into the sms function, which will require that you enter your passcode.
It's not perfect and it requires you to think about it, but it will work for you.
Oct 17, 2008 | Apple iPhone Smartphone
Have lost all messages
They might be on the computer at your service provider. You will need ID to retrieve them.
Dec 18, 2007 | Nokia N95 Cellular Phone
Mitel Superset 4025 Corded Phone (mitsup4025) Logo
53 people viewed this question
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
