Question about Samsung 1.8 cu ft Over-the-Range Microwave Stainless Steel SMH9187ST
Open door and internal fan engages.
Noticed this today and not sure what would cause this to happen. When I open the door on the microwave I can here the internal fan running. When I close the door the fan is not running. My ask is would this be caused by a bad control assy. or the door latch triggering the internal fans to engage, Looking to determine how to go about resolving this issue as this has never happened when opening the door.
    Prodigy:
    An expert who has answered 500 questions.
  • Samsung Expert
  • 650 Answers
One of the door interlock switch could be bad.
Posted on Nov 15, 2014
  • 19 Answers
SOURCE: constant humming sound
the most common problem with ALL microwaves is the magnatron
Posted on Dec 30, 2007
  • 25 Answers
SOURCE: samsung smh7150 shuts down after a few minutes.
If the mag overheats because its not being cooled it will shut down until its cool.
If the fan is turning slow you can try oiling it but it likely needs replacing.
Another thing that causes this is that the exaust port is blocked because its upagainst the wall and the hot air can not escape.
Posted on Jan 14, 2009
  • 30 Answers
SOURCE: Samsung microwave door popped open and now won't
The spring attachment to the moving latch has broken off either replace the latch or drill a small hole in the latch body and attach some heavy steel wire to make a new attach point for the spring. the inside trim easily pops off and the latch just slides off.
Posted on Mar 20, 2011
MicrowaveSvc
  • 9047 Answers
SOURCE: MODEL MW543OW, TURN OVEN ON TO
That would be model MW5430W. but no matter.
I would suspect a bad door switch or door switch mount.
See the files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Posted on May 26, 2011
Testimonial: "very good feed back, thank you!"
reyjoshua07
  • 1157 Answers
SOURCE: SAMSUNG MICROWAVE, MODEL SMH9187ST, WHEN NOT
Hi dschema,
You have a door switch issue. There are three behind the panel. If you can lift and hold the door and it starts one of them is bad for sure. You would be better off replacing all three or have a repair man replace them because a microwave can hold 3000v even unplugged.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 20, 2011
GE Profile microwave PVM1790 starts, what I believe is an internal fan, when I open the door. I sure hope it's not the microwave component frying me.
You probably have a defective door switch, or a bad relay. You are not being microwaved. It would blow its internal fuse to prevent that from happening.
Jan 16, 2017 | GE Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Fan runs when door is closed and no time set.
Some GE units were starting on their own. I would definitely unplug this oven and call GE to make sure yours wasn't one of the ones being re-called.
Feb 14, 2013 | GE Advantium 120 Convection/Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Microwave light and fan goes off until door is slapped.
This seems to be a defective door/interlock switch. There is a minimum of three interlock switches inside the oven that operate by the catches on the door. By opening the door or slapping it you are causing the to make connection.
Jun 07, 2010 | Hotpoint RVM1435 Microwave Oven
Internal fan on microwave runs with door open
I have the same problem with mine!!
Apr 10, 2009 | GE Microwave Ovens
Magnetron cooling fan
Are you sure it is the internal blower and not the VENT fan ?
Aug 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung 1.8 cu ft Over-the-Range Microwave Stainless Steel SMH9187ST Logo
129 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
