Question about Acer EY.JBY05.005, X1110, X1110A, X1210, X1210A, X1210K, X1210S Projector Lamp - EC.K3000.001 - OEM Equivalent
Acer x1210 projector is not power on,withi in 3 sec turn offed. what is the problem. how can I resolve this kind of issue.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Check the fans ,whether the fan is running,when you turn on the projector
Posted on Nov 18, 2014
Why Projector shuts down after turn on after a minutes ? and shows Temp LED and Lamp LED?
the mainboard is fault
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Aug 07, 2014 | Acer EY.JBY05.005, X1110, X1110A, X1210,...
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Acer dlp 1120 show pinkish tint
for acer p1120 pinkish tint solved:
reset your lamp hours
do hard reset :
power off beamer
unplug power cord and press power at same time
replug power cord in beamer and press power button for 10 sec
now it should turn up normal again pink is gone
i called acer also with solution so they can also help you out if you dont get it done
Sep 11, 2013 | Acer P1120 3D Video Projector ACER
My boss LG laptop screen bcame dullness plz tell me how to resolve this problem
Check whether the screen becomes dull when it comes to Windows.. (i mean if we turn on the laptop, screen should be normal and it becomes dull when it enters windows) in this case check for Battery settings (power adjustments).. if you find it is totally displaying dull, monitor should be replaced
Jun 17, 2010 | Acer Aspire One PC Notebook
I just replaced the lamp, but the projector won't power up. It has 2 solid red lights
To resolve the issue, follow these steps:
1. Turn off the master power switch, disconnect the power cord, and then wait a short time.
2. Reconnect the power cord, and then turn on the master power switch. 3. If the previous steps don’t resolve the issue, the lamp might be at the end of its life. (double check that you get a good one lamp, and that are installed correctly)
4. If your projector still doesn’t turn on, turn off the master power switch, disconnect the power cord, and then contact your local repair shop for Fix the Board on the prjector
Mar 11, 2010 | Mitsubishi HC3000U Multimedia Projector
Acer P3250 will not acccept password...
I found a solution that worked for me:
1. Turn on the projector
2. Press "Power > Left > Left > MENU" (Opens the system menu)
3. Choose "RD Menu"
4. Choose " EEPROM Restore" (the projector turn off and the power lamp blink red for about 1 minut. Then it stops)
5. Turn on the projector again and it should work again
Sep 15, 2009 | Acer Office Equipment & Supplies
I have a toshiba TDP-S8 projector up until about a week ago it was fine but now when i try to turn it on either by remote or button on projector the yellow power light disappears then reappears about 5...
Check the color wheel if it is not turning when you hit the power button (light should flash) you have 1 or 2 loose caps on the bottom of the main board behind the audio input try to resolder them with low heat iron these are smt caps and very hard work on if you have not worked on this kind of job take it to a expert
good luck! ps make sure you glue them down
if you do get them to work to prevent a reocurance.
OR you have a power supply issue which
should be a swolen 3300 mf 10 volt cap
in the main power supply.
Aug 24, 2009 | Toshiba TDP-S8 Multimedia Projector
Vertical line white, regular, blinking.
I don't think it's the bulb. Sounds like an LCD panel issue. Maybe one or more of the 3 LCD panels is either not working right or the unit has been dropped/jarred and the panels have moved (All three have to line up right optically to give the right colours). You need to take the projector to a qualified service centre.
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Apr 01, 2009 | Acer Projector Lamp for PD110, PD110z
SP-LAMP-LP3E powers off in 5-20 secs after inital power on
if the new lamp doesn't have a problem, then it's not the ballast, it's just a bad bulb. especially if you didn't get it from infocus. the cheaper lamps don't last long. you get what you pay for.
Dec 23, 2008 | InFocus Projector Lamp for LP340, LP340B,...
Acer EY.JBY05.005, X1110, X1110A, X1210, X1210A, X1210K, X1210S Projector Lamp - EC.K3000.001 - OEM Equivalent Logo
129 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
